Question about Philips AE2155 AM/FM/Weather/TV Radio
Replacement Knob I need a tuning knob replacement. Where might I find it?
What is the part number for the control knob for the Bernzomatic Patio Heater model # PH3250N?
Bernzomatic does not provide nor sell replacement parts for their products - they consider them disposable.
If the plastic knob is the only piece you need, Amazon sells a few replacement knobs for patio heaters. I searched Amazon with the terms:
replacement knob patio heater
Nov 01, 2017 | Pool & Spa
How to set clock in radio on a 2014 Jeep Patriot
Clock Setting Procedure 1. Press and hold the TIME button until the hours blink. 2. Adjust the hours by turning the right side TUNE/ SCROLL control knob. 3. After adjusting the hours, press the right side TUNE/ SCROLL control knob to set the minutes. The minutes will begin to blink. 4. Adjust the minutes using the right side TUNE/ SCROLL control knob. Press the TUNE/SCROLL control knob to save the time change. 5. To exit, press any button/knob or wait five seconds page 240
Mar 12, 2015 | 2014 Jeep Patriot
On/off swith knob broken
Is it the actual knob that is broken or the little tab the knob holds onto that is broken. You either need a replacement knob or a replacement switch assuming the know is also the thermostat for the unit. Does that same knob control the fan speed? Temprature or timer?
Mar 31, 2014 | Pelonis Heating & Cooling
How do I set my clock in my 2005 CTS?
  1. Press the TUNE/SEL knob to enter the main menu
  2. Turn the TUNE/SEL knob until set clock appears on the display
  3. Press the TUNE/SEL knob to select set clock
  4. Turn the TUNE/SEL knob to adjust the time
  5. Press the TUNE/SEL knob to update the time.Time updated will appear on the display
Thank you for using Fixya and good luck.
Mar 16, 2010 | 2005 Cadillac CTS
Starter knob on GE dryer came off. Dryer won't turn on.
If it turns hard, the timer may need replaced. But if you can turn the shaft with a pair of pliers and the dryer works, just get a new knob.
Jan 04, 2010 | General Electric WHDRR418GWW Dryer
JBL Prius Radio Tuning Knob Broke
Search for your model number on eBay. You should be able to find used radios taken from a totaled Prius much cheaper than buying a replacement from Toyota.
Apr 17, 2009 | Car Audio & Video
Missing control knob help....
Here is the customer service website to contact them about ordering another knob for your unit.
Jan 02, 2009 | Fahrenheat Electric Convector Baseboard...
Lost Tuning knob during accident.
Did you lose the gray part and the white center part? Meaning that when you look at where the knob was, all you see is a hole with a green circuit board and a gold circle in the center?
I have a knob for you (gray part and white part). Write to me at
Sep 21, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Philips AE2155 AM/FM/Weather/TV Radio Logo
35 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
