Can't seat black laser cartridge in HP Color Laserjet 3800
I was unable to output a document and noticed a question mark on the screen above the black cartridge icon. The message said "install black laser cartridge." So I removed the original cartridge, even though I couldn't believe it would be exhausted already, and went to Staples to purchase the correct HP cartridge for the printer. I removed the two pull tabsf, then slid the cartridge into its track. It won't seat on the left side, and when I closed the front of the printer, I still get the question mark and the error message.
I have design proofs to output -- HELP!!!!!
Thank you.
  • Anonymous Nov 10, 2008
    I ahve the same problem but with the cyan cartridge. Have bought two new cartridges and I still get the same "Install Cyan Cartridge" message.
    Any solutions to the problem!!
  • 96 Answers
SOURCE: Error message: Printhead missing, not installed correctly or has come loose
Ok...very good. If you have problems in the future, send me a message. Kodak Products are my specialty.
Posted on Jul 18, 2008
SOURCE: HP 1610 Won't Recognize the Color Cartridge?? Please Help!
i don't know who checks these messages, but I have the exact same problem, also with my mom's printer. it is no longer under warranty so HP wants to charge me thirty dollars for them to tell me how to fix it over the phone. no thanks.
Posted on Aug 15, 2008
jmassengill
  • 345 Answers
SOURCE: The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Posted on Jan 08, 2009
  • 65 Answers
SOURCE: 11 blue dots print out down the left hand side of documents
It's probably the toner cartridge again. See if you can spot defects at the cyan drum unit that matches the marks on your printout.
Posted on Sep 09, 2009
  • 23 Answers
SOURCE: Samsung CLX-3175FN: Display says toner exhausted
Service Manual can be found here. Free
http://hotfile.com/dl/28988134/55113fe/CLX-3170-3175.zip.html
Posted on Feb 17, 2010
I installed an original Q3971A toner into the HP 2840 laser printer, However there is still a notice to install cyan catridge. Can you help please
PDF]HP Color LaserJet 2840 and 2820 All-in-One for small and ...
h10010.www1.hp.com/wwpc/.../clj2820_clj2840_bro.p...
Hewlett?PackardColour laser printing. HP Color LaserJet ... •Convert hardcopy documents into digital format for easy ... Color LaserJet 2820 All-in-One gives you high quality, ... Oth ring. Why HP. Save time. Printing a file. Printing a paper fax. Receiving a .... Install, configure and manage multiple networked ... Replace toner cartridges easily.
HP Environment: Product Safety Information - LaserJet ...
Dec 18, 2015 | HP LaserJet 2840 All-In-One Printer
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
My boss want to replace the black ink cartridge for one that prints color. Can this be done with the HP 12-a cartridges? HP Laser jet 1022
Unfortunately laser printers don't work this way. The laserjet 1022 was designed for black and white prints only. In order to do color printing with a laser printer you will need to purchase one that is designed to print in color. The laser printers work a bit differently than the inkjets - the laser printers have 4 toner cartridges, one each for Cyan, Magenta, Yellow, and Black, that work together to print a full color page. With the old inkjets you could just replace a black cartridge with a color one.
So, short answer: Sorry but no you can't make a laserjet 1022 print in color. :)
I would recommend looking at an entry level color laser printer from hp, such as the CP2025 (http://h10010.www1.hp.com/wwpc/us/en/sm/WF25a/18972-18972-3328060-15077-236268-3673580.html) if you are looking into purchasing a color laserjet.
Hope this helps
Please rate this post, thanks!
Mar 09, 2011 | HP 645A Magenta Toner Cartridge (C9733A)...
Friends, I put a new transfer kit and laser toner cartridge to my HP Color LaserJet 8550n Printer and when I print, the paper go out completely in black. What could happen?
Put the original cartridges and transfer kit back in the printer.
Print to see if it prints ok. If it is ok, insert the cartridges one at a time, printing something after each replacement. Try the transfer belt last.
If all is ok, one of your replacements is bad. Repeat the swap outs as suggested above.
Jan 29, 2011 | HP Color LaserJet 8550n Printer
Any way to override when color cartridge is empty?
Select black only on the printer and in the printing preferences.
Nov 12, 2009 | HP Color LaserJet Q7582A Yellow Print...
Tiny dots about 1 inch apart down the side of page
Again, this was actually HP Laserjet 3800. Problem solved by chatting with HP, and them having me go into a diagnosis mode that disabled cartridge check. Then, I removed the cyan cartridge, the dots went away. They then had me put the black into the cyan slot, and not dots appeared. I had backup toner on hand, swapped in a new cyan and magenta, and all was good. HP agreed to replace the cartridges.
Jun 19, 2009 | Brother HL 2140 Laser Printer
HP 1600 color laser printer--colors are out of sync
Check the following information please.
General print quality issues
Solving issues with color documents This section describes issues that can occur when you print in color. Color document issues Problem Cause Solution Only black is printing when the document should be printing in color.
c00659983.gif Color mode is not selected in your program or printer driver. Select color mode instead of grayscale mode. The correct printer driver might not be selected in the program. Select the correct printer driver. The device might not be correctly configured. Print a Configuration page.
One or more colors are not printing, or are inaccurate.
c00659984.gif Sealing tape might be on the print cartridges. Verify that the sealing tape has been completely removed from the print cartridges. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The device might be operating in excessively humid conditions. Verify that the device environment is within humidity specifications. One or more print cartridges might be low. If you are using non-HP print cartridges, no messages appear on the device control panel or in the HP Toolbox. Replace any low print cartridges. The control panel is set for override. Replace low or empty print cartridges. A color is printing inconsistently after you load a new print cartridge.
c00659985.gif Another print cartridge might be low. If you are using a non-HP print cartridge, it might be low or empty but you will receive no indication. Remove the print cartridge for the color that is printing inconsistently and reinstall it. The control panel is set for override. Replace low or empty print cartridges. The colors on the printed page do not match the colors as they appear on the screen.
c00659986.gif The colors on your computer monitor might differ from the device output. Select Screen Match in the Color tab of the printer driver. If extremely light colors or extremely dark colors on screen are not printing, your software program might interpret extremely light colors as white or extremely dark colors as black. If possible, avoid using extremely light or extremely dark colors. The media might not meet HP specifications. Use a different paper, such as high-quality paper that is intended for color laser printers. The finish on the printed color page is inconsistent.
c00659987.gif The media might be too rough. Use a smooth paper or print media, such as a high-quality paper that is made for color laser printers. Generally, smoother media produces better results. Repetitive image defect ruler Use a repetitive image defect ruler to measure occurrences of repetitive image defects to help solve image quality problems. Place the ruler next to the first occurrence of the defect on the page. Find the distance between identical defects and see the Repetitive image defects table to identify the component that is causing the defect. Repetitive image defects Measurement Component 24.7 mm0.97 inch Developer sleeve 26.7 mm1.05 inches Charge roller 32.9 mm1.3 inches RS roller 37.7 mm1.48 inches Transfer roller 54.5 mm2.15 inches ETB rollers 56.6 mm2.22 inches Fuser sleeve 62.8 mm2.47 inches Pressure roller 75.4 mm2.97 inches OPC
Have a good evening
Jun 18, 2009 | HP LaserJet 1600 Printer
Apr 14, 2009 | HP LaserJet 4600dn Color Printer
Color Laser Jet 3800 leaving roller marks on paper
Pull out the fuser at the rear of the machine.
Feb 07, 2009 | HP Color LaserJet 3500 Printer
130 people viewed this question
jasbo
jasbo
