LG VX8350 Cellular Phone Logo
Posted on Aug 24, 2011
How do you fix the sound on the lgvx8350. Phone vibrates but will not ring. I have tried all the settings with no luck.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Aug 25, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
0
Helped
1326
Points
30
Try to change the speaker tip
maybe that'll help you......
LG flip phone won't ring, set on vibrate/ring and volume all the way up
My LG flip phone volume is all the way up. I've tried star key pound key volume keys even tried it during playing sounds and no luck. It has keypad volume but no ringtone or sound volume whatsoever. I've reset my phone and also dialed *228 but no luck yet. Any ideas?
tip
BlackBerry Tour: How to make it ring and vibrate for incoming calls
You can customize your BlackBerry Tour so that either it rings when you get a phone call, or it vibrates -- or both. To make your phone both ring and vibrate when you get a call, go to your BlackBerry's sounds and ring tone options, which you can get to by either of the following two ways:
#1 - Use the trackball to go to the sound icon in the upper left corner of the main screen and click on it, then toward the bottom of the list that appears, select Set Ring Tones/Alerts, then select Phone.
#2 - On the main screen, press the BlackBerry button (the one with the seven dots) to take you to your Home folder. Scroll down to the Options folder (it's usually toward the bottom, and it has a wrench icon) and click on it, then select Sounds and Ring Tones.
From this scren you can select the ring tone that you want and adjust the ring tone volume. Then scroll down to Vibration and set it for On.
There is also an option for Vibrate with Ring Tone. If you turn this option on, the phone will both ring and vibrate at the same time when you get a call. If you turn it off, the phone will vibrate first, then ring. Either way, you'll get the ring and the vibration -- it's just a matter of whether they happen together or not. To see the difference between the two options, use the "Try it" option at the bottom of the screen.
When you've made the selections that you want, exit out of the options screen, but be sure to choose Save rather than Discard to save your changes.
2answers
How to removed or turn off the vibration on the phone?
What phone you have would be useful to know but for
Android : How to Turn off Sound and Vibration in Androids Keyboard
Iphone: If you set the iPhone to vibrate in silent mode, it still makes an audible buzzing sound that may bother or disrupt others. If you need your iPhone to stay completely quiet, temporarily disable vibration. You can turn off vibration when silent mode is on, off or both. Tap the button next to "Vibrate on Ring."
Blackberry:
Turning vibration on my mobile phone on or off
  1. Find "Notifications" Slide your finger down the display starting from the top edge of your mobile phone. ...
  2. Turn vibration on or off. Tap the indicator next to Vibrate to turn the function on or off.
  3. Exit.
Nov 09, 2015 • Cell Phones
Why wont my Lg 4G phone ring
Hey Tony,
Go to Apps then Settings then Sound.
Make sure that the Sound Profile is on Sound (not on vibrate only or on silent) and then go to Volumes and adjust ring volume to your desired settings. Case closed.
Try downloading your phone Manual of Operation from this link.
Good Luck!
JP
http://www.lg.com/us/support/manuals
1helpful
When somebody rings sometimes it only rings once then goes silent
Go to Settings > Sounds > Change the settings to Ring+Vibrate or Ring Only or Vibrate Only
I guess you have by mistake changed the settings right now to Ring Only Once and hence it rings just once and then vibrates. If there is not settings icon and no sounds option you can check if you have Profile as option as you can change it accordingly in the profile you are using. Hope this helps. Good Luck
1helpful
My iphne 3 will only vibrate but not ring
If you're missing incoming phone calls due to your iPhone not ringing, you may have accidentally switched the ringer to vibrate or silent, according to Apple. The switch on the left side of the iPhone turns off the ringer and usually sets your phone to vibrate mode, but if your iPhone's vibrate setting is also disabled the phone will instead be set to silent mode. When in the phone's sound settings vibrate mode can be enabled, and the ringer volume of your phone is adjustable.
Read more: My iPhone Will Not Ring ' eHow.com http://www.ehow.com/how_7384812_iphone-not-ring.html#ixzz22OJOMZGR
1helpful
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
My phone will not ring out loud and vibrate at the same time.
To turn on a ringtone and vibration, go to your BlackBerry's sounds and ring tone options by either of the following ways:
1. Use the trackball to go to the sound icon in the upper left corner of the main screen and click on it, then toward the bottom of the list that appears, select Set Ring Tones/Alerts, then select Phone.
2. In the Home folder, go to your Options folder (usually toward the bottom, has a wrench icon) and select Sounds and Ring Tones.
Select the ring tone and volume that you want, and for Play Sound select Always. Scroll down to Vibration and set it for On.
There is an option for Vibrate with Ring Tone -- set that to on in order to make your phone both ring and vibrate at the same time, then save the settings when you cancel out, and you're all set.
41helpful
HTC Touch Diamond will vibrate, but won't ring on incoming calls
I just had this problem - and I have been messing with it for an hour.... but I finally fixed it - Try this - touch the speaker symbol on top (The system status window should pop-up) then touch the speaker symbol again (Now you should have two tabs - one for system and one for ring) Touch ring and slide it up. This worked for me.
2answers
No ring, only vibrate
if the ringtones ring from settings or the songs play then it will be surely the settings problem please select ring and vibrate instead of vibrate only and if it doesn't works then go to a near by repair shop and ask them to check and change the buzzer
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
