Question about Radio Communications
Interference using maxon pm100 2 way radio
We have used this radio system for 8 years for our taxis. For the last 4 days we have had a great deal of interference. So much so that on many occasions all we hear is a crackling noise and cannot hear the operator speak. There is an orange light coming on which was previously green when the operator spoke and red when the driver spoke.
Can you please help us solve the problem.
Thank you
    Scholar:
  • 157 Answers
Hello susannebrown. There is a problem with the base station or repeater station. If your mobiles can communicate ok, you have problem with the base, check the antenna & coax connections. #2 Swap out a mobile with the base & test operation. If you can do this & found the culprate care it to the repair shop(less cost). #3 Swap has no effect or you can't, you have a repeater problem. Sorry, call a repair shop.
Posted on Oct 20, 2008
How do you install a Maxon radio repeeter. It only has two wires that apear to be a Hot(Red) wire and a Black(ground). Should I just ground it and hook it up to a power suply?
Your correct the red wire is the positive and the black is the negative. You must also make sure to use a power supply with enough current to operate the radio. Usually a 12 volt supply that supplies about 4 to 8 amps should do the trick
Oct 29, 2011 | Maxon MCB-30 40-Channels Base CB Radio
What size fuse do i need on the positive side do i need if i have it hooked to the battery. my cb is a maxon mcb-40. if u cud tell me what size inline fuse i need it would help alot thank you
Most un-modified CB radios run about 2 to 4 amps on transmit. A 5 amp fuse is sufficient for most radios. Check you owners manual for the correct size fuse to use.
Feb 28, 2011 | Maxon Radio Communications
What is the range of the maxon hcb-10 model. miles or kilometers will do
It is between 4 - 7 miles.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 26, 2010 | Maxon HCB-10 40-Channels Handheld CB Radio
Hello there, I have the maxon mcb 30 and I have lost the mic. Do you know what kind of mic I must use to work good?
Try the stock mic from cobra, the regular 4 pin mic, its a great mic..... enjoy.... hope this helps....
Mar 13, 2010 | Maxon MCB-30 40-Channels Base CB Radio
I have a maxon sl55-u2 frequency radio only channels 1 to 4 work. why is this?
Only 4 channels have been programmed, you will need a programming cable to plug it into a computer and use the maxon software to programme the other channels to whatever frequency you need.
Nov 15, 2009 | Maxon Radio SL55, SP130, SP140, SP150...
Need a part for a maxon pm150
try phoning gb comms on 01388 778368 they repairs taxis radios
Mar 29, 2009 | Radio Communications
Reprogramming a Maxon SP 100G?
Hello codeencrypt,
THE SP100G is essentially the same radio as the SP100U UHF business band unit that Maxon made at the same time, just pre-programmed for GMRS. I believe there is a programming kit for this radio (Model number: SPK400C) which may still be available for purchase from Maxon directly. Otherwise, your best bet is going to be contacting your local Maxon dealer to see if they have the capability to program he radio.
Best regards,
Ken
"Go Ahead. Use Us."
Jun 04, 2008 | Maxon SP-100G (4 Channels) 2-Way Radio
Maxon MCB 10 A
I'm not sure about your particular model but many CB radios use the microphone push-to-talk switch to kill the speaker while the radio is transmitting. If you don't have the correct microphone or if the cord has a broken wire it can cause the radio to have no sound. Another possibility is that the speaker is bad. There is probably an external speaker jack on the back of the radio. You could try plugging a different speaker or even an earphone in the jack to see if you get sound there.
Mar 07, 2007 | Maxon SP-100G (4 Channels) 2-Way Radio
Radio Communications Logo
343 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
