Question about Frigidaire Dryers
I get an E9E fault code on my two year old Frigidaire front loading dryer.
  • 15,935 Answers
The error code E9E indicates that low voltage is being detected at the control board of the dryer.
This could be caused by the following factors:
* The electrical power supply to the dryer is bad. Check the dryer outlet for proper voltage (120 volts AC).
* Unplug the dryer and check the wiring of the dryer outlet plug. A loose wire on the terminal block could cause this problem.
* If you are able to safely access the control board in the console, check the red wire that connects to the heater relay on the board.
(NOTE: The dryer should always be unplugged when accessing internal components.)
A loose wire or burned connection in this area could result in this error code.
* A failed control board could cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 27, 2010
Frigidaire dryer. What do the error codes e56 and e9e mean?
sounds like you need to consider a new dryer .
May 19, 2015 | Dryers
Frigidaire dryer error code e9e
Hello zabbster - Typically E9E means that there is an issue with the control board receiving low or intermittent voltage and you would need to contact a professional to verify the house wiring and confirm the power supply.
Sep 25, 2012 | Frigidaire Dryers
Model glgq2152es error code E9E
The E9E code is a low voltage/intermittent voltage alert. It says in the troubleshooting manual to press cancel when this appears.
You may want to check the plug or the wall socket to make sure there is not a short occuring. The fault code is not saying your dryer is broken, just to check for proper voltage.
Jan 10, 2010 | Washing Machines
Dryer front load model # GLG22152ESO, Flashes Error Code E9E
Ok, i would also pull the blower assembly and, check it for clog's as well. clean out the entire exhaust hose as well. if this doesn't stop the shut down, you will need to replace the hi limit thermostat and (dryness)sensor(if equipped) as well.
Jun 09, 2009 | Frigidaire Dryers
My affinity frigidaire dryer keeps flashing an E9E error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#
Nov 26, 2008 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Fault code E9E
DEAR FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
Sounds like an electronic problem!
Better have factory service do it!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Jul 14, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Error code E9E
DEAR FRIEND,
This is an electronic problem and must be replaced by factory service!
If it happened from th beginning call factory service right away, it's under warranty, you do not pay for it!!!!!!!!
There is no other choice!
If the dryer was 10 years old I would recommend to trow it out and not spend a dime on it! Are you ready to buy a new machine??
If not let service fix it and get back to having clean clothes!
A&E Factory Service
1(800) 905-9505
Thank You
Bless you,ngfam1
Jun 12, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire dryer
it sounds like the programer on the drying side has had its day
Dec 23, 2007 | Frigidaire GLTF2940ES Front Load Washer
Dryers Logo
625 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
