Question about Zenith Televison & Video
How to change channels to channel 3 without remote?
  • Zenith Master
  • 520 Answers
Will your tv allow you access to the menu from the front of the set? (try holding down different combinations of buttons on the front of the set if there is no menu button) If you can get into the menu, run the automatic channel memory feature. Make sure the device you want to see on channel 3 is on and connected to the set. (if it's a vcr make sure it's in vcr mode) This should find the device and set your tv to channel 3. Use the channel buttons on the front of set if its not right on ch3.
Posted on Sep 08, 2008
How do I change from channel 4 to channel 3 without a remote control?
Why not purchase an inexpensive universal remote and use it to operate your Emerson TV?
Jul 30, 2015 | Emerson Televison & Video
I don't have a remote control for my RCA TV and it's on channel 2. It needs to be on channel 3 so that It's compatible with my cable box. How do I change the channel without a remote to channel 3. It
U should have a menu button on your tv.If so try to find the channel setup option if you find this you should b able to manually go through your channels to add & delete the channels you want.If not you will have to go out a buy a universal remote.Make sure that it is compatibl to your tv.They should be a list on the back of the remotes pack stating all the brands that the remote is compatible with.I think you should be able to get one for unde 5 dollars.in the pack it should have an instruction manual.some tvs u can set up very easily & some you might have to keep putting in different codes until it works.Hole this could be some help to you.Good luck.
Apr 19, 2013 | Televison & Video
Can you change channels on tv's without remote
Hello
If your tV has a Menu Button and channel up-down, programme up-down button at tis front control panel, you can change channels and other inputs using these buttons. You haven't give any details of your tV, its Brand Name, Model Number etc, so I can give you this much detalils only to you.
Nov 25, 2011 | Televison & Video
My television set is stuck on one channel....the audio changes with the channel but the picture stays blurred on one channel...whats wrong with it?
Lots of possibilities. If you are using the remote, try also using buttons on the TV to change channels. If TV buttons work, the remote is broken or perhaps try changing batteries and cleaning battery contacts on the remote. If neither work, lots of other things to try. You may need to set preselect channels, so your TV thinks there is only one channel out there until you do. If you are on a cable box you just need channel 3 and change channels on the cable box. I can't tell what you mean by "audio changes with the channel" ... if you mean that when you try to advance channels, it increases volume and moving down in channels lowers volume that would be strange -- if you are using a programable remote it might not be set correctly (try another programming code). The "blurred" picture is probably symptomatic of having the set on the wrong channel, and if you could set channel it might clear up ... I'd start with getting channels to change. If you need more help, give the brand and model of TV, say if you are using a remote (original or programable), and what the 'audio changes' comment means in more detail. Probably worst case is that your tuner circuit is fried, but don't assume that without more diagnostic.
Aug 29, 2011 | Televison & Video
How can you change to channel 3 without remote?
U only can now used those buttons like channels + - for channels,it will alway skip channel 3.U can't get channel 3 if channel 3 is not in ur tv save memory.Try website like Remotes.com to buy the tv original remote to used.
Jun 30, 2011 | Daewoo DVQ13H1FC 13 in. Combo
Need to change tv to channel 3 without remote!
go to menu and see if you have channel selection on go down thaT way. you should be able to program it in.
Feb 16, 2010 | Televison & Video
Getting a specific channel on the TV without using a remote
Usually if you go into the setup menu, there is an option to allow you to either "scan" for a channel, or "input" a channel. In this case, select "input" and see if the TV will allow you to press the up and down channel buttons and go to a specific channel. If so, when you get to channel 4, press the "add this channel" option (or whatever the menu option says) and you should then be able to go to channel 4 using the buttons on the front without skipping over it.
Jan 24, 2010 | Televison & Video
Comcast Remote requires 3 digits be entered to change channels
I had the same prob and found the answer posted elswhere.
This worked for me...
If you go into the main menu under Setup --> Guide Setup --> Set Auto-Tune to "YES".
now the channel will change without the 3 digit requirement.
Nov 23, 2008 | Universal Remote Control Remote Control
l. Push the "Menu button"
2. Push the "Menu button" again
3. Scroll to "Setup" and push "OK"
4. Scroll to "Guide setup" and push "OK"
5. Scroll to"No Auto Tune"
6. Click on arrow next to "No Auto Tune". This will change it to "Auto Tune".
7. Now exit, or just punch in any channel number.
You should now be able to go directly to a channel without entering zeros.
Nov 23, 2008 | Philips Tivo HDR812 80-Hours Video...
My daughter brought her tv home from college without the remote. I'm now trying to hook it up to digital cable. It needs to be on channel 3. When I try to manually change the channel to 3 using the...
The easiest will be to make sure that the cable box is on and sending out a signal to Channel 3 and auto-programming the set. Channel 3 is skipped because the last time it was auto-programmed, there was no signal on that channel.
Dan
Jul 10, 2008 | Televison & Video
Televison & Video Logo
101 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
