I want to change my kenmore washer water pump. How/where can I get diagram and step by step instructions?
  • 116 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Lean the machine so that the front is up enough for you to get under and see the pump just inside the front of the washer.
Remove the 2 retaining clips from the pump. Now take off the 2 hose clamps. remove the hoses to the new pump and put the clamps on. Put the retaining clips into the motor housing, install the new pump. Now attach the retaining clips and you should be good to go. Hope that helps
Regards
Posted on Sep 08, 2008
How do i remove the clutch on a kenmore 70 series washing machine?
To get step by step instructions.Please click on the link below:----- http://technoanswers.blogspot.com/2011/03/how-to-remove-clutch-on-kenmore-70.html -------------- It has instructions and diagrams to remove and replace the clutch.------ This should help.Thanks.Helpmech.
Mar 25, 2011 | Washing Machines
How do i remove a cabinet diagram on a kenmore 500 washer
The following link explains step-by-step how to properly remove the exterior cabinet on a Kenmore top loading washer:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
Kenmore is manufactured by Whirlpool, so these instructions will apply. If you have any questions, please post back and let me now. I hope this helps you.
Feb 16, 2011 | Kenmore 24032\24036 Top Load Washer
Instructions on how to install a belt on a kenmore top load washing machine model #: 110.24622300
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Next, see the following illustrated description of how to replace a belt on top load washers:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=144&osCsid=2d35143b9424efb2825c26899392c2e1
Sep 08, 2010 | Kenmore 22422 Top Load Washer
I have a Kenmore 90 Series model 110 washer that overflows. I have changed the water level switch and verified the tube is clear and has no leaks. Could the timer have anything to do with the problem or...
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It has a troubleshooting section as well as testing procedures.
I'd test and verify that the Water Inlet Valve is working.
If it tests OK, I'd also test the timer.
May 19, 2010 | Kenmore Washing Machines
Water pump replacement
haynes repair book,,it is good to have if u plan on keeping the truck,,,,tells u step by step,,
Apr 20, 2010 | 1998 Jeep Grand Cherokee
My kenmore HE3 front load washer will not drain or open door
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 21, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I need instructions for replacing snubber pads
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Look at the diagram of the machine base.
If you have the basic Kenmore top load, you can use a thick screwdriver to pry the tub base up from the machine base and pop the old pads out.
Oct 09, 2009 | Kenmore 24032\24036 Top Load Washer
70 Series Kenmore washer pouring water underneath washer.
Check the areas for the motor and pump and the Agitator Basket and Tub .
If you've checked the hoses to and from the pump the problem points to either the pump itself or to the Centerpost gasket.
Neither of these is too difficult to replace, the Gasket requires removing most parts of the washer although the pump is an easy replacement.
Sep 24, 2009 | Kenmore 24032\24036 Top Load Washer
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Front Load Washer Won't Drain (Model #417.40052990)
The machine knows when there is water left in the tub and will not function properly because the level switch indicator is still open.Ok, to simplify this ,you have a clogged pump and if there is no access into the machine from the front then look at the back to see if there is.Open the panel and remove the hoses from the pump and remove what is caught in it.Also look into the ends of both the 2 hoses.Don't wash RUGS,MOPS,COIN MONEY,NAILS,JEWELERY,UNDER WIRE BRA'S,OR ANY THING THAT DOESN'T BELONG IN THE WASHER,cause these little things don't make it past the pump,therefor washer leaves water inside and error messages start rolling.
Nov 11, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
