Question about Zyxel Prestige 310 (AM406100) Router
What is BOOTP/DHCP? - Zyxel Prestige 310 (AM406100) Router
    Scholar:
  • 130 Answers
BOOTP stands for Bootstrap Protocol. DHCP stands for Dynamic Host Configuration Protocol. Both are mechanisms to dynamically assign an IP address for a TCP/IP client by the server. In this case, the Prestige 310 Internet Access Sharing Router is a BOOTP/DHCP server. Win95 and WinNT clients use DHCP to request an internal IP address, while WFW and WinSock clients use BOOTP. TCP/IP clients may specify their own IP or utilize BOOTP/DHCP to request an IP address.
Posted on Feb 19, 2006
SOURCE:
Jetdirect ex default ip
Usually it it set to pick up IP from DHCP/BootP.
If someone had assigned a fixed IP and it is now unknown. It is better to reset the print server to factory default by pushing the little reset button,
Then check you DHCP server for the newly assigned IP address.
You will need a version of HP Jetadmin or HP webjetadmin to configure this print server
May 13, 2014 | HP JetDirect EX Plus Print Server
Does the SR505n modem have a BOOTP mode? how to set it to BOOTP so a DHCP server assigns the IP (not the default 192.168.1.1)?
I am not quite sure what you mean by a "BOOTP" mode for this modem, but the following link takes you to a downloadable pdf file which is the manual for this modem and others in the range.
http://www.start.ca/files/smartrg505n.pdf
Among other things it shows how to disable the DHCP server aspect of this modem (around page 29 I think) and gives you all the means of getting into the modem's settings and configuration area.
May 07, 2014 | Computers & Internet
IP Address 3200mfp
Dynamic addressing (BOOTP/DHCP)
To have a TCP/IP address assigned automatically by the server, take the
following steps:
1. Press Menu until Network Setup appears on the top line of the display.
2. Press the scroll button ( or ) until "Config Network" appears and press
Enter.
3. Press Enter when "TCP/IP" appears.
4. Press the scroll button ( or ) until "DHCP" or "BOOTP" appears and
press Enter.
5. Press Stop/Clear to return to Standby mode.
Static addressing
To enter a TCP/IP address from your machine's control panel, take the
following steps:
1. Press Menu until "Network Setup" appears on the top line of the display.
Enter.
4. Press Enter when "Manual" appears.
5. Press Enter when "IP Address" appears.
6. Enter a byte between 0 and 255 using the number keypad and press the
scroll button ( or ) to move between bytes.
7. Repeat this to complete the address from the 1st byte to the 4th byte.
8. When you have finished, press Enter.
May 07, 2014 | Office Equipment & Supplies
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
What do I choose for the WiFi network for my ipod touch regarding the IP address - DHCP, BootP, Static?
Should be DHCP as your ISP will automatically set up the IP address for your network.
Jan 09, 2010 | Apple iPod touch
My network HP laserjet 4Vprinter and ESI 2830 pocket print server suddenly gives an error message "No RARP/BootP Server". How can I fix this?
the information in the link is too long to paste but you may want to look at it.
HP Jetdirect and Embedded Jetdirect Inside Print Servers - TCP/IP, Messages on Configuration Page or Self-Test Page
Get the IP address subnet and gateway address of a computer in the same network.
Usingthe LJ5's control panel, setup a static IP for the Jet Direct using thenumbers you got from the Laptop, except change the last number of theIP to one that is not being currently being used. Perhaps adding 5 or10 to the highest number in use.
Here are the steps to configure the LJ5.
1.Press MENU, repeatedly, until the following message appears on thecontrol panel: HP LaserJet 5/5n/5m and the original Color LaserJet: HPMIO MENU
2. Press ITEM. CFG NETWORK=NO* will appear.
3. Press the PLUS button once. CFG NETWORK=YES* will appear.
4. Press ENTER or SELECT.
5. Press ITEM repeatedly until CFG TCP/IP=NO* appears.
6. Press the PLUS button. CFG TCP/IP=YES* will appear.
7. Press ENTER or SELECT.
8. Press ITEM until BOOTP=YES* appears.
9. Press the PLUS button. BOOTP=NO will appear.
o When using BootP or DHCP, keep the setting BOOTP=YES*.
o The BootP or DHCP server will configure the TCP/IP parameters on the HP Jetdirect.
o No other TCP/IP configuring is necessary.
10. Press ENTER or SELECT.
11. Press ITEM. IP BYTE 1 = (value) will appear.
12.Press the PLUS button until the value of the first byte of the IPaddress appears on the control-panel display. By pressing SHIFT and thePLUS button, the value will decrease.
13. Press ENTER or SELECT.
14. Press ITEM to continue. Repeat Steps 11-13 to configure the remaining bytes of the IP address.
15.Repeat Steps 11-13 to configure the subnet mask bytes (SM BYTE 1=),syslog server IP address (LG BYTE 1=), default gateway (GW BYTE 1=),and timeout (TIMEOUT=).
16. Press ONLINE. Print a self-test page to verify the IP settings.
17. If the test page does not show the correct settings, power cycle the printer and reprint the test page.
else: have the printserver reinstalled
www.nls.com/common/pdfs/v307n10.pdf
Nov 24, 2009 | Extended Systems Pocket Print Server
I have a ricoh sp 3300dn and neet to set the ip for it, can anyone tell me how this is done, you can't do it for the printer like most. rick
Configuring DHCP/BOOTP
To enable or disable DHCP/BOOTP, use one of the following methods:
• Web Image Monitor SP 3300 Series: Select Network Settings >
TCP/IP and select DHCP or BOOTP from the IP Address Assignment
Method list.
Creating a Standard TCP/IP port
1 In Windows XP, click Start > Printers and Faxes.
In Windows 2000/Windows Server 2003, click Start > Settings >
Printers.
In Windows Vista, click Control Panel > Hardware and Sound >
Printers.
2 Click Add a printer or double-click Add printer, and then Next.
3 Click Local printer attached to this computer and then Next.
Make sure that Automatically detect and install my Plug and
Play printer. is not selected.
4 Click Create a new port, select Standard TCP/IP Port from the
Type of port list, and click Next.
5 Click Next.
6 Enter the IP address or DNS name of your network printer and click
Next.
For the port name, a default name will be entered by Windows. You
can change it to a more user-friendly name.
7 Follow the instructions on the screen to complete installation.
Now, you can select your printer from the Print Setup dialogue box.
reply if you need more
timothyvdh@gmail.com
Jul 30, 2009 | Office Equipment & Supplies
IP Change
When you see DHCP and it asks you if you want to use it and you say no, it should prompt you for Manual settings. Try it
Feb 23, 2007 | Konica Minolta magicolor 2300DL Laser...
BEFSR81 Server and BOOTP Packet Vulnerability
A flaw in the built-in DHCP server causes the routers to send BOOTP reply packets that contain sensitive information about traffic running through the devices as well as other random information about the router's configuration. New firmware to fix this issue is now available! See information on the Linksys site for upgrading to the new firmware.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Zyxel Prestige 310 (AM406100) Router Logo
801 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Joaquim Martins
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
