Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
Maytag washer/front end loader
After the wash is done I reach in to get my clothes and they are sopping wet. Try to do a spin cycle again, but to no avail. It sounds like the machine is going thru the proper channels/gears. Could the there be a blockage?
hope you can help,
Fritzie
fvicente1@tampabay.rr.com
  • 1 more comment
  • allysone Sep 12, 2008
    Mine is doing the same thing just starts and the timer keeps resetting
  • newtonpuppy Sep 29, 2008
    I agree. The clothes are still wet and sometimes has soap in the well. I do't think it is rinsing well either or spinning.
  • Anonymous Oct 23, 2008
    I have this same problem. The lock on the washer door is malfunctioning so it prevents the washer from going to spin cycle. So far, only a replacement of the "wax motor" for the lock and the board that controls this function is the only solution i could right now.
Mine is doing this too. The "wax motor" that locks the door during wash has failed so the machine will not go Spin Cycle.
Posted on Oct 23, 2008
HI...mine has just started dong the very same thing. I unplugged it to reset the computer and tried
just the 'spin' setting....still...the water is still in the machine....not sure what to do. I thought a blockage too.
abby
Posted on Sep 27, 2008
I have a WSXH208 ge front loader It started to fill was and then in the middle the water pumped out but did not finish and clothes were sopping wet, Drum stopped spinning. what could be wrong
all front loaders will not go into high spped spin if there is water in the tub.You should first remove the bottom panel and check the water pump for blockage.Some units have a sscrew style filter to catch debris befor it enters the pump impellor.when you unscrew the filter make sure you have a wet vac handy.
Apr 02, 2013 | Washing Machines
My washer spins out very slowly and the water drains but the clothes are very wet.
f the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing.
Nov 30, 2010 | Westinghouse WWS833ES Super Capacity Top...
Hi, my neptune washer will not spin clothes dry they come out sopping wet. can you help? thanks
if there is water standing in your washer your pump is clogged clear it out and will correct the problem ; if there is no water in the machine when you complete the cycle but the clothes are wet it did not spin more than likely your door switch is probably bad replace it
Aug 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
Clothes sopping wet at end of all cycles
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Frigidaire ATF6000ES Front Load Washer
After the wash cycle is complete the clothes are still wet.
Open the machine and remove the drain pump. Clean out any debris and try again.
Remove the front panel.
The pump should be directly in front of you. Open it and clean it.
This procedure will have to be done occasionally.
Mar 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune MAH6700AWW spins but not fast enough
Too much laundry in your machine. Try a smaller load and see if you have the same problem
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer Not Spinning All Of The Water Out
It's not supposed to. They all keep water in the drum after wash is finished. Was told by Maytag its to keep the balance of the spin cycle, like balancing a tire with lead weights.
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
How can i fix my washer myself?
The washer will not ever completely drain according to Maytag. A certain amount of water stays in the outter tub for balancing the machine for final hyper-spin. However if the machine is not spinning all of the water out and your clothes come out sopping wet....read the long thread I typed out to another person earlier.....it's about 2-3 questions up on the same topic
Beach towels sopping wet after machine done spinning
The washer will not proceed into high speed spin with just two large beach towels in the basket. The washer is detecting a out of balance condition, and remains in low speed spin. Solution? Try adding more items into the basket. With only two towels, there is not enough mass to balance the washer. With more clothing or towels, there is more items for the machine to balance, and reach full speed spin.
The only other thing that could cause this, would be if the water in the tub is not completely draining in the time allowed. This washe does not have a cleanout, and checking for an obtruction in the pump is difficult. I would go with the more clothes first, then see.
Sep 25, 2008 | GE WSXH208A Front Load Washer
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
162 people viewed this question
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Bill Long
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
