Question about GE DVL223GB Gas Dryer
DBXR463EB1WW I have a GE dryer, model above, has stop. It will not turn on. It is not the switch in the door nor is it the fuse in the fuse box. Help????
  • 1,543 Answers
If the dryer does not make any noise, the most likely cause is a broken belt (WE12M29 for a DBXR463EB1). If the belt breaks, there is a switch near the belt tension arm that cuts power to the dryer so the dryer will not heat without the motor running. (UL requirement) If belt is OK there are host of other potential electrical areas to check, so then better call a service tech.
Posted on Sep 08, 2008
My ge dryer DBXR463EB1WW stopped running. The power is on
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 30, 2011 | GE Dryers
I have a GE dryer, DBXR463EB1WW for the model. The laundry gets warm but does not dry. Any idea what may be the issue
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
Mar 04, 2011 | GE Dryers
Dryer doesn't start
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer or control board
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Oct 04, 2009 | GE Dryers
Dryer won't start, timer makes clicking noise drum sometimes begins to turn but does not come on.
3. Thermal fuse
**The most common issue here will be a defective Thermal fuse, but in this case, the door switch may be the culprit. Check all the areas stated above to cover all suspect issues
Sep 30, 2009 | Kenmore 73952 Gas Dryer
Will not turn on
The dryer would not start with a broken door switch. Replace the door switch if found defective.
3. Thermal fuse
4. Timer
Jul 10, 2009 | GE DWSR463EGWW Electric Dryer
Will not start up. It has power to it.
Check the following to address this issue.
Thermal fuse
If all the above inspection check out ok and, the door switch or actuator is functional, replace the timer or control board.
Jun 18, 2009 | GE Dryers
My dyrer doesn't turn on. It just stop working.
Thermal fuse
Timer
Jun 06, 2009 | Maytag MDE2600 Electric Dryer
Dryer Starts... Then Stops!...
Sounds as if you have a bad motor. That humming is a big give away. Unless its less than 3 years. I would replace it.
Oct 29, 2008 | GE DBXR463EBWW Electric Dryer
My roper dryer stopped working
right above the door where it closes, there should be a door switch actuator, although your closing the door it might not be activating door switch.
Feb 24, 2008 | Roper REX4634KQ Electric Dryer
GE DVL223GB Gas Dryer Logo
526 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
