Question about Panasonic Vacuums
We have an MC-3003 vacuum cleaner which keeps cutting out. We've changed the bag, but the problem still occurs with a new bag fitted. Could it be an electrical fault and is the machine repairable?
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: How to change belt on Panasonic MC-E464 vacuum cleaner
Remove the bottom plate, the belt goes fron the brush rol to the motor shaft or pulley.
Posted on Feb 23, 2008
reddevil6
  • 1673 Answers
SOURCE: miele vacuum cleaner not working properly
Is the suction low or ok at the vacuum without the hose attached? If it is ok, then there is a clog in the hose. If it isn't, then check filters, is the speed variable, is the contol set too low. Could be a bad motor, running too slow.
Posted on Mar 06, 2008
reddevil6
  • 1673 Answers
SOURCE: My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
Posted on Mar 22, 2008
reddevil6
  • 1673 Answers
SOURCE: sebo x5 vacuum cleaner
The full bag light comes on when it is getting full or a blockage in the hose or the dirt inlet by the brush roll. Other then that, there is a circuit board called the computer controller, part #5740ER and is giving you a false reading and causing a shut down.
Posted on Jun 22, 2008
ukvacfan
  • 328 Answers
SOURCE: Panasonic MC-E468 vacuum cleaner loss of suction
HI If the cleaner is loosing suction make sure to check all inspection tubes and the dirt channel hoses after the spinning brush. Also check the main hose for any clogging. One of the worst faults of this model is clogging hoses. Hope that helps you.
Posted on Feb 27, 2009
How to change the belt
usually reading the directions helps .
Jul 27, 2015 | Kenmore 6 Canister Type C Sears Vacuum...
Panasonic mc 6220
To open a Panasonic MC 6220, pull quite firmly (but not enough to break it) on the vertical wine molded handle on the front of the vacuum cleaner. It sits between the 3 power selections buttons, and the window that shows how full the bag is. It takes a U3 bag - remove the orange/red mounting bracket from the wall of the vacuum, and then from the bag itself. Make sure you mount it properly on both (and the bottom of the bag so it fills completely) to avoid any dust leaking out. Good luck! This is a fabulous vacuum and lasts a long time, if you maintain it.
Aug 24, 2014 | Vacuums
How do you take apart electrolux canister vacuum #2100?
ok, you need to bypass the auto shut of. Put the vac on it's side and pull off the sliders on both sides.Carefully pull machine apart.lift the front of the piece that hold you bag.Underneathe there is a clear tube plugged in to a round thing on switch area.Simply pull the tube out of the rouind trhing.This will allow you to fillthe bag without shut dow.Just make sure your bag doesn't get too full....Chris
Jul 14, 2014 | Electrolux Canister Vacuum Cleaner Motor,...
My sebo cleaner keeps almost cutting out but comes back on again after a couple of seconds. I.ve checked for blockages and changed the bag and filters.
Sounds like a bad sensor or a possible loose connection electrically. If you are very handy with tools you could try taking things apaet but a dyson is expensive nso I would leave it to the pro's and take it to the local used vacuum shop. They give the best advice in these situations.
Oct 07, 2010 | Sebo Vacuums
Feb 27, 2009 | Panasonic MC-E583 Bagged Upright Vacuum
Miele Revolution 600
This is a problem with the hose, and unfortunately it will require replacement of the entire assembly.
The SES-125 hoses produced in the general vicinity of late 2002 had a tendency to start building up static and kicking the motor off after a few years. The problem was rectified, and the more current hoses do not have this problem.
Head to your friendly neighborhood Miele dealer and get a new hose, and this problem will not occur again.
-R
Aug 27, 2008 | Miele Revolution 600 Bagged Canister...
Part numbers for washers and end caps of vacuum agitator brush
The part numbers for the washers and caps can only be found if you know the agitator brush number.
Mar 28, 2008 | Panasonic MC-V5745 Bagged Upright Vacuum
Vacuum shooting out dust
i dont know what kinda vacuum u have u didnt specify so try changing bag,dump cannister clean filters or just cuss it out lol
maybe one of these will help
Dec 28, 2007 | Vacuums
Vacuums Logo
Top Panasonic Vacuums Experts
Ryan S
Ryan S
Jim Parker
Jim Parker
Roger Potts
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
