Question about Canon Office Equipment & Supplies
HOW TO PRINT SPECIFIC APPLICATION TO A CERTAIN PRINTER?
I'd like to know how to setup certain application to be printed to specific printer. For example, I need to print Word doc to printer A, then Quickbook report to Printer B, etc. Is that possible?
  • Peter Bdm Sep 09, 2008
    hi, checkitright
    Yes, I've been doing that for years now. I gotta select printer back & forth, if I want to print a certain file. Do you think it's time consuming to do the network setup for specifying printers accordingly? What tools/ applications do I have to use? Thx again for your time & advice.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
If you have a network system and depending on the application you are using then Yes it's possible to do, but it's not easy, you need an IT person to set it up.
Some App's like Meditech, Kronos etc.. will do it, and even then you need tospecify the printer NAME
Otherwise you will have to choose the printer in the :
File
Print
(choose printer)
then print each time
Posted on Sep 09, 2008
  • CheckitRight
    CheckitRight Sep 09, 2008
    depends is this a big office/business or home app.? I'll try and see if there are any programms specific to what you are doing, but usually it's mainly used in big business's like hospitals and corp. that have over 100 people.
My hp 6540 won't print pictures in a document
HI,
Change settings from an application for current jobs (Windows)
To change the settings
1. Open the document that you want to print.
2. On the File menu, click Print, and then click Setup, Properties, or Preferences.
(Specific options may vary depending on the application that you are using.)
3. Change the settings that you want, and then click OK, Print, or a similar command.
More info read page no.33.
http://h10032.www1.hp.com/ctg/Manual/c01325559.pdf
Thanks,
HP Printer Support
May 30, 2014 | HP DeskJet 6540 InkJet Printer
I have just purchased and installed a J3600 Officejet printer. How do I get it to orient the print for a #10 envelope, which has to be fed in lengthwise?
You'll have to choose "#10 Envelope" as your paper size in whatever program you are printing from.
Then pick "Landscape" in the print options menu when you go to print on the envelope.
Apr 15, 2008 | Office Equipment & Supplies
I am trying to print something in color using my canon pixma mp640. i have made sure all of my ink levels are good and that my setting on both the computer and printer are set to color. but it is only...
If you are certain that your printer online properties indicates color printing and you can get 'test print' in color (via Printer properties or Printer built-in menu), I would first check that your application is not overriding the default settings (e.g. such as proof/draft mode printing in mono or B&W) or try another application.
If no applications won't print in colors, I would try to re-install the Printer Drivers specific to your windows version.
Sep 21, 2011 | Canon Office Equipment & Supplies
79.060e on HP5100 laser printer
The printer detected an error. The numbers (xxxx) indicate the specific type of error. Turn the printer off, and then turn the printer back on. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears when you use a certain software application or print job, contact the software vendor for assistance.) If the message persists, try the following: 1. Cycle the power. 2. Reseat or replace the interface cable and cycle the power. 3. Download the latest firmware image (if available-the firmware download is not available for some printers) from http://www.hp.com and use HP Jetdirect or another appropriate utility to update the printer. 4. Remove the DIMMs one at a time and cycle the power. 5. Try using the parallel interface, if possible. 6. Remove the EIO cards from the printer and then perform a cold reset. 7. If the error persists, replace the formatter.
Aug 15, 2011 | HP LaserJet 5100tn Printer
Epson 600 stuck on making 3 copies,no matter if i set it for one copy
Select Basic Print Options After opening your file for printing, open the Print window to select your print options. 1. Open the File menu and select Print. 2. Click the arrow to expand the Print window, if necessary. wf600.1.86.1.jpg 3. Select EPSON WorkForce 600 as the Printer setting. wf600.1.86.2.jpg 4. Select the copies and pages settings for your print job. Note:
If you don't see these settings here, check for them in your application before printing. 5. Select page setup options. Use these options to select the paper size, orientation, and scale. Note:
If you don't see these settings here, check for them in your application before printing. For example, you may be able to open the File menu and select Page Setup. 6. Select any settings that are specific to the application you're using. For example, if you're printing a photo from Preview, you see the application settings shown above.
If you have any doubt in this pls click here
Jul 26, 2011 | Epson WorkForce 600 All-In-One InkJet...
Trying to print a document error 49.4CO2 comes up. What does this mean?
