Question about Dell Dimension 2400 PC Desktop
Won't turn on when I press the front button
I logged off and shut down the computer as usual yesterday - it had behaved entirely normal. When I wanted to boot it today and pressed the front button to switch it on would not respond at all. The button comes back out again and does not stay inside the machine even if held for longer. I first suspected a power problem but the cable and socket seem to be alright. Please help. Thanks.
  • cpu dummy Sep 09, 2008
    Dell dimension 2400 Wont power on Changed powersupply still nothing. Green light on mobo comes on thats it no fans no nothing.
    President:
  • Dell Master
  • 1,314 Answers
This sounds like your power supply; it's the part that the power cord plugs into that converts the power to dc and powers your motherboard, drives, and everything else inside your computer. You can pick one up for around $30 online or $80 at a retail store.
Thanks and please take a moment to rate as fixya.
Posted on Sep 08, 2008
Someone used my computer and did not log out.
Hello Barbara,
You can use following options.
Option 1: Easy One
Press and hold the power button between 5 to 7 seconds
This will turn off the laptop
wait for 20 sec after shutting down
Start laptop again
Laptop is ready to use.
Option 2: Moderate one
Remove the power cord from laptop
take the battery out
put the battery back
start your computer
Option 3: Difficult one
At this point I am not sure which Windows are you using and how do you usually log-in to the system.
I am guessing you got a new laptop, with Windows 7 installed.
The computer might asking you to press Clt + Alt+ Del to unlock the computer.
You can also see there is small button on screen which says "Switch User"
click on "Switch User" button
It will then ask your user name and password
Use your username and password the one you usually use to log-in to the system.
once you are logged in
restart the computer
it might ask you "other users are log-in do you wana continue"
press enter
the computer will restart and now you can use it as normal as before.
Hope these options might help
Thank you
Feb 27, 2014 | Computers & Internet
Hi FixYa folks, I have a Gateway DX4200-UB001A problem when ruuning in BOTH Vista Home Premium and now in Windows 7 Ultimate and giving me the same problem. When I put it in Sleep Mode, it won't come...
you are cold booting the pc always shut down normally when you shut down just useing button it will eventually corrupt the system I have several computers and never shut them off at all unless installing new hardware if you get a keyboard with the specific button just for the sleep mode this problem will clear up but if you shut down normal it will work rite
Jul 08, 2011 | Gateway DX4200-UB001A Desktop Computer
I shut down my computor it shuts down like it should but the power button stays on if you push it it doesnt go off like it should says power lock
Hello tvernia, hi, unplug your computer, press the power switch on and off several times, does the switch behave normally? do you hear the "click" , if no have the power switch replaced.
Nov 13, 2010 | Computers & Internet
Panasonic CT36SC13 remote or front power button will not turn off
Solution1:
a)Inside the tv there are microswitch CH+- Vol +- power, menu: when the ones are faulty," tv tends to behave at its own", change them, of course before to buy'em, unsolder th'em and try with the remote, tv has to work with out'em.
Apr 08, 2009 | Televison & Video
When i start the computer the sign log in off shows up
Hi there!
no need to panic. This is a safety feature with Windows. If you log-off the computer will normally ask you if you want to log-on again. This would NOT turn off the computer. If you want to shut-down the computer, simply push the power button on your CPU.. This will automatically shut the computer off.
....im hoping you could rate this as: FIXYA!
-levibit-
Mar 18, 2009 | HP Compaq Presario SR1920NX PC Desktop
Laptop won't shut down normally!
You should go to the BIOS and load the default settings. Also, check your device manager to check if all hardware is installed and functioning properly (no conflicts, etc).
Oct 31, 2008 | Acer Aspire 5630 Notebook
Having Trouble Starting
Enter Safe Mode with Networking.
Update Video drivers.
Restart the system in normal mode and if still no go then you have to reinstall Vista from CD's.
Sep 25, 2008 | Toshiba Satellite A305-S6834 Notebook
My Compaq wont turn on!
That flashing usually indicates a battery/power issue. Could the battery be dead? And/Or the power cable? Normally the power cable has a "brick" in the middle, and that connection could be loose. In many cases that brick has a led light when it is plugged it. Does your machine have that light and if so, is it lit? Does the "charging" or "AC power" light go on when it's connected via the power cable? Lastly, try removing the battery entirely, and using just the power cable, to make sure the battery is not causing the problem.
Jan 28, 2008 | Microsoft Windows XP Professional With...
Computer shuts down but does not turn off
Mchem, you actually have 2 separate issues going on there.
  • Open control panel > open the system control panel
  • in the system properties, click on the advanced tab
  • in the startup and recovery section, click the settings button
  • In the startup and recovery dialog box, under system failure, remove the check from the automatically restart option
  • click ok
  • click ok
  • Open control panel > open power options
  • in the power options properties, select the advanced tab,
  • in the power buttons section,
  • When I press the power button on my computer: click on the drop down menu and select the shut down option
  • click ok
Sebastien123, you only need to run the first part of this solution.
Dec 20, 2007 | EliteGroup ECS PF5 EXTREME...
Dell Dimension 2400 PC Desktop Logo
119 people viewed this question
Alun Cox
