Question about Linksys RV016 Router
Port Forwarding On Linksys RV016
Port forwarding was working on this Linksys RV016. The previous sys admin set it up so I could access the IT workstation using the routers public IP address and an assigned port, using RDP.
It looks like this on the router, "setup", "Port Range Forwarding":
IT-RDP[TCP/4200~4200]->192.168.100.46
It worked fine, I could access it from anywhere on the Internet. The IT workstation died, so I put another workstation on that IP address (192.168.100.46), but it does not work.
I can RDP from the LAN, but not from the Internet.
Any ideas?
  • 1 more comment
  • Mike Chase Sep 08, 2008
    That is a different model router. Also, the port forwarding is already set up, and was working fine, but the computer that I was accessing died. I set up a different computer on the old computers IP address, but it does not work.
    The router is allowing access to other ports/IP Addresses
    I can RDP to the computer on the LAN, so it's not a remote access/desktop issue.
    "Check settings on the NEW Workstation (Remote Access grants / Ports assignment)
    And your Computer as it is still looking for the old workstation (RDP is more on the computer's identity not the IP address)."
    What do you mean by "Ports assignment"?
    Guru:
  • 859 Answers
My first thoughts were whether the old PC had XPSP3 or not and if the new PC is different than the old one with respect to XPSP3.
Secondly, this too could affect the profile in your router. The station ID. That is the computer name in addition to the ip address behind the router.
When you want to add a new PC as a replacement station on the network, not only does the IP address need to match , but the computer name needs to match as well.
I'd check those two things, most importantly the XPSP3 which had raked havoc on systems.
Regards,
Worldvet
Posted on Sep 09, 2008
  • Linksys Master
  • 6,487 Answers
Make sure that the new workstation can access the internet and its also setup with the correct static IP and DNS which is the one setup to use the the RDP port that was forwardde on the router. because if you just change the workstation and its not set with the same settings like the old one it wont be working...
Hope that helps..........
Posted on Sep 08, 2008
    Genius:
  • 1,239 Answers
Hi sir..   u will get more details about this.. forums.linksys.com/linksys/board/message?board.id=Wired_Routers&thread.id=18777 thank u sir.  have a nice day..
  • 89 Answers
Common misconceptions:
1. The remote computer MUST be able to install the Active-X Remote Desktop Client that is provided by the Remote Desktop Web Connection (AKA TSWEB).
2. It does not work like GoToMyPc, which works over standard SSL. Remote Desktop works over port 3389 (by default)
3. The purpose of TSWEB is to provide both an Active-X Remote Desktop Client and the proper configuration information to connect to a Terminal Server or Remote Desktop Host.
4. The IIS Server hosting TSWeb does NOT connect to or contact the Terminal Server in any way, shape or form. It's only job is to provide the Active-X Remote Desktop Client and the proper configuration information. The TSWEB can be on the public Internet, DMZ or private network, i.e. makes no difference where it's located.
So to recap:
Remote client connects to the IIS Server -> IIS Server provides Active-X Remote Desktop Client and the proper configuration information to the client computer (if the client isn't already installed) -> Client uses the connection information in the TSWEB to connect to the defined Terminal Server or Remote Desktop Host over port 3389, or whatever port is defined in the TSWEB Configuration.
If the firewall is configured properly, one should be able to connect to the Terminal Server with the built-in Remote Desktop Client. If this doesn't work, neither will the Active-X Remote Desktop Client provided by the TSWEB.
Using an SSL Connection for the TSWEB is pointless, as it offers no added security.
http://www.sessioncomputing.com/security.htm
http://www.sessioncomputing.com/how-to.htm
  • 13,433 Answers
Would need to mach the settings on the server to the old server, something must be a little off. Services on the right ports? Forwarded the right ports?
Think you need to double check everything that they are set correctly, new server firewall blocking?
-check ip
-check ports
-check firewall
the issue is clearly between the server and the router / firewall. I suppose you could even try DMZ if the workstation has protection.