Hi as you will see I have cut this from the manual its not very specific
I hope this is of some help
Ian
Description Recommended action
49.XXXX
PRINTER ERROR
To continue
turn off then on
None A critical firmware error has
occurred that caused the
processor on the formatter to
abort operation. This type of error
can be caused by invalid print
commands, corrupt data, or invalid
operations. In some cases,
electrical noise in the cable can
corrupt data during transmission
to the printer. Other causes
include poor quality parallel
cables, poor connections, or homegrown
applications. On rare
occasions, the formatter is at fault,
which is usually indicated by a
79 Service Error.
1. Press CANCEL JOB to clear the
print job from the printer
memory.
2. Turn the printer off and then
back on.
3. Try printing a job from a
printing a different file. If the
message appears only with a
4. If the message persists with
different software applications
and print jobs, disconnect all
cables to the printer that
connect it to the network or
PC.
5. Turn the printer off.
6. Remove all memory DIMMs
or third-party DIMMs from the
printer. (Do not remove the
firmware DIMM in slot J1.)
7. Remove all EIO devices from
the printer.
8. Turn the printer on.
9. If the error no longer exists,
install each DIMM and EIO
device one at a time, making
sure to turn the printer off and
back on as you install each
device.
10. Replace a DIMM or EIO
device if you determine that it
causes the error.
11. Remember to reconnect all
cables that connect the
printer to the network or
computer.
12. If the error persists, replace
the firmware DIMM.
13. Replace the formatter and
calibrate the printer. See
Calibrate now (HP Color
LaserJet 5500 models only).
Mar 17, 2011 | HP LaserJet 5550 Printer
49,4c18 error
49.XXXXX ERROR
A critical firmware error has occurred.
1. Turn the device off and then on.
2. Try to determine whether the error occurs intermittently, while printing, or when turning on the device.
3. If the error appears while printing, determine whether it occurs when printing from a specific computer, a specific application, or a specific file. If all other computers, applications, or files
can print without the error, then the problem may be only within one print job or computer. Make sure the computer has the most current printer drivers, or use a generic printer driver.
4. Go to www.hp.com/support/LJP3005. Click Download Drivers and Software. Check for the latest firmware image version at the bottom of the page. If this firmware image is newer than the
one installed on the device and the device can receive a firmware update, download the newer firmware upgrade.
Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
6. If the message persists, contact your HP Support.
Feb 22, 2011 | HP LaserJet P3005n Printer
Error code 49.4c18
49.XXXXX ERROR
5. Try printing a job from a different
assistance.
HP Support.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 21, 2009 | HP Office Equipment & Supplies
Won't print error ''79 service(01BF)''
You didn't list a model, but here are some possible causes:
** could be "font" related especially if it's an older printer years. Does it happen specifically with certain PDF's and Word docs are ok? If so, there's probably nothing to do, but upgrade printer
  • Software/drivers, Memory PCA's, Font-Macro-Personality Cartridges, option I/O Cards. Defective toner cartridge in the Laserjet 4 Plus only. Remove any accessories (font cartridges, memory PCA's, SIMMs, etc.) plugged into the formatter card and try again. If the problem persists and is application specific, verify proper setup with application vendor.
  • Defective Formatter PCA
* Please rate my solution :)
Mar 30, 2009 | HP Office Equipment & Supplies
Crazy characters start to print when printing from pdf doc or certain websites
I understand that the printer is printing garbage when you are trying to print from internet.
Please follow the below given instructions to resolve the issue.
This issue can occur if the data send from the application from which you are printing, is using the PC-8 character set. This will produce a smiley face or garbage charters each time an unsupported escape code is sent by application. To know the character set, please contact the manufacturer of the application.
Also, you can follow these steps to disable the power managment in the comoputer.
1. Right-click My Computer, choose properties
2. Click Hardware tab, click Device Manager button.
3. Click the + next to Universal Serial Bus Controller.
4. Right-click USB Root Hub, choose properties.
5. Click Power Management tab.
5. Uncheck the option "Allow the computer to turn off this device
to save power.
6. Click Ok.
If the issue persists, follow the instructions from the below given weblink to resolve the issue.
Here is the web document:
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=bpu01105&cc=us&lc=en&dlc=en&dlc=en&lang=en
Just copy and paste the entire link into the Internet browser's address bar and press enter.
This should resolve the issue.
Regards,
Lawrence
Nov 13, 2007 | HP Photosmart C6180 All-In-One InkJet...
56 people viewed this question
old marine
old marine
Corne Viljoen
