Question about Dell Dimension E510 PC Desktop
Will not start...
I am having some issues with my dell e510, it wont start. I had it in storage for about 3 months, and when i got it out it would not start. All i get is a flashing yellow LED on the front of the tower. After fidling around i was able to get started...only once...then i turned it off to move it into my room and it did the same thing...i have replaced the power supply to no avail. any assistance would be greatly appreciated. You can contact me at camp9250@bears.unco.edu
-Anthony Campisi
  • Dell Master
  • 998 Answers
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Since you replaced the power supply, my guess is that the motherboard has a problem.
Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Posted on Oct 20, 2008
How i can install the new HITACHI HDS721010CLA har drive in to my dimension E510
Hi castanedajes !
Here is a link to the Hard Drive section of the user manual of the Dell Dimension E510. It detailes all of the procedure.
http://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1366406
Best of luck omerk.
Jan 28, 2011 | Hitachi 1TB HDS721010CLA332 SATA2 U300...
Dell dimension wont boot after power outage and stops half way through the boot page
The problem is with the corrupted boot files .In my opinion you have one solution
Steps for solution
1. Download an operating system called ' Linux mint ' which can be installed in the pen drive having minimum 4 gb capacity . Using this operating system you can access the computer .
2. Copy the file and folders to an external storage device (external hard disk, pen drive etc..)
3. Reinstall the operating system ( XP,Vista ,Window 7,Ubuntu etc )
Hope you be successful
Mar 12, 2010 | Dell Dimension E521 PC Desktop
My Dell E510 PC Desktop Does not turn on, the front light is green, but isn't blinking and a 3 and 4 show up. It also peeps a couple of times, but does not boot up.
Manual is here: http://support.dell.com/support/edocs/systems/dimE510/index.htm
Look under Diagnostic Lights. 3/4 is a memory issue. Unplug your PC and open it up. If you have more than one memory stick, remove 1 and then try rebooting the computer. If it still fails, try the other stick instead. You may need to replace both sticks or even just reseat them both.
Mar 08, 2010 | Dell Dimension E510 PC Desktop
The dell dimension E510 powers off and will not stay on
This info is not enough to give you a specific solution. Try this: Press and hold on/off button for 3 seconds. Turn on button, press f8 continuosly to os start menu, choose safe mode, check sleep and hibernation settings, test for malware/spyware, check startups - run msconfig, disable all startups if needed.
Dec 16, 2009 | Dell Dimension E510 PC Desktop
Blinking amber light and wont boot up.
if the power button was blinking amber, unplug your tower, and hold the power button for 30 seconds to 1 minute, to use any excess power stored in the capassitors in the pc. this was told to me by a dell tech, it is a small issue with the 3100=E310, and 5150=E510 Dimension desktops
Sep 24, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
I have dell dimension e510 and i got a steady amber and the 2-3-4 are lit up green. i cant get comp to start up what is up with my comp
see if this will open for you
http://support.dell.com/support/edocs/systems/dim5150/en/sm/tshoot1.htm#wp1114195
look for the
Diagnostic Lights that should give you an idea whats going on
Jun 27, 2009 | Dell Dimension™ E510 PC Desktop
Bios problem on dell dimension e510
At first u need to remove the bios. wait for 5 minutes. then add the battery. start it
Jan 24, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell dimension e510 won't turn on
Unplug the power cable from the power supply in your computer and reinsert it. If you still have nothing, most likely a dead power supply.
Jan 24, 2009 | Dell Dimension E510 PC Desktop
Dell E510 Freezes during Bios Load
u haveto reset your bios wit juper settings it is near cmos set in it 2-3 position then again in 1-2 position .
ten clear all dust from circuit then reaatch all calwe and connectors.
Jan 18, 2009 | Dell Dimension E510 PC Desktop
Dell Dimension E510
A few potential problems:
1. Your CPU fan isn't working, causing your CPU to overheat and then turn off the system
2. Your power supply is faulty
3. A capacitor has blown on your motherboard
Give us more details on your problem so we can figure out what's going on
Jul 27, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension E510 PC Desktop Logo
64 people viewed this question
Alun Cox
