Question about R.A.M. Computers IX PACIUP4240 15'' LCD TV / DVD / PC CIU Combo (2.4 GHz and 256MB RAM ) (PACIUP4240L) PC Desktop
Usb I'm trying it on my printer only now and that's what is not working due to the usb problem
  • R.A.M. Compu... Master
  • 13,433 Answers
Try connecting the printer directly into a usb port, also if possibly try the printer on another computer to see if the problem happens there also, or if its a problem with your ports.
Posted on Sep 08, 2008
Windows 7--64 bit. USB port, was working. Had power outage due to lightning striking corner of house, burned out some breakers. Printer was on surge protector, but printer and PC not powered off prior to...
See if printer will work in another working computer. If it does the issue is with your computer hardware/software. If it also does not work then the issue is with the printer. And if so, it is not cost effective to repair given the price of printers these days.
Mar 03, 2017 | Brother MFC495CW AllInOne InkJet Printer
Tai sao khong scan duoc
The problem could be due to a bad USB cable or the USB port on the PC is faulty. [Yes, they do fail] Also, this MFP came out before the new USB 3.0 so their could be driver issues as well. Try a different port first. If that doesn't work, try a different cable that you know works. Try either reloading your printer driver next. Don't forget to inspect the connector on the scanner where it plugs into the back of the main chassis. If the cover has been removed and that plug had been unplugged, re-seat it into its board.
May 07, 2014 | Xerox Phaser 3200MFPB Multifunction...
Drucker ist an aber druckt nicht
Just yesterday I bought a German grammar but I cannot pretend I understand what you are saying. Google translate says that the printer is ON but nothing prints. Have you tried copying? If it does not copy then machine may have a problem (paper jam, lack of ink) or its configuration is amiss.
If one of the cartridges is empty the printer will scan but will not copy nor print.
If printer copies but does not print it may be due to a connection problem (no connection or faulty connection). Try with a USB cable. For this you will have to install the printer as a USB printer (You can install USB printer and Network printer at the same time)
If the USB printer works then you have an Ethernet or wireless configuration problem. For the wireless the router must reserve an address for the printer. There is a utility in the Brother Software suite that can find an IP address for your printer.
Oct 13, 2013 | Brother MFC-465CN InkJet Printer
I am tryibf to install my new brither hl-2142 laser printer but it comes up with " USB printing support the required device registry key does not exist" I have paid my money to Fixya.com ...
This error may occur due to 2 reasons.
1. Faulty usb cable or corrupted USB drivers
2. Glitch in O/s ( your pc operating system
I would like to know the operating system you are using or setting up this printer on.
Try these steps.
Try changing the usb cable. Connect with another cable. If this does not work, Connect it to another USB port on the PC
Hope this should fix the issue.
Nov 06, 2010 | Brother HL-2040 Laser Printer
I have HP Laserjet 4000 PCL6 printer with parallel port only. I purchased a parallel to USB cable to try and get it to work, but there seems to be no way to get it to print. There is no option for setting...
Many USB to Parallel, and USB to Serial adapters/cables just don't work well, due to the processing 'overhead' in the software of the drivers for these devices.
The parallel (or serial) device at the end of the cable just doesn't 'see' responses quick enough, so asumes it not to be connected to anything.
Network adapters are plentiful and cheap for these printers. Perhaps this is the solution.
Mar 18, 2010 | HP LaserJet 4000 Printer
Computer wont recognise the printer
it is the problem with your USB driver, try to update your USB driver due to your motherboard brand, series and model...
or if its not work, update your bios,
also check the cable, is it normal or broken
Jun 29, 2009 | Epson Stylus DX4850 All-In-One InkJet...
HP F2200 all in one/ usb
As you are receiving the USB device not recognized whenever you plug in the USB cable, the problem could be either due to the corrupted USB drivers on your computer or the USB cable needs to be replaced. Try updating your USB drivers and/or replace the USB cable. I am sure that the issue will be resolved.
Nov 23, 2008 | HP DeskJet F380 All-In-One Printer
Mp240 Canon printer not responding.
just go to the printer folder right click the printer and then choose properties then click the ports tab and find a usb port. check it and click apply. then it should work. if not then i cant help you sorry. i had the same problem and the sollution was the port.
Nov 01, 2008 | Computers & Internet
Cable problem
Usb extension cables may give you troubles, buy a longer usb single cable, possibly a well sielded one (ask seller) long usb cable can give you troubles due to the bigger signal loss on a longer wire.
Aug 27, 2008 | HP DeskJet 3550 InkJet Printer
R.A.M. Computers IX PACIUP4240 15'' LCD TV / DVD / PC CIU Combo (2.4 GHz and 256MB RAM ) (PACIUP4240L) PC Desktop Logo
26 people viewed this question
Top R.A.M. Computers Computers & Internet Experts
Laxman Bisht
Laxman Bisht
castletech
castletech
Are you a R.A.M. Computers Computer and Internet Expert? Answer questions, earn points and help others
