Broan KWH35X NEED TO HAVE IT REPAIED, PLEASE PROVIDE REPAIR DEPOT IN VANCOUVER, B,C CANADA
5 Suggested Answers
SOURCE: hp compag t5000 slim client
Threw the damn thing in the recycle bin.
Posted on Aug 06, 2008
sodeep
  • 3267 Answers
SOURCE: Have checked all connections. Perfect audio. No
The television is actually pretty easy to check if you have a multimeter, T10 torx screwdriver or T10 socket, and a Philips screw driver. First of all remove the back cover from the television, do not worry about the screen assembly, it is flimsy but it is mounted on the inside to not go anywhere when the back cover is removed. Next remove the black voer that is mounted by 4 torx screws, the cover that has the projector part of the engine assembly sticking through, be careful not to damage the black foam rubber that is around the projector head. Once you have those two covers off, unplug the ballast power supply wire which is the white and black wire on the bottom of the ballast, the ballast is the circuit board that is mounted in front of the big fan on the right side Also has two wire coming from the top that plug into the lamp housing. With a multi meter check to see if you have power going into the ballast (TV has to be plugged in and turned on to do this step). If you have power going in then turn the television off and unplug it and and plug the power supply wire back into the ballast. Next remove the lamp which is secured into place with the one screw on the left side. See if you have power coming out. If you have power coming out than replace your lamp. If you do not have power going into the lamp than replace the ballast. If you do not have power going into the Ballast than replace the power supply which is part number DVL-U2830XC good luck in finding that part. If you have power going through to the ballast, and to the lamp and have replaced the lamp than replace the video board Part Number B0001
Posted on Dec 19, 2010
  • 139 Answers
SOURCE: where is a local dist/sales/install/repair in vancouver b.c. canada?
You can contact Omega Research and Development, the makers of Excalibur and K-9, for a local dealer. Omega R&D website
Posted on Dec 03, 2011
  • 885 Answers
SOURCE: hilti repair
Hilti has a repair center in Tulas, Oklahoma with awesome turn-around times. Contact them at 800-879-8000 to get instructions on how and where to send your tool. Most Hilti tools have a maximum cost to repair/rebuild and they can give you that information if it applies to your tool.
Posted on Feb 01, 2012
456 Prior Street,
Next time, please provide the correct address. Dedicated people will assist you when you provide as much information as possible. After some investigative research, here is (I believe) the information you are looking for: 456 Prior St Vancouver, BC V6A 2E5, Canada
Mar 31, 2015 | Computers & Internet
Where would i send my Rolex watch to get fixed in Vancouver B.C
Well I would just ask around and then look around google maps to see if you have any local dealers that can also fix it. You might just be able to go to a regular watch dealer and get it fixed.
Jul 21, 2012 | Watches
I have an old - 10+ yr broan heater fan that went out in the bathroom. Can i get a new broan that would fit the old box in the celing?
yes, you should be able to find one..they may have changed the cover but the box should be the same... i know home depot and lowes carries some broan products... i fnot go online and search broan exhaust fans and see if you can locate... it may take a little searching but if it is the sueare type still common to find.... good luck to you ..
Jan 13, 2011 | Broan-NuTone Heating & Cooling
Where can I buy a new cold water hose? Mine is leaking. I live in Vancouver BC Canada
You can buy a new hose from a number of places. Canadian Tire, Home Depot, Sears. It should be just a standard hose with fittings on the end that are similar to a garden hose.
Dec 27, 2010 | EuroTech Washing Machines
Hi!am wilma new in vancouver angd i need help where to find asus service center here in vancouver.like the address oc any contact #.thanks
There is one Asus service center in Canada. Their contact information is:
Asus Service Center Canada
+1-888-678-3688 (24 hours)
Markham
802 COCHRANE DR, UNIT 2, MARKHAM, ONTARIO, CANANDA L3R 8C9
Aug 03, 2010 | ASUS Computers & Internet
I need to exchange small and large rubber rings and one glass ball in Saeco De Lux Coffee Machine. I am in Vancouver BC where I can get these parts
Saeco's address in Vancouver is:
Boundary Road
Vancouver, BC V5M 3Y7, Canada
(604) 299-7555
They should have parts - then again may only sell them to their authorised repairers - Check.
Jun 09, 2010 | Saeco Vienna De Luxe Espresso Machine
170 people viewed this question
 Grubhead
Grubhead
