Question about Zyxel Prestige 310 (AM406100) Router
How fast can the data go? - Zyxel Prestige 310 (AM406100) Router
    Scholar:
  • 130 Answers
The speed of the cable modem is only one part of the equation. There are a combination of factors starting with how fast your PC can handle IP traffic, then how fast your PC to cable modem interface is, then how fast the cable modem system runs and how much congestion there is on the cable network, then how big a pipe there is at the head end to the rest of the Internet. Different models of PCs and Macs are able to handle IP traffic at varying speeds. Very few can handle it at 30 Mbps. Ethernet (10baseT) is the most popular cable modem interface standard for the PC. This automatically limits the speed of the connection to under 10 Mbps even if the cable modem can receive at 30 Mbps. Most Local Area Networks use 10baseT Ethernet, and although they are 10 Mbps networks, it takes a LOT longer than one second to transmit 10 megabits (or 1.25 megabytes) of data from one terminal to another. Cable modems on the same node share bandwidth, which means that congestion is created when too many people are on simultaneously. One user downloading large graphic or video files can use a significant portion of shared bandwidth, slowing down access for other users in the same neighborhood. Most independent Internet Service Providers today connect to the Internet using a single 1.5 Mbps "T1" telephone line. All of their subscribers share that 1.5 Mbps pipeline. Cable head-ends connecting to the Internet backbone using a T1 limit their subscribers to an absolute maximum of 1.5 Mbps. To create the appearance of faster network access, service companies plan to store or "cache" frequently requested web sites and Usenet newsgroups on a server at their head-end. Storing data locally will remove some of the bottleneck at the backbone connection. How fast can they go? In a perfect world (or lab) they can receive data at speeds up to 30 Mbps. In the real world, with cost conscious cable companies running the systems, the speed will probably fall to about 1.5 Mbps.
Posted on Feb 19, 2006
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
What could the problem be if my canon 350d focuses but does not take a picture?
Taking a picture with point-and-shoots are so simple as to be dull. Not so much with a SLR at times. There may be a couple of things going on here, first thing is your camera only has the ability to shoot so fast, as its internal buffer takes time to capture and write to that zone, then it takes time to transfer to the memory card. Secondly, the memory card itself, in your case an sd if I have that correct, only writes so fast, and also has to buffer the data. You can buy a camera based on its ability to write very fast data, and you can buy very expensive memory cards that write very fast, but even the quickest camera bodies and cards all have a limitation. You'll have to wait while the writing of image data is fulfilled. If on the other hand it won't take a picture even after moments or a full minute goes by, then you have an internal problem, or bad connections, or a bad pin on the card or the card connection port. You can pull the card out, examine both the card and the port with a magnifying glass, or try another card. It can cost upwards of a $100-$200 to repair for most models in your camera's class.
Jul 17, 2014 | Canon Cameras
Why dose the data light keep flashing
that's normal, it means that there is data flowing. If it wasn't flashing then your router would not be working correctly.
Jun 14, 2014 | Computers & Internet
Low speed 15kb . how to speed fast ?
Hi you can try 3G broadband high speed connection. If you are use a data card then change your data card and purchase high speed supported data card. Beacuse speed is also depends on the Modem.
Thanks
May 20, 2011 | Computers & Internet
Applications are not running fastly...
Remove off your memory card which can be infected and try after removing off battery to reset. If the set still works slowly there are errors and the software must be reinstalled.
Sep 28, 2010 | Samsung SGH-L700 Cell Phone
What does building datsbase mean
Ok when we Build a Data Base that simply means the we Collect and Collate Data, and input them into a Program that stores them in some predefined order, and using search software within that program, can access and display, that data.fast.
Mar 28, 2010 | RCA OPAL M4001 MP3 Player
Bluetooth
it depends on the cell phone to u sending or recieving...see if u r sending to an nokia phone..the nokia phone is slow in recieving...but ur phone cant force it take data fastly...so it happens...as i've seen v3i to v3i its fast...even stil its an prob restart once n use...
ne other prob's do tell me..N plz do rate me
cya
Apr 15, 2008 | Motorola Mobility RAZR V3i Cellular Phone
How can I hotsync both ways?
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Sep 11, 2005 | Palm Zire 31 Handheld
Zyxel Prestige 310 (AM406100) Router Logo
150 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
