Question about Sharp R-1480 Microwave Oven
Microwave doing lightning
When hitting , suddenly the are lightning and on the ceiling of the microwave you can see flushes.
What is causing it ? Can it catch fire ? how to fix it ?
  • siga Sep 09, 2008
    Thank you. it looks you are right. the waveguide is burned, and i do need to replace it.
    It is Sharp R-1480. please tell me where can i get new Waveduide >
  • Sharp Master
  • 9,098 Answers
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
Please write back with your brand and model number if you need further help.
Posted on Sep 09, 2008
  • William Miller
    William Miller Sep 10, 2008
    The best place to order Sharp parts is Tritronics.
Why did it catch on fire?
Any flaws in the painted surface on the inside of the unit will cause a spark and that generates heat. Examine the surfacecor any exposed metal. You have to use special paint to resurface the inside.
Nov 15, 2015 | Microwave Ovens
Microwace noise coming from top and flashing
dont use the microwave until you retrieve what dropped inside when you removed the port. The grinding is most likely a foreign object that is hitting the moving parts of the microwave and causing sparking. It can catch fire
Mar 09, 2014 | GE JVM1650 1000 Watts Microwave Oven
House was hit by lighting and now my microwave wont work
It is likely your microwave was hit by a power surge associated with the lightning strike.
Jan 14, 2013 | Microwave Ovens
My emerson microwave #mw8999rd shoots out fire from a silver piece of cardboard thats on the righthand inside of my microwave oven. whats with that?
There is electrical problem in your microwave heating circuit. This is a fire hazard and you should stop using this microwave and unplug from the outlet. This is not something you can fix and the fuse does not protect your system anymore. The best choice is to purchase a new one and throw this away.
Dec 06, 2011 | Emerson Microwave Ovens
What caused this to catch on fire?
its the grease that has got into it replace it and allways keep it clean
Dec 06, 2011 | Frigidaire Microwave Ovens
MY MICROWAVE KEEPS GOING WRONG
Hi well 4 and they cannot fix it then ask for your monet back and buy somethig else if it cannot be fixed after 4 times then there is something very wrong with this
Jan 23, 2010 | Whirlpool Max 14 Microwave Oven
My microwave is dead following a lightning storm M406 01 Can this be fixed
If it just blew the inside fuses yes if your power line was hit by lightning it may be toast but need the model number to tell you where the fuses are.
Aug 26, 2009 | Jenn-Air Microwave Ovens
It catches on fire, through the center turn table.
NOTHING in a microwave should ever be on fire. Depending on the damged cause by even a small fire, the repair may be involved and costly. Inspect stirrer motor by removing bottom of microwave with power off. Note damage and replace stirrer motor and wiring harness as needed along with turn table drive block. Check to make sure all connections with all wires are sound with no exposed copper wires or shorts of any kind. Test always using a cup or bowl of water.
Jul 02, 2009 | Microwave Ovens
Roper microwave caught a paper towel on fire.
Why is this even a question?
Of course a paper towel can get hot enough to catch fire in a microwave. In addition, anything not specifically identified as microwave safe can melt, deform, crack, chip, spark, catch fire, explode, etc...
This is not a microwave problem.
Mar 01, 2018 | Microwave Ovens
Sharp R-1480 Microwave Oven Logo
626 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
