Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchenaid Superba Ice Maker quit
Our 3-year old 25 cu. ft. side-by-side suddenly stopped making ice.  The water dispenser works fine, but no water flows to the ice maker.  I guess we'll try the defrost "fix" and see what that does(?). 3 yr old Kitchenaid KSCS25INSS side by side.. ice maker not working- Water in door still works... no water coming into icemaker
  • Anonymous Mar 20, 2014
    water not getting to ice maker
  • Anonymous Mar 26, 2014
    French door
  • 1,543 Answers
Water dispenser works fine eliminates some potential probems, so disconnect the water line at the outlet of the water valve leading to the icemaker. Blow into the tube (with the freezer door open so the air has an escape route.) If you can't blow through the tube, check where the tube passes into the freezer section for an ice blockage. This would result from a water valve not shutting off 100 %, allowing a little water to dribble in and freeze the inlet shut. If you can blow through the tube, most likely the electric solenoid coil on the water valve supplying the ice maker water is bad. In either case, replace the valve. (it is a dual solenoid valve, part # 2315533)
Posted on Sep 08, 2008
  • 118 Answers
"no water coming into icemaker"
Check the connection of the icemaker to the water dispenser, could be an object blocking it. Sometimes simple works, so chuck some cleans pipe clener into it. THis should clear any obstructions, but makesure you rinse it tons, as it is posionous
  • 13,433 Answers
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
  • Ekse Sep 08, 2008
    Also check your tubes, they might be frozen up?
I have a 25 ft Kitchenaid Superba, probably 5 years old or so. It just started to get a large buildup of frost/ice on the surfaces where the ice maker tub joins the ice chute in the door. I have taken the...
There may be a small leak in the pipe at the place of joint which lets small amount of water out and it may be this water that freezes. Have a check of that tube and if necessary get it replaced.
Apr 20, 2010 | KitchenAid Superba KSRG25FK Side by Side...
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My ice maker has stopped making ice. I have Kitchenaid Architect II KSRS25FTBL.Water dispenser is working fine. Ice maker is turned on.
Could be the solenoid valve. It is usually located where the water line connects to the frig. The valve may have trash in it.
Feb 21, 2009 | KitchenAid Superba Architect KSCS25INSS...
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kitchen aid superba fridge - ice maker not working .. water dispencer is
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Jun 26, 2008 | KitchenAid Superba Architect KSCS25INSS...
No ice
Jun 23, 2008 | KitchenAid Superba Architect KSCS25INSS...
Make sure your manual doesn't say something about inline filters, or a float that might be sticking in off position. Depending on how ice is made sometimes they have a float to where water rises so hight then gets shut off to freeze and form the ice.
Nov 10, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
610 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
