Question about Memorex iMove Mi3005-BLK Docking Station for Apple iPod
Battery light blinking when ac adapter is plugged in
I have had my MI3005 for about 4 months. Today I went to turn it on and the battery light is blinking. It is plugged into the wall so I do not understand why it will not play my ipod and it is acting like it has no power going to it.
  • Anonymous Dec 13, 2008
    I have the same problem. It started doing this gradually. The battery sgn would blink in the right-hand corner, and then 5 minutes later it would play. Now it takes 2-3 hours in order for it to play my docked iPod. I don't what the problem is, and I have no batteries to play it with.
  • Anonymous Feb 19, 2009
    same here. didn't understand how a battery is needed when it's plugged into the outlet...tried another outlet, but to no avail. does it mean the adapter needs replaced?
2 Suggested Answers
SOURCE: My ihome won't work
I wish I had a solution but I have the same problem. I'm thinking it is junk.
Posted on Dec 12, 2009
2 months ago ive bought new charger...cause there was a fault with my previous one. It might also be a socket on laptop, so ive fixed both of it!but in the recent time,something went wrong...my charger...
Turn everything off. Take off the battery. Connect the ac adapter and turn on your computer. If it works with the ac adapter connected and your battery off then you have a defective battery.
If it does not work then it's either your ac adapter or your dc jack inside your computer. Try a different ac adapter at the store you bought the battery and you'll know if your adapter is bad. If it works with another adapter then exchange the adapter again (I know, I know, I've been there). If it does not work with another adapter then you're back to the dc jack but at least you'll know for sure.
Make sure that whoever is replacing the dc jack is good at soldering and replaces it not just solders the same one back on. Don't forget the shield to the dc jack. Good luck!
Oct 16, 2010 | Computers & Internet
Laptop battery not charging wanna know how to run without battery
The problem you described here shows that, the case is not likely to be a battery problem, but the laptop AC-Adapter (Charger) problem, because, the red light you are seeing shows that your battery has rundown, and even when you plug-in the adapter to AC, it still blinks red, showing that the AC-Power is not charging it. I would suggest that you get another Laptop AC-Adapter (The Charger), or try it with a friend's own first, then you'll see that the problem might not be with your battery but your AC-Adapter
Jul 09, 2009 | ASUS Computers & Internet
No response
First follow procedure to try to reset the power.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
May 23, 2009 | Acer Computers & Internet
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Feb 01, 2009 | Dell Inspiron 1501 Notebook
Macbook pro start up problem
First remove the battery, then plug it into your AC adapter. Hold the power button for 5 seconds or until you either hear and beep or the activity light on the front of your laptop lights up. Start up normally.
Aug 02, 2008 | Apple MacBook Pro Notebook
Removing battery
If there is a CMOS battery it should be replaced but it could the AC adapter might need to be replaced.
Jul 20, 2008 | Computers & Internet
Laptop won't turn on
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Screen went black
plz try by resiting the ram, if the problem persist then you have problem in display adapter,send it to the vendor from whom you have bought
May 16, 2008 | Compaq Presario 700 470024-192 Notebook
Screen went black
Hi, could be anything to do with video. Might be the on board video card or its memory. It is also possible that your display lost its back lite and you just can see the display. Try turning the laptop on normally and let it run for a while. Try tilting the display left right up down as if trying to gaze at the inside of the display. If you can see faint traces of your desktop then it is definitely the back lite, if none then something else is at fault. Either way you will have to bring it back for repairs or replacement. You can also try checking the memory by sliding out the panel cover at the bottom of the casing. There might be a screw or two locking the cover panel in place. Try wiggling the memory a bit, might have loosen up somehow. If still a no go, then perhaps you're really better off sending it back for repairs/replacement. Hope this works out for you. Pls post again how things turn up. Good luck and kind regards.
Jul 29, 2007 | Acer Aspire 3680 Laptop
Memorex iMove Mi3005-BLK Docking Station for Apple iPod Logo
697 people viewed this question
Top Memorex Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
