Question about Snom 300 IP Phone
Snom 300 We recently had power outages. I have about 3 phones that the display don't work but the phone still does, 2 of the phones have display but they a black box's all across the first line. Thank you, David
  • Anonymous Dec 28, 2008
    my problem is nearly same. but i had over voltage on my phone (24V) my phone display dosen't work but all of lights will turn on.
This is not a solution - we have the same problem too.
have about 70 snoms here and sometimes the display shows only black boxes. a reboot helps then mostly for a while.
telephones are connected by poe or voltage adapter.
never had over voltage and i can't remember on power outages.
Posted on Mar 09, 2010
  • a426889 Mar 09, 2010
    perhaps they will find a solution:
    http://forum.snom.com/index.php?showtopi...
  • a426889 Jan 19, 2011
    the world needs a solution!
How to fix snom 300 because it cannot received calls
Is your phone connecting to a hosted PBX provider or is it connecting to a premise-based IP PBX? Incoming and outgoing calls are usually handled by two separate connections between your PBX and the service provider SIP trunk. Sounds like a registration problem with the SIP trunk. There is nothing you can do from the phone itself to fix this.
Nov 16, 2014 | Snom 300 IP Phone
HOW DO I UNLOCK MY SNOM 300 KEYPAD?
To lock or unlock a Snom 300 keypad you will use the * key. Hold this down until the lock icon appears and hold down again until lock icon is gone to unlock.
Jan 14, 2011 | Snom 300 IP Phone
My snom 300 phone displays NR help please
try resetting the vlan settings if that doesnt work ensure that the default gateway and dns settings are correct.
Dec 08, 2010 | Snom 300 IP Phone
Cannot update firmware Snom 300
It's not really asking for a TFTP update, it's just something that is always checked for in the boot sequence.
As for manually setting the networking configuration rather than using DHCP, see page 14 of the manual at
http://www.snom.com/uploads/docu/UM_snom3xx_V2.2_en.pdf
for instructions on how to bypass DHCP and manually configure your settings.
Dec 22, 2009 | Snom 300 IP Phone
Hi, our phone here snom 300 cannot read the IP address what should be the best thing to fix this? thanks for the immeadiate reply.
How do you mean it cannot read the IP Address. Default is 196.168.254.2. Type that into a web browser and see if it connects.
Oct 22, 2009 | Snom 300 IP Phone
I forgot the password and cannot access the web interface of snom 300, version of firm ware is 7.3.23, I have tried to reset it but it again asks for password. I have tried user name as 'admin' and...
Your phone has two passwords, administrative and http. If you lose http but still have administrative you can fix this through the web interface as your are trying. If both are lost then you will have to reset the phone to factory defaults by using TFTP to update the frimware. Note that this will result in you starting from scratch with your configuration.
Here is the SNOM wiki article containing directions for doing this:
http://kb.snom.com/kb/index.php?View=entry&CategoryID=44&EntryID=32
Jul 02, 2009 | Snom 300 IP Phone
My snom 300 phone rebooted but displays NR
Go to vlan settings, then pick reset . The phone would restart itself and that should do the trick.
Jun 09, 2009 | Snom 300 IP Phone
Can't connect to phone
I bought SNOM 300 and i was unable to connect the router in first go. it was keep saying Send DHCP reqt but nothing was happening. i tried even connecting SNOM 300 dirctly to my laptop but in vain. in last i started receiving message Ethernet cable unplugged.
I reset the SNOM 300 to the factory defaults which solved the problem immediately.
Get to the phone menu "configuration-Reset" and select this option. it will ask for the admin password which is 0000. This will fix the issue. try it.
Jan 23, 2009 | Snom 300 IP Phone
My snom 300 is dialling letters instead of numbers how do I fix
Pick up the handset and press down on the direction button until the display reads "123" instead of "ABC" or "abc"
Oloff
Nov 25, 2008 | Snom 300 IP Phone
Snom 300 IP Phone Logo
557 people viewed this question
Top Snom Computers & Internet Experts
David Payne
David Payne
Are you a Snom Computer and Internet Expert? Answer questions, earn points and help others
