Question about Maytag Atlantis MAV6000 Top Load Washer
I have a maytag top load washer (Bravos quiet series 300) that has stoped working. it flashes a code of "F51". It did this before and the repair man opened it up and found small clothing items that had washed over the spinning tub (it does not have an agitator). He put it back together and it was fine. It has done that again now: Question: How do I open it up to get to the items stuck down around the bottom of the outside of the spinning tub?
    Habit-Forming:
  • 146 Answers
Press 2 metal tabs. About 6" from the sides on the front of washer. Plastic ring on top has tabs that need to be disengaged to disconnect the ring. Once ring has been removed the area between the plastic tub & metal tub is accessible. Check for small articles of clothing, like socks or underwear. Inner tub can be removed by: snap up plastic cap (small slot for tool to slip in and pop up). Remove 7/16 nut and remove agitator (may require to be rocked back & forth, sits on a splined shaft). Remove 5 small phillips screws, being careful not to drop any, and pull inner metal tub up (may require it being shimmied back and forth). Removing this tub will give full access to any debris or articles of clothing that may be under it. Please keep in mind that if you're challenged in reassembly
Posted on Jun 16, 2017
2 Suggested Answers
SOURCE:
TheMobilian
  • 8220 Answers
SOURCE: MAytag Bravos Quiet Series 300 washing machine
F-51 RPS senses rotation when basket ought to be stopped.
It is probably loose or worn out.
Video How To
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Oct 22, 2011
What does code F51 mean
Code F51 means there is a problem with the Rotor Position Sensor. This could be something as minor as a bad plug connection. However, there have been many cases of socks or other small garments being flung over the top of the tub rim and getting caught between the metal tub and the plastic tub which contains the water. The "errant" clothing keeps the tub from returning to it's original position thus preventing the Position Sensor from aligning.
Mar 06, 2015 | Maytag Bravos Series MVWB850YW 28"...
What does it mean f 51
http://forum.appliancepartspros.com/washer-repair/131926-maytag-washer-error-code-f51.html
Jan 30, 2013 | Maytag Bravos MTW6600T Top Load Washer
MAytag Bravos Quiet Series 300 washing machine starts to fill, stops and shows code F51
Video How To
Oct 22, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
My Maytag 300 quite series has a code F51 what does this mean?
Hi and welcome to FixYa, I am Kelly The F51 code is a motor rotor position sensor (RPS) feedback error. In other words the control board is not sensing any motor rotation. It is fixable but will result in the replacement of failed parts. (Sensor or electronic control board) The control board is not cheap. Hopefully you only have a failed sensor.
Thanks for choosing FixYa,
Kelly
Feb 16, 2011 | Maytag Bravos MVWB400V Washer
I have a Maytag Bravo top load glass washer and a f51 code. Top wont open and machine has stopped
Defective hall sensor most likely, The cabrio bravos and Oasis machines are all basically the same.
MORE here
Dec 19, 2010 | Maytag Bravos MTW6600T Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
108 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
