Question about Creative Labs Inspire T7900 Computer Speakers
AUX mode i just bought these speakers, and i tried playing ipod from AUX, but its just playing from two speakers, no other speaker is sounding? is it like that? it does not support 7.1 or 5.1 in AUX?? need urgent rep, thank you
    Problem Solver:
  • 11 Answers
This will not work the speakers need something to decode a surround signal which is why they have so many connectors to the computer.
Aux only supports the stereo signal from example an Ipod
Posted on Sep 13, 2009
Alpine Ipod Interface Not Working Correctly
Sometimes those 3.5 mm stereo connectors don't work right. If a little wiggling and unplugging/replugging does not restore the sound there may be a connector that is defective
May 05, 2013 | Alpine Kca-420i Kca-121b Ai-net3.5mm Mp3...
Hi I am having problems with my Panasonic SA-AK200 stereo system when in AUX mode. What happens is when I play through AUX mode The Sound only comes through One speaker usually the right one but when on cd...
Looking at your question, it appears that the problem is not always on the same channel (right/left). This makes me wonder if the problem is the source or the cables you are using. The easy way to test this is to connect everything, check which speaker is not working, then swap the left and right cables at the aux jack. If the same speaker does not work, then it is a problem with the SA-AK200. If the problem switches to the other speaker, the SA-AK200 is not the problem and you should try replacing the cables or suspect the source (whatever you are trying to connect to aux) is at fault. If the SA-AK200 is the problem, I would suspect bad solder connections at the input jacks. Good luck
Dec 12, 2017 | Panasonic Audio Players & Recorders
My E350 station wagon came with a cable for my ipod but when I plus the ipod into the cable in my glove compartment, the audio plays from my ipod but not through my speakers
There are various types of Ipod cables for cars. Most of them use FM transmitting mechanism whereby you pick an FM station and the music will be transmitted to said station or the type which act as an external auxiliary. With the external auxiliary you have to change the car radio mode to aux. As long as the cable is properly connected and not in bad shape then if you change to auxiliary mode it should play on your car speakers. Try this option and get back to me.
Hope this solution has been helpful?
Feb 10, 2011 | USA Spec iPod Interface Mercedes Benz...
My daughter has an Iwantit ipod speaker model IW900 and it works/sounds fine with her ipod usind the dedicated ipod connector. On the the back of the speaker there is an Aux in socket. She would like...
It took me a while to figure this one out. Firstly plug your device in to the aux socket and play some music so you can hear when it's correctly switched over. Turn on the iwantit using the switch at the back then press the play button once, you should see the lights on the buttons go brighter. Now press the play button again, this time holding it down for exactly 3 seconds. When you release the button you should be in aux mode and you should hear your music playing. Hope this helps, it took me about an hour of faffing around before I finally figured it out.
Aug 16, 2010 | Audio Players & Recorders
No sound from my Pure-Fi Express plus into my 4th gen Nan Ipod
Hi, while your pure express plus you just purchased is not playing out any sound is because, the speaker that enable you to play the sound when you play music through the ipod is faulty and it needs to be replaced with another one for it to function properly again.
After changing the speaker that is faulty with a new speaker, you can now start enjoying the music again through the internal speaker.
Take care.
Apr 14, 2010 | Apple iPod nano
I dropped my On Stage micro and now when my iPod is docked and the on stage is powered on their is a LOUD buzzing sound from the speakers. The auz-in mini plug still transmits sound and music fine, only...
I have had then same exact problem, except I had an ihome. I've done research on it for a way to fix it. basically what I have come to find is that the plug for the ipod is just cheaply made, and that there is basically no easy and cheap fix for it. However as long as you have an aux-in you can just simply avoid the problem by buying an eighth inch to eighth inch cord so that you can just simply plug you ipod into the aux-in. As long as you have the ipod plugged into the the aux-in, and aux mode is selected, it should play your music while charging.
Sep 21, 2009 | JBL On Stage Micro Speaker Dock for Apple...
Only 3 speakers play with ipod all other is ok
Are you playing your ipod through the stereo with a cable in aux mode? If so check your fader and balance settings when in aux.
there would be no other reason except for speaker wiring check and make sure there is no auxiliary wiring that may not be hooked up.
if it's not settings, then it's wiring, unless your stereo has an internal problem in the auxiliary circuit.
May 27, 2009 | Apple iPod MA446LL/A MP3 Player
Can't get into AUX source
Are you sure it is an AUX input? According to the Manufacturers Specs, the AUX, is an optional accessory. There is a Pre-Amp connection, which would be an output, hence causing the problem you are having. Best of Luck.
Sep 13, 2007 | Kenwood KDC-MP232 CD Player
Creative Labs Inspire T7900 Computer Speakers Logo
157 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
