Question about Canon Sure Shot Z115 Caption 35mm Point and Shoot Camera
CANON Z115 SHOWS ERROR AND FILM DOES NOT ADVANCE
FILM DOES NOT ADVANCE AND SHOWS e, HOWEVER, SHUTTLER GOES OFF AND ZOOM DOES WORK
5 Suggested Answers
akku
  • 10 Answers
SOURCE: my canon sure shot zoom-s film camera
it happens some times when ur camera not in use from long time and when u do want to use it it doesnt work it just need servicing . go to any well technician and get it repared. and if u want to know sumthing about ur camera then mail me on priyanshu999@yahoo.com or contact me at 09971272689. take care
Posted on Dec 06, 2007
  • 185 Answers
SOURCE: leica m2 film advance lever is stuck
mandie22,
on this model two strokes are needed to fully advance the film and to set the counter to the next #,
so advance the lever, bring it back and advance again.
Posted on Dec 09, 2008
  • 17 Answers
SOURCE: canon ae1 film advance
On the very bottom inside the plate there are many cog gears with levers and retractor springs. One may had come off causing your problem
Posted on Mar 07, 2009
pontelemon
  • 531 Answers
SOURCE: WHEN I LOAD A ROLL OF FILM INTO MY CANON EOS 600,
Jammed Advance motor. Unfortunately, there is no way to reset it or fix externally. Will need service.
Posted on Apr 19, 2009
SOURCE: dear sir, pictures taken by it is unclear (canon EOS 500 Film cam
Hi Marvo,
thankx for your valuable solution but as i seen, i think all zoom lenses are ok, but shifted from its original position, can u please suzzest me, how to open it and what precautions should i take , and what will be its original position?
thanks
sanju
Posted on Oct 07, 2009
Canon iR2018N showing system error E007
eoo7 - fixing film in fixing unit does not work or spin, the cause of dry lubricant or fixing film torn, or white sign has been worn.
if dry then put lubricant again, if you tear you should replace it with new one, after that you must clear error. goodluck
pic of fixing film
Feb 22, 2015 | Canon iR2018N
Why is my canon ae-1 only developing blank film
First thing I would do is sacrifice a roll of film. Load the film as you have been. Then with the back open and tension on the film (do not touch the film over the shutter, advance the film. It may be that you are putting the film on the takeup spool incorrectly. Watch how the film advances on the spool. If it is on the spool incorrectly it will disconnect then not advance. If that does not work it may be a errant takeup spool.
Jul 06, 2012 | Canon EOS-AE-1 35mm SLR Camera
System error E007 Canon IR2022
Hi
I have problem with my canon Ir 2020 after 3 or 4 copy it shows Error E007 .. and some times when i turn on the copier it shows this error .
How can I Fix this error ... please help me .
Thank You in Advance.
Oct 24, 2010 | Office Equipment & Supplies
Error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Jan 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Film will not advance
Broken "Shutter FPC" .
Needs replacement.
Mar 25, 2009 | Canon Sure Shot Z115 Caption 35mm Point...
Camera froze up Type Canon Sure Shot ZOOM-S
Sounds like the film either didn't advance thru the camera or its been rewound.
Here's a copy of the user manual:
http://www.cameramanuals.org/canon_pdf/canon_sureshot_prima_105_zoom-1.pdf
Dec 25, 2008 | Canon Sure Shot 105 Zoom S 35mm Point and...
Film advance
In most film cameras, a battery is not necessary to manual advance film using the lever. Your Canon AV-1 is no exception. I have owned two cameras from the same group, the AE-1 and the Canon A-1. Neither required a battery for manual film advance.
Make sure the ring around the shutter release button is set to "A", otherwise the shutter won't release and the film lever won't work correctly. If the ring shows an "L", the shutter release is locked.
Here's a graphic of the batteries that can be used in your AV-1:
Nov 17, 2008 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
My canon sure shot zoom-s film camera
Dec 06, 2007 | Photography
Canon Sure Shot Z115 Caption 35mm Point and Shoot Camera Logo
61 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
