SOURCE: On my tv screen I have a vertical white line with some colours
the x or y driver board is failing.best to have a servicer checked out
SOURCE: Vertical black lines. But they are not solid. lg plasma 42pc3dv
This could be a poor connection with the LVDS cable which runs from the main video processing board to the screen, or a fault within the video processor on the main board. Worst case scenario is it could be a fault with the screen itself.
SOURCE: 32LH20RMA problem is half of
Please read or download the info about fail T-CON/LCD panel and see the example of failed T-CON and LCD panel. http://www.scribd.com/doc/25276757/E40951307-TCON-Troubleshooting-10-22-09-OPT PDF download: http://www.mediafire.com/?zzjygannjty LCD panel: http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/ LCD panel: http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
You may want to try to reseat the ribbon cables between the LCD panel and the T-CON board first.
See FIGURE 4 of the download.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series
