Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Defrost Mode Hello My Refrigerator has an automatic defrost, I have a problem now where the refrigerator went into defrost mode and the refrig side temp says 45 and the freezer side says 33. It's been two days now and shouldn't the setting go back to the orginal freezer and refrigerator settings? I tried unplugging the power to the refrig and waited over 2 minutes before plugging it back in. Settings went back to the same as stated above. Also if I try changing the settings down to 0 degrees for the freezer it will change but then after 3 seconds the freezer setting goes back to 33
  • 1 more comment
  • 2pojeff Sep 09, 2008
    I vacuumed out the condesor coils but still same problem, but freezer temp has come down as low as 22 degrees, I have it set for zero degrees. Also the face plate that the freezer door gasket mates to is super hot.
  • 2pojeff Sep 12, 2008
    I have a service technician scheduled for Monday the 15th of September. I will reply with a comment as to what they find. Thanks for your helpl
  • freezermad Oct 26, 2008
    the freezer defrosts, then works for another day, then defrosts again. This has happened for three Days.
  • 126 Answers
YOU MIGHT HAVE A GAS LEAK ON THE UNIT.OR THE COMPONENTS IN THE FREEZER COMPARTMENT ARE NOT WORKING WELL.BEST YOU GET AT TECHNICIAN TO HAVE A LOOK.GOODLUCK.MOHAMED
Posted on Sep 12, 2008
Where is the defrost switch on 106.53592300
Not sure there is a manual defrost switch. Look at the link below for defrost switches for your model. On some refrigerators, if you set the temperature switch to off and unplug then plug in the refrigerator it will force the defrost mode; then unplugging and plugging again will reset the mode.
Oct 20, 2014 | Kenmore 57029 Side by Side Refrigerator
Freezer side works fine, Refrigerator side is too warm
Hello.
The leading problem when freezer works yet the refrig. section doesn't get cold is going to a problem with a automatic defrost system defect. Do ya see a bunch of frost inside of the freezer on the back wall?? if yes ya do see that frost build up ist defiently not defrosting and this tip i wrote covers what to check when it doesn't defrost http://www1.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Oct 04, 2011 | Jenn-Air JCD2389G Side by Side...
My jcd2389des freezer is working fine but the refrigerator isn't cooling properly
Hello Sharleen,
GENE
Oct 03, 2011 | Jenn-Air JCD2389G Side by Side...
Is my refrigerator running properly? Refrig. went into defrost mode about 6-7 hours the other night. Unplugged and pugged it back in and it seems fine. Now, the refrig is performing defrost every 1-2...
if its a timer controlled defrost it will defrost every time the timer gets to the spot where it cuts off the compressor and activates the defrost circuitry,if its an "adaptive defrost type system" then it depends on the amount of times the door is opened,the amount of frost on the evaporator coil,etc and is determined by sensors in the units walls
Mar 08, 2011 | GE Refrigerators
Why does freezer automatically defrost and then stay in defrost no matter what we do?
The defrost timer/control board whichever you have is sticking in the defrost mode....replace it...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 02, 2010 | GE Profile PSW26P Stainless Steel Side by...
Automatic defrost not working, but manual is?
Yes if the heater and defrost thermostat are good then the problem is the control board.
Sep 04, 2009 | Amana ARS266ZBS Side by Side Refrigerator
Amana SXD23VE quit cooling 3rd time
wel there are 2 thermostats in this unit, a defrost thermostat(very common to go bad) but would mainly affect refig sect and the freezer only slightly, the other is a cold control thermo affecting both freezer and refrig, if this goes bad you get NO cooling, looking at the diagram for the refrig it has a defrost timer under the righthand side of the kickplate, i would try advancing the timer, with a screw driver you can manual turn the plastic gear on the timer( i believe on yours its problaby a pink knob. its possible that the timer has gone bad and the unit is stuck in a defrost mode, try turning it ever so slightly, youll hear it "clicking" as you do , it should "snap" into arun mode and everthy kick on for it is stuck in defrost(worth a try anyway)
Oct 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Beeper
The defrost timer is most likely stopped on defrost mode,the refrigerator is trying to cool but cannot bring the temp down because of the defrost being on all the time.replace the defrost timer.If I can help,let me know.
Oct 20, 2008 | Viking 42 in Built In Professional...
GE Profile SxS Refrigerator wont defrost after new heater installed
If one coil was burnt out and you replaced the heaters and defrost terminator switch I would recheck the continuity through the defrost heaters. You can do this with an Ohm meter with the refrigerator unplugged. If you had an open coil in one of the heaters you did not have to replace the thermo disk. If you have a complete circuit through the heaters try using the old thermo disk. If you have a meter you can check the voltage from the heater connection on one side to the inlet side of the thermo disk with the refrigerator running in the defrost mode. You should read 115-125 Volts on the meter. This reading tells you that the defrost timer is supplying power to the heater circuit.
Apr 30, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Ge Profile refrigerator
Yes your refrig is not defrosting automatically. You can start by removing the shelves in the freezer than removing the rear panel (the panel that is frosted half way). Use hair dryer to defrost ice from coil. This will restore your refrig temporarily. Your refrig has a pretty advance defrost system and is not easy to test. If you have a meter (volt-ohmmeter) i can help with diagnosis.
Oct 10, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
169 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
