Check on the fuse box, am sure that a starter fuse is blown. the alternator might be the causer. as you said you changed it not so long. When you find out the fuse are ok, check also the solnoid wire on the starter motor beside the main wire, when that is good then might be the carbon brushes are won need to be replaced
Testimonial: "Thanks For the help, I will try these things, this was helpful, I check a few wires, and some fuses but not the ones you are refering to!! Thnx Again!"
Several possible solutions here. I'm assuming you know how or know someone who knows how to check the following items on your car: Check your ignition switch, make sure it is connected properly and is working. Make sure cables are connected properly to the starter. Check the starter solenoid switch (if you can, remove the starter and take it to a store like autozone to have the starter tested for free). Check the ignition/pickup coil. Check that distributor cap and all wires are properly seated (distributor cap/rotor could be faulty). Hope this helps.
