Question about HP ProLiant ML150 G5 Server
STORAGE HP ProLiant ML150 G5 Server Problem WHEN INSTALLING WINDOWS 2003 R2 IT STOPED DURING INSTALLTION WHEN PRESS ENTER TO CHOOSE INSTALL WINDOWS GIVIEN MESSAGE IT DID NOT DETECT ANY HARD DRIVE ON MACHINE . P.C : I HAVE 1 HARD SATA 250 G. IN THE ARRAY PLEASE HELLP AND FORGIVE MY WEEK ENGLISH LANGUGE.
  • 1 more comment
  • Anonymous Sep 17, 2008
    I have exactly the same problem.
  • sam_HP_user
    sam_HP_user Mar 23, 2009
    I have the same problem. Since this server does not have a floppy drive and windows 2003 does not support USB during installation, how to install? The only solution I am about to try out is to use the HP SmartStart installation media though the list of supported servers on it did not show ml 150!!
  • Anonymous Apr 08, 2009
    is there any Easy Set-up CD for this server ???
    talalism@gmail.com
Hi, I found this thread interesting. Will try it out today.
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?prodSeriesId=3799613&prodTypeId=18964&threadId=1285096&admit=109447626+1237817674797+28353475
It says that the right driver is not in the support CD!! As per the link, the problem was solved for him once he used a USB Floppy drive (Windows compatible).
Posted on Mar 23, 2009
  • sam_HP_user
    sam_HP_user Mar 25, 2009
    Hi Guys,
    I solved this issue yesterday night :) . Quite straight forward. Download nlite, integrate the storage drivers from support site (including the one I posted earlier), make sure NOT to add 64 bit driver, then using the integrated installation folder, burn a bootable cd. Thats it! Oh, one more thing, I changed the HDD mode in Bios to RAID as well. Good luck.
    Sam.
  • vhong Oct 28, 2011
    thank you so much sam...... its really a big help
Sam.
Thank you it works.
Selim
Posted on May 08, 2009
But i think there is arry config
Posted on Nov 19, 2008
    Scholar:
  • 95 Answers
The problem is probably that your hard drive controller wasn't detected by Server 2003. You'll need to make a boot floppy, and press F6 during setup of Windows to pass it the correct driver. You can download the needed files from HP by clicking here. Make sure you've got a good floppy disk before beginning the process.
Steven
Posted on Sep 17, 2008
Drivers and support for hp proliant ml150 g5 in installing windows server 2003
You should find helpful tips at the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3580646&prodTypeId=15351&prodSeriesId=3580609&swLang=8&taskId=135&swEnvOID=1005
If you have a more direct question with your install, please feel free to repost. Good Luck
C2Solutions
Please rate your solutions here at FixYa. Thank You.
Oct 28, 2011 | HP ProLiant ML150 G5 Server
I am unable to instal windows server 2003 on HP Proliant ML150 G5 because it gives me message no hard drive found
Option 1 (HIGLY Recommended): HP servers should come with an install disk that prepares the windows installer for you. Boot from that disk,tell it your OS, and pop in the disk for the OS when prompted. It will come up fine and have all the HP monitoring agents installed.
Option 2: Load the driver the old fashioned way. Unless you have a floppy drive the standard "Press F6 to load drivers" trick won't work. If you do, then you'll need to put the RAID driver on the disk.
Option 3: Use an installation customizer like nLite to pre-add the RAID driver to the Windows 2003 installer.
Good luck.
Feb 26, 2011 | HP ProLiant ML150 G5 Server
Hard disk not found message coming while installing windows server 2003 on Hp Proliant ML150 G5
You need to press F6 and load special drivers for your disk driver card
See which disk adapter your server has and get the drivers on a floppy disk
Put the disk into your computer before seutp, then click F6 when prompted
it will search your floppy drive for them
Feb 15, 2011 | HP ProLiant ML150 G5 Server
Can we install Windows XP in HP Proliant ML150 Server
That should be no problem. Install Windows XP Professional and also the service packs - SP2 (includes SP1) and SP3.
Oct 28, 2010 | HP ProLiant ML150 G5 Server
Enable RAID system
use this guide, this is fo the embedded sata raid controller that comes standar with the ml150 g5.
Enabling SATA RAID functionality in the BIOS Setup Utility: 1.Boot the server, and then press F10 to enter the ROM-Based Setup Utility (RBSU).
2.Go to the advanced tab.
3.Enter the IDE configuration or hard disk configuration.
4.Change the ATA/IDE configuration to enhanced or SATA controller 2 enhanced (if not available then use enabled mode).
5.Configure SATA as RAID or configure controller 1 as RAID.
6.F10 to save and exit.
7.Reboot the server.
8.During post f8 will now show up for the embedded SATA set up.
•Creating the RAID volume.
1.Enter the embedded SATA setup by pressing f8 during post.
2.Enter the array configuration utility.
3.Enter create array.
4.Create the raid volume as desired.
5.Save and exit.
i hope it helps you!!!
Aug 11, 2010 | HP ProLiant ML150 G5 Server
From where I can get LAN Driver for HP Proliant ML150 Model
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model computer and the XP or Vista Windows version of the drivers you require and install them. Use this link to download the drivers: -
http://h18000.www1.hp.com/cpq-country/cpq_support.html
Oct 28, 2009 | HP ProLiant ML150 G5 Server
I Install windows 2003 server on HP proLaint ML150 G5 not working
What means "then os is not working"? Was the system rebooting all the time, blue screen, a service was unable to start ...? The CPU fan is turning? Disconned the power cord and press power on for few seconds. Try another bootable CD. Is it still the same boot the system from a (bootable) USB Flash Drive or USB CD/DVD drive. Is this working?
Jun 06, 2009 | HP ProLiant ML150 G5 Server
Hi support, Am Kennedy.I just wanted to know how i can get a VGA card for Hp Proliant ML150 and what are the costs. Thanks and kind Regards:
Hi there ,
In a HP ml150 you can install a PCI VGA card subject to availability.Normally it comes embeded on the motherboard .But if other devices are installed on the same PCI bus its efficenciay will be dgraded to the PCI VGA card.
Jan 09, 2009 | HP ProLiant ML150 G5 Server
HP ProLiant ML150 G5  Server Logo
867 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
