Question about Sony KDS-R50XBR1 50" HDTV
3 flashing red lights
Try to turn tv on the indicator flashes 3 times and there is no picture or sound have looked on several message boards no solutions
  • madskillz8 May 11, 2010
    I have the same problem...Ive tried reseating the lamp into its connection several times as well as checking the lamp door switch and the lamp connection switch...all seem fine...any other possible solutions to this error code?
  • 10,594 Answers
3 times flash shows error in Lamp Cover. Please check lamp cover at back of tv and set it properly, if you removed it.
Let me know if
have query.
bye.
Posted on Sep 08, 2008
  • 23 Answers
It's in the owners manual.
3 times means the lamp or lamp door is not secure. Reinsert the lamp until you hear it click and tighten the screw on the lamp door...
Posted on Oct 01, 2008
Samsung ln46c530 lost picture, now won't turn on. Indicator light turns on solid red when on, flashes five times when shut off
The fault is with its main board itself. Troubleshooting to this board is not an easy work to a user can do. It will be best to contact any service technician. google.com/+GopakumarGopalan
Nov 24, 2013 | Samsung LN46C530 TV
I turn on the tv, indicator light flashes green, I hear a intermittent hissing type of sound coming from the back of tv, sort of like a loud scratchy hard drive, the sound repeats 3 times then the...
The fault is with its mother board [main board]. SCL-SDA line short. If you wish to get more details, check the site linked here. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 10, 2013 | Sony KDF-E42A10 42 in. LCD Television
Red flashing light
  1. Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Jul 17, 2013 | Sony Televison & Video
Tv will not turn on when tried on either tv or with remote green light flashes 3or 4 times then turns into red flashing light no picture or sound at all.Have tried changing batteries in the remote and fuse...
Hi.The signal lights red means the primary power of your tv is good and the signal lights green indicate the second power.If the green lights is flashing it means that they have shorted parts in the crt board.Maybe the problem is in the power section of the crt.Need for troubleshoot or repair the crt board.
Jul 03, 2011 | Panasonic Televison & Video
Panasonic projection tv pt-53wx52c no picture red light flashing 3 times have sound
3 times red light flashing is an error code that indicates problem in convergence output section, please check and replace convergence output chips and pico fuse nearby. Chips replacement in circuit board requires soldering work and local tv repair shop will help you if you are not familiar with soldering.
Hope this will help.
Thanks.
Mar 28, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
Feb 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
Vizio P50HDM No Picture/No Sound
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
BRAVIA KDL-V32A12U PICTURE LOSS
THREE Blinks
B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FIVE Blinks
AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
Jun 19, 2017 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Picture & sound shuts off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Oct 06, 2008 | RCA L32WD14 32 in. LCD Television
Sony KDS-R50XBR1 50" HDTV Logo
273 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
