Question about Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Ver6
Have been using this Linksys router for over a year with no problems. My computer is connected to the router with a broadband cable and the router is connected to the Comcast modem with the same type cable. My wife connects to the internet with a wireless computer. This past weekend we connected a second desktop computer to the modem with a broadband cable and everything worked well for a couple days. Then we could no longer access the internet with the router. The second computer has been removed, but neither my wife nor myself can access the internet through the router. We keep getting the message that the web browser can not desplay the page. My computer works fine connected to the modem when the router is removed. I tried replugging all the cables and pressing the reset button for 30 sec, but had no success.
  • poth_34293 Sep 09, 2008
    Could not reconfig the router with a cable internet connection. When I plugged in the router I still got the message that internet explorer could not desplay the webpage. Had to unplug router to write this comment.
  • lisawebb873 Oct 10, 2008
    I moved my computer last night (turned off/ unplugged) and when I got set back up, I could not get on the internet. I worked with my isp provider (bellsouth) for over an hour, reconfiguring, setting new passwords, over and over... Finally I bypassed the router and just used my modem and everthing was fine. Well, except that I can't use my laptop now! I don't want to mess up this connection by trying to fix it.
    Scholar:
  • 65 Answers
Try reconfiguring the Linksys router. Click on this link for instructions on how to configure the router with a cable Internet connection.
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=4da24a60bfc84fe9ad65ce672b4b8b52_KB3686_EN_070208_v1.xml&amsstatsid=4067617
After configuring the router and if you already have an Internet connection, then connect your second computer to any numbered port of the router (port 1,2,3, or 4) and test the Internet connection.
Configure the wireless settings of the router by following the steps on this link.
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=2f99c35863934424a932742692a5e83b_KB4024_EN_070329_v1.xml&amsstatsid=4067626
If you want to have a wireless security for your network, you may clck on this link for instructions.
Then try connecting your wireless computer to the name of your wireless network and enter the security key (if you have created one).
Posted on Sep 09, 2008
Wrt 54gs ver6 power led flashes rapidly all other leds off. if lan is plugged in..the led comes on.. hard resetting does not bring the router to it`s original state either.All this uooured when i had a...
This power failure could not have happened at a worst time.
Try reinstalling the upgrade again, and if this does not fix the problem then I think you have a piece of junk.
Mar 30, 2012 | Linksys Wireless-G WRT54G Router
Can only connect 2 computers
Yes, the Linksys Wireless-G WRT54G Router will used to connect the computer wirelessly by using the security keys.
You will have different combinations of encryption or security keys.
Jan 22, 2011 | Linksys Wireless-G WRT54G Router
Can connect to internet directly through modem. When connected through Linksys WRT54GS router, all lights are ok on both modem and Linksys--including internet. (Have had this router for 2 years...no...
As last resort you might want to use a JTAG cable and debricking programming software. If your router is brikced or you want to change the firmware this cable can do it. The cable will connect to your parallel port and your wireless router so you can repair your router. They are about $5.95.
Jan 11, 2010 | Linksys Wireless-G WRT54G Router
Linksys WRT54G Wireless Router Issue Allows 1 Computer at a time
Your router my not be DCHP enabled or it might not be assigning the IP addresses either.
I would do a reset and start all over with your security settings and see if that works. Worst case scenario you could always turn security off when your parents or others are there.
Link HERE for more Linksys information
pls rate 4 stars
Dec 01, 2009 | Linksys Wireless-G WRT54G Router
Lost wireless router CD
You can make the router working even without using the CD. Who is your ISP? Are you having concern with wired or wireless connection?
Jun 28, 2009 | Linksys Wireless-G WRT54G Router
WRT54G Linksys Wireless Router
Hi and welcome to FixYa,
Pinging most LinkSys WRT54G would require to open a command prompt in the PC, type "ping 192.168.1.1" less the quotes and await reply from the router.
Good luck and Thank you for using FixYa.
Dec 03, 2008 | Linksys Wireless-G WRT54G Router
Cannot connect to WRT54g
think you have to connect a cable to the ethernet adapter of your desktop in order for you to connect to the wrt54g. uless you have a wireless lan on your desktop. also check your channels. and manually config your router through 192.168.1.1.......
Aug 31, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
Useing WRT54G WITH STARBAND
your starband is if im right the cable modem ? connect the modem to the router and then the router to the computer ? then run the linksys easy connect @ www.linksys.com/support
Jul 19, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
130 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
