Question about Acer Aspire 5600 Series 5630-6951 Laptop
Format pc laptop
Bios instruction to run format installing new windows xp
    President:
  • 2,961 Answers
If you wish to do a full system factory recovery, on boot up press Alt & F10, or press F2 or Del on boot up, select the cdrom as first boot device and insert windows cd, save settings and exit for a reboot.
When prompted to press enter to boot from cd, do so and the option to repair or install will appear, choosing install will format your drive.
Posted on Sep 08, 2008
I was looking for step-by-step install guide to putting new hard drive and loading Windows XP on my Dell Inspiron E1505?? I purchased a WD 320GB SATA hard drive to replace my dead 80gb hard drive....Dell...
All you've got to do is:
1) Insert the new hard drive.
2) Press the F8 key as the laptop boots. This will take you into the BIOS.
3) Locate the disk drive priority setting in the bios.
4) Set Priority 1 to your CD/DVD drive and priority 2 to the 320GB hard drive.
5) Save settings and exit the BIOS. This should reboot your laptop.
6) Insert the Windows XP CD.
7) It should not start the setup as it recognises the CD.
8) I will recommend that you format the drive before you install, go along with the format (make sure it does a full format).
9) After the format it will reboot your system.
10) You will be prompted with a message like "Press any key to boot form CD", DON'T press anything otherwise it will start all over again.
11) Now it should start the install. Follow the on-screen instructions.
Mar 15, 2011 | Dell Inspiron E1505 Notebook
Can you help me how to format windows vista starter in acer aspire 4715z i would like to changer it in windows xp pro can you help me step by step instructions... thanks!
get a bootable dos and format the entire disk;and try;if the BIOS doesn't support installing XP then downgrading the bios which is a risky thing
Nov 26, 2009 | Acer Aspire 4720 Notebook
How to install windows xp into compaq presario cq40
compaq cq40 is one particular model from compaq which is literally designed for vista and when you want to install win xp ;it doesn't work becoz the BIOS block it;the only way out is to downgrade the system BIOS which is a risky thing.check your bios model and version and google for a lower version and download it and flash the ealier BIOS.gooogle more on How to downgrade BIOS
Sep 21, 2009 | HP Compaq Presario CQ50Z-AMD Sempron(TM)...
I loaded a new, Windows XP formatted IDE in a 570e-then nothing
Well the formatting must have been different! try dropping the partition and format using the pc you are installing it on
Sep 07, 2009 | IBM ThinkPad 570E Notebook
Just bought a laptop cheap as on trade me for extra battery was told that it was broken but fired it up and works but is asking me for a user name and password to log on to windows. can i over ride it or...
keep the laptop, hope it got a working cd-rom/dvd-drive !(if not, take-out /replace the harddisk)
-win xp has to be removed from harddisk,
the hd must be formatted so you got a blank hd to set up your new system
you'll need :
- antoher PC with internet connection and cd/dvd-burner
- a win98 installation cd or bootable savecopy of it,
- a new win-xp install cd plus cd-key
- a program called PC Wizard(download)
and a bit of time...(one night or two:-)
follow instructions:
if you can enter bios (press F1 or F2 or Del)
during booting), youre lucky...
enter bios while booting, in the menu look for boot otions or devices, change order of boot devices, so that cd/dvd-drive is 1st, then save and exit (F10)
insert win98-CD, boot from cd, try to setup win98, you'll be asked to erase/ format all data/installations/partitions
on the harddisk (drive c:,probably), do so, format the drive using the FAT32-file system,
then end installation without fully setting up win 98.
now you should have a blank disk witout any operation system on it.
now put in win xp cd, go through the whole installation process
install and run pc wizard(it'll tell you all hardware devices of the laptop)
get the proper drivers for the notebook for win-xp from the net(google might be helpful)
install them.
happy computing!
if all this did not work, remove the harddisk,(you'll have to unscrew a lot of the laptop)
replace it by a new s-ata ide-drive()and..
erh.. come again then, this is a long process as well
Jul 23, 2009 | Microsoft Windows XP Professional SP2 Full...
HOW TO FORMAT HP 530 LAPTOP
all u need to do just enter either "Delete" or "F2" button when u turn on ur computer then go to bios section and change the boot sequence to CD-ROM first then save and exit
aftert that put in ur CD-ROM any bootable windows xp cd then it boot by itself then follow the instruction to format it and install new O/S
Jun 22, 2009 | Computers & Internet
How to install windows xp on preloaded vista
If you have Windows XP OS installation CD, just put it in and boot your computer.
Leave the system till it comes to a blue screen. Choose to install a new OS and follow teh on-screen instructions.
Choose to format the C drive if you wish to delete Vista and the data in you C drive. Proceed with the instructions and you will be able to install the OS.
Hope this helps!
Mar 29, 2009 | Microsoft Windows XP Professional With...
Instaling windows xp
when you removed vista then you install Xp your Hardware drivers are not match so you need to install porper harware drivers..
Jul 03, 2008 | Toshiba Computers & Internet
Installing widows XP
first, have a WIN XP startup disk...created by (in windows)  inserting floppy and right clicking choosing format and select option "create MSDOS startup disk"
first backup all personal files...then restart and bypass to DOS screen at startup...try using F8 key just after BIOS screen...then select startup to DOS prompt only...then run (from the floppy disc) format c:
now you should have a nearly bare hard drive. repeat above steps and this time choose "startup using CDROM drivers"...then insert CDROM and redirect to that drive letter (d drive?) and run setup.exe.
Oct 30, 2007 | Compaq Presario C552US Notebook PC
Acer Aspire 5600 Series 5630-6951 Laptop Logo
73 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
