Question about Acer Aspire 5600 Series 5630-6951 Laptop
Help installing windows xp
I'm on the bios bootwhat do i do format the install windows xp press copy,idid try changing cd ram and hdd and press f12 still when back to windows
  • 95 Answers
Place your xp cd in tray/then go to setup and change the boot order to cdrom as ist boot then HD
Posted on Sep 14, 2008
Hi install Windows 7 on my hp compaq nx6310 Celeron M. and put a 500GB HD I worked fine but after installing some programs are lost anrranque files then I wanted to install windows xp tells me not see the...
restart your computer witht he XP cd in your drive and maiing sure it boots to cd by either pressing F12 or going into your bios and setting the priority to cd first then hard drive second after you have done this if it still cant see the hard drive then the hard drive has developed a fault and will need replacing if you havent formatted it yet try and see if it boots up to windows 7 if it does then it means the xp cant format the drive. if you have more problems then please use the comment below to describe whats being done. Kronoguy
Jun 29, 2011 | HP Compaq Business Notebook nx6310 -...
I installed windows xp sp2 in the bios setup boot from cd / dvd. first of all windows format hard disk and copy files. the two processes have been successfully proceed. after that, this message appears...
1. Maybe your HDD is getting to die.
2. Try to switch off any RAID in BIOS, and switch you IDE controller into compability mode if it is in you bios (otherwise you need the floppy with you motheboard controller driver) while installing windows)
Jun 06, 2011 | MSI PM8M-V Motherboard
RM Z91FR laptop I want to remove the windows "Vista Ultimate" operating system and go back to XP Vista has slowed the machine drastically and filled the HD. I also want to instal a larger HD...
try to format all your drive by deleting your partition..insert your xp cd room boot with cd room press enter, press f8 press esc, press d, press l, then press c and enter
May 06, 2011 | ASUS Computers & Internet
I try to format my pc 1st time its operating system is windows xp i have inserted a xp cd ..... and click reboot but no change occur and i am also unable to format all other drives which donot have os...
First of all does the cd boot into the xp installer. If not the the setting in the Bios would be to boot from HardDisk first. Get into bios by the appropriate key on boot and change the boot order to cd/dvd first and then hdd. Now save settings and restart the system and the xp cd should boot up and you will be able to install xp. Be careful as you may delete all data on the hdd.
Some bios use the del or f2 key to enter, see press __ to enter setting's or bios.In that goto the boot order and change appropriately.
If xp is already installed then if other drives are not acessing saying not formatted then the easy fix would be to right click on non formatted drive and click on format. Then you will be able to access it. Do same for all other drives.
Jan 15, 2011 | Computers & Internet
Hi there, my problem is ,my windows xp can't startup. i thought my OS has problem, then i try to reformat it (reinstall winxp). the format process fail to complete as well. I try to format same HDD to...
you need to reinstall it completely ...but first check the ram memory ..sounds like a problem there ...If you tried to format during installation and didnt worked..or it worked to format the partition but it didnt let you load start the actuall installation ..this is a issue of Ram memory ..(it may also give you blue screen errors..)
if you only tried to format it from the windows...there is an issue cause this is not possible for partitions with windows on it you need a windows installation bootable cd and boot from it to reinstall and only then you will see if the issue is indeed with the Ram memory ..or was just plane ...bugged..
so ...if you do not have such a disk ..go here a image ..and burn it by double clcik on it ..(using nero for file association ) ..on a new blank cd-r
after that select the first boot device...(in bios) cd /dvd and restart and see whats going on ...if it fails loading is the Ram memory to blame ..or the Hdd..but if the hdd accepted to be installed in another computer only remain the Ram..
here is the image ...use utorrent to download
Apr 27, 2010 | Microsoft Windows XP Professional
Computer wont boot properly
A POST diags card can help you resolve your problem/s, if not then.
1. remove all devices and insert the floppy drive, one RAM module and video card.
2. Go into the BIOS configuration and set it to the default configuration, check the installed RAM is it correct? .
3. Insert the remainder RAM module/s and check the POST info and BIOS again, has it detected all the RAM?
4. Does the computer Boot up using a floppy boot disk
5. Insert the CD and hard disk and check the POST info and BIOS configuration, does it detect the new drives?
6. Does the computer Boot up using a floppy boot disk, run FDISK, can you see the hard drive, if so delete all partitions (if any) and create a new primary DOS partition and then format the hard drive.
7. Boot up with the Windows CD (may have to change the boot order to the CD as the first boot device).
8. Delete the DOS partition, create a primary NTFS partition and the do a full NTFS format (not a quick format) and continue to install Windows Xp or Vista.
9. Install the other device eg modem, Lan etc. and the drivers.
If you have trouble with the first 5 steps, then you most likely have a faulty motherboard and/or a faulty hard disk.
Sep 11, 2009 | Computers & Internet
How to format drive so to install xp on 5515
If you are Windows XP bootable CD with u,
first u restart ur computer and change the boot priority in the BIOS setup . Then insert the bootable cd and restart computer.
When some message comes in the screen, regarding bootable cd, press any key for installation,
It will take some time to copy installation files, then configure computer hard disk.
Then u have to agree the continuation of installation by pressing F8.
It will ask u either to repair or install Windows
press appropriate keys for that.
It will show the disk partitions and lets u with options of creating ,deleting paritions .
if u want a partition, then select any large partition and press C and type the amount of memory(in MegaBytes) u want for the partition
After finishing creating partitions,
select any partition and press enter for Windows installation in that partition. and select "format and install" option . It will format that partition and restarts . there is nothing to do more .
After restarting , it takes about 40min to install(times inversly proportional to the processor configuration), it asks for the serial /product key fo ur windows bootable cd, and some general settings about time,time zone,username,passwords etc.
After that , Windows would get completely installed.
Then insert ur motherboard CD for installing driver for (audio,graphics,LAN etc)
Then ur system is ready with Windows.
Ask me if u have any difficulty while installing...
Jul 08, 2009 | Acer Aspire 5500 5570-2609 Laptop
Upgrading HDD From 40GB To 160 GB
  1. Use the Windows XP Setup disks to restart the computer, or use the Windows XP CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows XP installation.
  3. Press C to repair the Windows XP installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER.
  5. Type the Administrator password, and then press ENTER.
  6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows XP CD-ROM.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
    copy drive:\i386\ c:\If you are prompted to overwrite the file, type y, and then press ENTER.
Feb 19, 2009 | Western Digital 160GB Caviar ATA-100...
Fail to load files during text mode setup
Maybe its a software problem, have you tried putting in a bootable XP installation CD? After the bios boot and it asks you to boot to CD, press R for repair, it will try to repair your OS, and if it is an OS problem ,then it will boot once again... If not you can try formatting your HDD and reinstalling windows...
Mar 10, 2008 | Toshiba Satellite A65-S126 Notebook
Problem for D101G Intel Mother Board
this problem due to bad hard disk or some bad sector develop on it.repartion and than format (not quick format)and may also run scandisk for surface scanning to locate bad sector.
Manish Kubawat ,India
Oct 28, 2007 | Intel Motherboard
Acer Aspire 5600 Series 5630-6951 Laptop Logo
62 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