  • 1,879 Answers
No change needed on the RV016 - same IP & Port
  • 118 Answers
I think it would be wie to check that the server is set to allow access from the internet. many routers now have a built in firewall to ensure hack attempts cannot access. I think it may be that its set to allow RDP connections from lan but not from the internet.
    Brigadier General:
  • 5,158 Answers
It's a rather lenghty explanation so please go to this site and follow the instructions...
http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/
Robert
Please rate this solution ... thanks
How do I find my network password
use www.portforward.com use the instructions set for port forwarding. to access your network under admin. its usually admin/admin. being username/password. or admin for password nothing for user. have to open internet explorer and type in ip address and it will take you to a screen to login as administrator.
FixYa Support
Aug 16, 2011 | Linksys WRT160N Wireless Router
Where do i find the port forwarding?
To access the Port Forwarding option of your router, you will need to access the router setup page and from there you will find Application and Gaming tab and there you will see the sub tab port forwarding that is where you can open the port that you need to work behind the router.
Aug 12, 2011 | Linksys WRT54G2 Wireless Router
How do I do port forwarding with one static IP to put my address in my other computers . I need to shadow into with VNC after I install address on my computer is port forwarding marked on the menus are...
Find the IP-address of the computer that you want to accept VNC connections.
Access the router's web-interface.
Find its web-page for "port-forwarding".
Define 'TCP' port '5900' to be forwarded to the IP-address that you found.
Save the settings, and restart your router.
Hopefully, Verizon's FIOS network does not "block" all 'TCP:5900' traffic.
Nov 17, 2009 | Linksys Computers & Internet
Linksys WRT54 GC failed auto port forwarding
check in your pana sonic ipadreses then test in your network can you able ping of ip of cam?
If you can get ping and if you save ip forwarding port 80 to cam ip then check in camera that the settings of "access via interent is enabled" then you cana cces it with cam ip with 80 http port.
Jul 27, 2009 | Linksys WRT54GC Wireless Router
Dont know how to set nat type to open
For you to be able to open the NAT on the router you have to open or forward the application port on it. This router has a graphical interface where you can configure port forwarding, access http://192.168.1.1 (default) username blank and password is admin. Now look for port forwarding and open the port for your application.
Jun 29, 2009 | Linksys Wireless-N WRT150N Router
HOW CAN I OPENIG PORT IN MODEM ROUTER LINKSYS
Try typing 192.168.1.1 into your web browser navigation bar and when it prompts you for a username and password type in this username = Administrator and the password should be: admin if admin does not work then use the password you made when setting up the router. once in the administrator menu look for port forwarding and use the port forwarding page to set up the port you want opened and the ip address of your computerif you need more help i will gladly try my best to walk you through the steps. i must go for now
May 08, 2009 | Linksys WAG200G Router
Port forwarding my wireless interent linksys and netgear
access the admin page by http://192.168.0.1 - If you have the manuals, you should be able to access port forwarding with the admin page.
Manuals are avail. online, as well.
May I ask, what do u need to setup for port forwarding?
Oct 24, 2008 | Computers & Internet
Port forwarding
Hi!
Do you know how to access the router's web ui via Internet Explorer?
If it's the default then follow these steps:
1. Open IE then type http://192.168.1.1 (username: (leave it blank)/ password: admin)
2. Click at Applications and Gaming tab
3. Click at Port Forwarding sub tab
Hope this helps!
May 03, 2008 | Linksys Wireless-G WRT54GS Router...
Port forwarding
try this.
1.Access setuppge of the router through http://192.168.1.1
2.User name admin Password is password
3.Once you are int he setup page on the left side click port forwarding
4.You may need to ask linksys what are the ports needed to open for the PAP2 device that you have aqnd get its IP address.
Apr 18, 2008 | NetGear WGR614 Router
Port Forwarding
Hello Just wondering If both are on the same work Group in the network settings. (Same Name) You probably did that already but if not give it a try and maybe your forwarding will resume and work properly. Hope so. Thanks
Jan 16, 2008 | Linksys EtherFast Cable/DSL Router
Linksys RV016 Router Logo
1,231 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
