Have Kenwood CD UD-405 not used for many years. Will not now play CDs or sometimes a few tracks then cuts out stating *NO DISC". Seems fine electronically. Tried switched on for several days to remove condensation in lens system as recommended in user manual, but no effect.
Seemed to have solved problem by using lens cleaning disc. Had no effect at first but kept trying it and eventually started working. Many cut outs but kept repeating and eventually played without cut outs.
Posted on Sep 09, 2008
Sony cdp cx 355 skips on first track
Could be some dust or debris in the unit. Also be careful that you are not putting fingermarks near the hole section of each CD you put in, as the CD plays from the centre out.
Jul 02, 2017 | Sony MegaStorage CDP-CX355 300-Disc CD...
Getting a whine from CD player
Hi there! i have listed out the parts of cd player(see image). The clamper is a part of the cd tray ejecting mechanism that is under the tray. The pcb is used to power the lens mechanism and the laser you are talking about is a part of the lens mechanism(it uses laser to read the discs). Now tell me where did the tech tell you install the brass string and i will help you out
Mar 06, 2008 | Aiwa JAX-S5 CD Shelf System
Audio formats supported by kenwood kdc 719
My older CD player accepted WAV files when I burned them as Audio CDs. (I was able to add CD-Text, even though my player can't read the text. The disc I added space between the tracks though didn't work properly.)
Then do a mastered burn (disc at once) and finalize the disc. I used CD Burner XP for burning the latest batch and Audacity to create the WAV files. I've also use Roxio Creator and Nero in the past.
I hope this helps.
(I'll admit there's one issue - I can't get the disc to stop between tracks. I was copying audio tapes to CD before more of my tapes broke.)
Apr 29, 2012 | Kenwood KDC-719 CD Player
Cd player will not play cd's. Error code: TOC ERR
A few things it could be:
No disc has been loaded in the disc magazine.
CDs being used are burned, test using different media or an actual CD.
Very dirty or scratched CDs.
The CDs are upsidedown.
Sep 21, 2011 | Kenwood KDC-MP4028 CD Player
Player stops mid track and shows ''no disc''.
HELLO
Have you tried cleaning the lens? It's incredible how a dirty lens can cause so much grief! You'll need the CD player cover removed and powered off then get some isopropyl alcohol and a cotton bud. Wet the bud but not too much get any excess moisture off.
Using a careful circular motion clean the lens, let it dry and try the player again. If this does not cure the problem, you may have a defective laser and that will need replacing.
ALL THE BEST (:-)
Oct 04, 2009 | Audio Players & Recorders
Alpine CDE0-7826P Cd Player doesn't always work
If It dosent play burned cds its not an mp3 compatiable cd player as far as the other problem kinda seems like its time for a new cd player
Jun 14, 2009 | Alpine CDE-7826P
Kenwood kvt m700- playing cds
The M700 is purely a monitor so you will not be able to control play, pause, stop, skip, FF or RWD. I use my DVD player as a CD player and have to use the DVD remote to change tracks.
Mar 27, 2009 | Kenwood KVT-M700 Car DVD Player
Kenwood cd stopped pla computer made cds after i dropped it now will play for about 1min then stops
hi 1paullawrenc, try get your lens cleaned by using a lens cleaner hope this solve your problem.
raj..
May 11, 2008 | Kenwood CD-203 5-Disc CD Changer
Kenwood RXD25 CD player intermitent??
Hi jenoss
Sounds like the unit has either a failing load belt to the cd drawer mechanism,not allowing the transport to fully load the cd. Give the unit a gentle tap just after the drawer closes and see if it resolves the problem.
OR a faulty spindle motor, you will have to take the lid off and after pressing play, give the disc a gentle "kickstart". If it then begins to run, then the motor is the problem.
If you find it is neither of these, get back to me here and I we shall go further
regards
Graeme
Mar 16, 2008 | Audio Players & Recorders
Kenwood KDC-2025 won't play CDs
source http://www.kenwood.nl/support/veelgestelde_vragen/ Changer Error Codes ? E-00: Poor Cable connection. ? E-01: Magazine not properly set in changer. ? E-02: No Disc in magazine. ? E-03: CD does not have selected track number. ? E-04: Disc is dirty, upside down or unreadable. ^^^^ ? E-10: No data is recorded on the MD. The player plays the next disc automatically. ? E-99: Changer malfunction, disc may be caught in machine or changer requires service. I suggest the lens needs a clean, or someone has dropped it and broken the delicate lens mech. Luck
Apr 30, 2007 | Kenwood KDC-2025 CD Player
126 people viewed this question
 Grubhead
Grubhead
