Question about HP Computers & Internet
I have a HP laptop dv6527eu. From past few days, I have started experiencing starnge problem. It suddenly switches off without any notifications. It boots properly whn switched on again. Can you pls tell me what is the problem.
    Problem Solver:
  • 23 Answers
It can sometimes shut down unexpectedly because it had just automatically installed window updates.
Posted on Sep 09, 2008
Bose Bluetooth Headset Series 2 - Right Ear
What exactly happens when you say the battery drains fast? Does it suddenly stops working, or does it starts beeping with low battery notification right away?
If the battery is bad, then you will need to have it replaced. Although the bluetooth is made to be a single piece without easy way to service it, it can be done, although with some skill.
One day I will post detailed instructions on how to service this type of device, but from what I know these types of posts BOSE corporation takes down very effectively, that is why you do not see any of them.
If the bluetooth suddenly stops working and then starts up again, that most likely is a actual switch problem, and requires cleaning inside the switch. I say cleaning instead of replacement, because I failed so far finding switches of this type. It is about .7 mm high, about 5 mm long and 2.5 mm wide. If you are careful, you can open the switch, clean the inside moving parts of it, and solder it back up again. I have done so with at least 20 of them, so I know it is doable.
Oct 28, 2012 | Bose Bluetooth Headset Series 2 - Right...
HP PSC 2210 PRINTER creates a 'thumping' sound when switched on!
Hi Natalya, I have done some research on you printer and I have found some troubleshooting steps to try and solve your issue.
Please follow the links :-
Remove and Check the [Right/Left] Cartridge :-
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042885&tmp_track_link=ot_recdoc/c00055502/en_us/c00042885/loc:3&lc=en&dlc=en&cc=us&product=79499
Open Door, Clear Carriage Jam, and then Press Enter' Error Message Displays on the All-in-One
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042632&tmp_track_link=ot_recdoc/c00055502/en_us/c00042632/loc:4&lc=en&dlc=en&cc=us&product=79499
All the Best
Jul 14, 2010 | HP PSC 2210 All-In-One InkJet Printer
I have an hp pavilion dv2315nr notebook. My interneal wifi stopped working all of a sudden.
On the front of the computer is a switch to turn the internal wireless on and off. It may have gotten turned off. This user guide from the HP site shows the switch location (look at page 10).
Thanks for using Fixya!
Feb 15, 2010 | HP DV2315US PAVILION DV2315US NOTEBOOK PC...
My HP presario note book has started to switch off
Computer shutting off after a few seconds to a few minutes
This sounds like an auto shut-off signal given by the processor because of a possible over-heating issue. This usually happens when the laptop has been run for an extended time without having the dust, dirt and debris cleaned from its cooling vents and grills. After time, the thermal paste on the processor bakes under the extreme heat and starts to flake off and lose its efficiency at cooling the processor.
Get a few cans of compressed air that you would buy at an office supply store and using short bursts, blow out the dust and dirt from all the ventilation grills and vents first, make sure the laptop is powered down and battery removed. Then, open all the compartments and clean them out as well including the cd/dvd tray. There is a small black hole on the dvd bezel, just stick an open paperclip in it and it will pop the tray open. Blow a good blast in there to clean the dvd player.
There is the possibility that the thermal paste will have to be replaced, that means you need to gain access to the heatsink and remove from the processor, clean all the old thermal paste from it and apply a small thin layer of new paste to the top of the processor and replace the heatsink, securing it evenly with the attached screws. If you uncomfortable with this step, I would look into one of the local shops to perfrom this procedure for you, because it is critical for the laptop's survival over the long run.
Oct 26, 2009 | HP Compaq Presario C700T
PC will not boot, power and fans turn on, no video, no post.
LEAVINGYOUR COMPUTER RUNING ALL THE TIME WILL NOT MATTER.
NEED MORE INFO
SHUT DOWN THE SYSTEM, MAKE SURE EVERYTHING IS SEATED, REMOVE THE MEMORY AND REINSTALL THEM, REMOVE THE CONNECTION FROM THE HHD AND MOTHERBOARD RE INSTALL THEM, REMOVE ADDITIONAL BOARD AND CARDS, UNPLUG MONITOR AND PLUG IT BACK IN, REMOVE ANY EXTRA USB CONNECTIONS UNTIL YOU TRY RESTART THE SYSTEM.
ROD/ CANDYMAN GANDY
Jan 29, 2009 | DFI LANPARTY UT nF3 (LANPARTYUTNF3250GB)...
Laptop goes off
If a computer shuts itself down suddenly after 10-15 minutes it's usually down to oveheating. clean the filters and ensure that there is good airflow around the computer when you use it. you can keep an eye on temperature and control your fans with this program
http://www.almico.com/sfdownload.php
you might need to buy a laptop cooler like this
http://www.amazon.com/Targus-PA248U-Notebook-Chill-Pad/dp/B0000AKA8Y/ref=pd_bbs_1?ie=UTF8&s=electronics&qid=1204562271&sr=8-1
which sits underneath it and blows cool air in
Mar 03, 2008 | Acer Aspire 5630 Notebook
Toshiba A105 keyboard
Your keyboard or motherboard could be failing. Would suggest calling manufacturer for support to get it repaired.
Dec 16, 2007 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
55 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
