Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Posted on Aug 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a part for my Ultimate Care II LSQ9549L Top Load Washer Problem
Anonymous
Level 3:
  • Whirlpool Master 3,361 Answers
  • Posted on Aug 24, 2011
Anonymous
Whirlpool Master
Level 3:
Answers
3361
Questions
Helped
1028942
Points
10654
Go to www.appliancepartspros.com and enter your model number,select your model then locate your part on the diagram. Then order your part from them.
Whirlpool Ultimate Care II Washer will not drain
bad lid switch,open the lid a few inches and close it down,if you do this a few times and don't hear a clicking sound the switch is bad.
http://www.youtube.com/watch?v=PZAbg9uftos
2helpful
Replace belt for model CJ4732600
that model number you sent isn't a good model number,your problem is under Whirlpool Ultimate Care II LSQ9549L Top Load Washer,if this is your washer there isn't a belt in it,it has a motor coupling,let me know if this si your washer and i can help you out.
Whirlpool Ultimate Care II LSQ9549L Top Load Washer were is the drain filter
Hi.
With Whirlpool top loader models the pump is located at the bottom of the appliance. The pump is accessed from underneath the appliance. Some model may have an access panel at the back. I think that with the Ultimate Care models the pump must be accessed from underneath. Here a repair video.
Here parts and diagrams.
Standard washing machine hoses dont seem to fit my Whirlpool Ultimate Care II washer? Do I need an adaptor of some sort....
The Whirlpool Ultimate Care II is an American top loading washing machine and requires different hoses available from Whirlpool.
Washer leaking in floor, appears to be coming from a clear/white plastic piece near the pump, Ultimate Care II top Load Washer
it's the pump housing anot an exspensive part and for my washer removing it was as easy a poping 2 black metal clips
2helpful
How do I separate the 2 agitator parts on a Whirlpool LSQ9549L?
that part snaps in you need a long screw driver to free the snap on the inside where the nut is don't pry on them too hard you'll brake them
Whirlpool Ultimate Care II LSQ9549L Top Load Washer leaves water
Water pump must not be running. Check if the belt is not broken or came off or the dial switch is bad or the clutch is not engaging.
Good luck
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
