Question about Zyxel Prestige 310 (AM406100) Router
What is the difference between the internal IP and the real IP from my ISP?
    Scholar:
  • 130 Answers
Internal IPs are sometimes referred to as virtual IPs. They are a group of up to 255 IPs that are used and recognized internally on the local area network. They are not intended to be recognized on the Internet. The real IP from ISP, instead, can be recognized or pinged by another real IP. The Prestige 310 Internet Access Sharing Router works like an intelligent router that routes between the virtual IP and the real IP.
Posted on Feb 19, 2006
SOURCE:
What is the IP address for my Firestick?
The IP address of an item, unless you specifically assign it one, is done automatically by the router when it connects to the network. This address can be different each time the device connects depending upon what other devices are already connected.
Jan 02, 2016 | Computers & Internet
I need to set my Canon Pixma MX430 to a new internet provider. How do I do this?
You need to change the router settings note the model number of the Router or modem and phone your ISP and find out the settings that need to change. The router uses an internal ip range so you do not need to change the internal ip ranges just the settings to talk with the ISP . Your ISP should be able to guide you through the router settings. The Pixma should not be affected by the change of ISP unless the internal range of IP addresses has been changed. the internal range is 10.0.0.1 to 10.0.0.254 or 192.168.0.1 to 192.168.0.254. you may need to change the email pop server and the smtp server name if stored in the printer for emailing out scanned items. The printer should have a setup CD to set these items
Aug 31, 2014 | Office Equipment & Supplies
Can someone show me how to change my Dell lattitude e5520 ip address?
Your IP address is assigned by your network system.
If you have a conflict with your IP, you can try a ipconfig /release or ipconfig /renew.
At the command prompt type
ipconfig /? for all available switches.
If you are using a cable modem, you would want to reset to factory first.
May 03, 2014 | Office Equipment & Supplies
What is an ip address
An IP address is also known as Internet Protocol Address.It is very important in Internet.Every Internet users are identify by their users using their IP address.IP address is Unique.You can get it from your Internet Service Provider[ISP].
IP address are two types.
There are Internal and External IP address
Internal IP means that your system IP address.
If you want to know your system ip address follow these steps:
Start--->run-->Type cmd
Then command prompt will display.
type ipconfig
then it will display your system IP address
External IP address means that your network IP address.
If you want to know your Network IP address then visit IP-details.com here it shows the details like ISP(Internet Service Provider),IP location,country,latitude,longitude etc..
Mar 15, 2013 | Computers & Internet
Iam having different ips from wan is this mean someone is accessing my network?
You just have Dynamic ip, nothing to worry about.
"Static IP addressing is for one customer on one IP address and Dynamic IP addressing assigns a different IP address each time the ISP customer logs on to their computer, but this is dependent upon the Internet Service Provider (ISP) because some ISP's only change the IP address as they deem it necessary.
If you have Dynamic IP Addressing through your Website Host it means that you are sharing an IP Address with several other customers.
If you are a beginner on the internet, an avid internet user, are entertaining the thought of starting your own website business, are a gamer, use VOIP or VPN there are several things you should know about IP Addressing."
Read more
Mar 21, 2011 | D-Link DIR-600 Router
Diffrent between Dynamic&static ip address
Static IP address is usually a single IP address provided by the ISP to you, which can be configured so that you can run a web server (host web sites etc), or access your home computer from any where in the world ( your computer and internet should be on ).
Dynamic IP address is usually IP address provided by the ISP to your DSL modem / computer (for dialup modems) for that internet session, next day or next time you connect the IP address will be a different one. (usually home internet connections are Dynamic IP based.
In a typical home environment if you have one wireless adaptor and planning for a wireless repeater its better to configure dynamic IP address in the repeater (so that you repeater will acquire IP address from the wireless adaptor)
Dec 09, 2010 | Computers & Internet
How to configar real Ip
Ask to you ISP to provide you public IP.
Apr 08, 2010 | NetGear WGR614 Wireless Router
Lexmark X644e All-In-One has link light, but does not print or ping.
If you have a router or wireless router, these routers assign a standard class C network address ie. 198.168.0.xxx or 192.168.1.xxx behind the real IP address issued by your ISP.
The reason why you cannot ping the print server could be that your computer and print server have different IP address ranges. Eg. the IP address on both the print server and the computer must contain the same first three group of numbers, only the last numbers are different.
Try configure the print server's IP address again.
Feb 12, 2010 | Lexmark X642e All-In-One Laser Printer
I have a linskys EQ-660R ADSL Router and i am trying to make my NAT type open. I've got UPnp and checked all boxes...nothing happened. here i will give u my options on the advanced menu. (Password) (LAN)...
you need to set
wan type to PPPOE for ADSL
ADSL has one IP address coming out of your building to the ISP
How does it connect many internal computers to just one outgoing IP address you may wonder. It uses different port numbers for each computer on the same ip address via a PPPoe connection .
http://searchnetworking.techtarget.com/definition/PPPoE
if still stuck call your isp for help
you will most likely need dynamic IP for the isp ip and DNS /
Jun 17, 2017 | Zyxel P660HW-D1 Router
Will sync but online LED won't work
4 Select the connection type from the Connect Type drop-down menu. ? Always Connected means that Internet connection to your ISP is always on. ? Auto - Triggered by Traffic means your Router will automatically connect to your ISP every time a PC needs to access the Internet. ? Manual - Start in Disconnected means that after re-booting the Router, the Internet connection will need to be re-established manually by the user. ? Manual - Start in Connected means that after re-booting the Router, it will automatically establish a connection to your ISP.
(from http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c02582095-1.pdf )
this sounds like Manual - Start in connected mode will get the ip address and dns settings automatically from the ISP
using adsl on phone line then use pppoe for the protocol
DCHP server has to be set up also and on
The DCHP server ip address range is 192.168.1.20 to 192.168.1.254 with subnet mask 255.255.255.0 and default gateway is 192.168.1.1
pppoe protocol allows the ADSL to connect many computers on the one isp global ip address allocated to your line via using different port numbers to translate the computers internal ip address on the dhcp server through the router.
Jul 01, 2017 | 3Com OfficeConnect Router
Zyxel Prestige 310 (AM406100) Router Logo
486 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Joaquim Martins
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
