Cell Phones Logo
Posted on Aug 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to erase pictures off my phone and it will not let me erase I may have put them on lock but I can't figure out how to unlock them
Anonymous
Level 2:
New Friend:
  • Expert 57 Answers
  • Posted on Aug 24, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
57
Questions
0
Helped
13508
Points
209
When viewing the picture there should be a way you can go into the options menu and there should be a unlock button within that menu. Also, some pictures come with the phone and can't be deleted.
2answers
How do I unlock a screen lock I didn't put on my phone without loosing all my data and pictures?
If you are going to remove the lock without knowing it then you have to compromise your data. No other option
1helpful
When i turn on my phone it goes straight to passcode and wont unlock
You, or someone else has put a passcode lock on your phone. If you do not know the passcode, try some simple ones, 1234, 0000, 1111.
be careful, there is also an option to erase the phone if you get it wrong 10 times, and that might have been turned on.
if you cannot figure it out, you have no option but to wipe it and restore from your backup
My cell phone is motorola WX345 call setting not available and phone lock off ,when I try to put phone lock on , need pass word I do not have ,I do not know old pass word ,I do not see any network ,...
Hello
Thanks for choosing Fixya and for the purchase!
From your descriptions it may seem that you're experiencing a network lock on your phone.You may need the unlock code which contains 8 -16 digits.This you can obtain from the link below although it may come with a price tag:
http://www.gsm-unlock.com/unlock/motorola/wx345.html
Try removing the Simcard and reloading it again and see what happens.Try it on another phone.
Another option is to try a hard reset on your phone.This includes restoring your phones settings back to factory settings.It erases the changes and data added onto the phone from the the day of purchase leaving it as it was when new.This process erases everything and its advisable to store your data on a secondary device before running the process.Here's how to:
Press menu > Settings > Restore factory settings.
Now,concerning the bluetooth connections:If you wish to repair the phone using a secondary device,make sure your phone's bluetooth power is on and ready.Power the second device and put it to pairing mode and then:
Press menu > settings > connectivity > bluetooth my space > inquiry new device.This lists the devices under your range .Select on the device and then press on pair..
Please let me know of the progress.
Thanks again.
Ken.
2answers
Unlocking phone xperia
Wooo hooo thank u everybody I figured. It out its hold cam button volume down and power button. To erase and reset
Jan 03, 2012 • Cell Phones
3helpful
2answers
How to unlock a picture
Go to the playback menu and select it (you may have to adjust the circular option know to get to the playback menu). Once there, scroll to the picture(s) that are locked by using the sideways selection arrow buttons. Then select the up or down arrows, which will lock or unlock your picture. You can also erase any locked pictures, in case you want to, by formatting the xD card. Hope this helps.
2helpful
Picture lock
Protected pictures cannot be erased using [ERASE],
[SEL. IMAGE] or [ALL ERASE], but they are all erased by
formatting.
• Go to Playback mode in the camera. Select the picture to be unlocked with the left or right arrow buttons, and to remove the protection select OFF with the up or down arrow button.
7helpful
2answers
I need to erase all my contacts but don't have the unlock code to do it...
Go to Menu, Settings, Security (The code is usually the last four digits of your phone number), Erase All, and select Phonebook. This should clear out the entire Phonebook. You can also erase all of your downloads and pictures there.
Aug 26, 2008 • Cell Phones
Factory ringtones
Sir,
You can lock your phone manually or set the phone to
lock automatically whenever you turn it off.
To use a locked phone, you must enter the unlock
code. A locked phone still rings or vibrates for incoming
calls or messages, but you must unlock it to answer.
You can make emergency calls on your phone even when
it is locked (see page 68).
Locking Your Phone Manually
Find the Feature > Settings > Security
> Phone Lock > Lock Now
Unlocking Your Phone
Tip: Your phone’s unlock code is originally set to 1234.
Your service provider may reset the unlock code to the last
4 digits of your phone number.
Setting Your Phone to Lock Automatically
You can set your phone to lock every time you turn it
off:
Find the Feature M> Settings > Security
> Phone Lock
> Automatic Lock > On
If You Forget a Code, PIN, or
Password
Note: Your phone’s 4-digit unlock code is originally set to
1234, and the 6-digit security code is originally set to
000000. Your service provider may reset the unlock code
to the last 4 digits of your phone number before you
receive your phone.
Press To
1 keypad keys enter your unlock code
2 OK (+) unlock your phone
> Phone Lock
Master
Clear
Clear all user settings and entries
except SIM card information, erase all
downloaded pictures and sound files,
reset all options except unlock code,
security code, and lifetime timer:
M > Settings > Initial Setup
> Master Clear
Caution: Master clear erases all
user-entered information (including
phonebook and datebook entries) and
user-downloaded content (including
photos and sounds) stored in your
phone’s memory. After you erase the
information, you cannot recover it.
Thanks
Good Luck
Don't forget to rate the solution
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
