Question about LG WD-14124RD Front Load Washer / Dryer
Clothes get wet when put on dry on lg wd 14123rd
5 Suggested Answers
SOURCE:
SOURCE: lg wd-14123rd Dryer Problem!
The DHE error in my case was due to blocked condensing duct and bellows with lint. I found I got an odor in the clothes when drying, and the unit would start drying at first, then show the error approx 5 mins into drying. It was missed twice by registered dealer repairers, I paid a fortune to get it flushed out, to have it recurr. I bought the online manual for $30 to show me how to get into the unit and now do it myself. If you are handy, take off the top and front covers, the condensor duct is on the right side of the unit and is plastic zig zaggy unit, and leads down to the bellow. I flush it out with water and detergent, then reassemble. The odor returns over time, and I know I have to repeat the process.
Posted on Jul 30, 2008
SearsTechToo
  • 261 Answers
SOURCE: washer won't spin dry clothes
What model is in reference here? Please post back with model number.
Posted on Oct 16, 2008
sonicboomele
  • 1557 Answers
SOURCE: i have a lg intellowasher 7kg wd-8015c (front
the water pump is sending a signal to the pcb telling it there is a fault clean the filters and wheel on the water pump
let me know how you went
sonic boom electronics
Posted on Dec 28, 2010
SOURCE: I just had the LG
I also have this unit with the same problems. After lamenting on making a poor purchase decision, I found somewhat of a solution. Basically, water is not being expelled during the dry cycle. When I addressed this issue, clothes were MUCH more dry than before. Made a quick video demonstrating the fix: http://www.youtube.com/watch?v=8EhzuzSk2Ok
Posted on Jan 03, 2011
Why my washing machine vibrate when spinning
if it only vibrates when in the spin cycle turn off the machine and cloths distribution re-balance you have to many heavy cloths on one side of basket. Turn it back on and let it continue this should solve your vibration problem
Jul 13, 2015 | LG Washing Machines
LG Direct drive having problems drying clothes
check on the water outlet pump beneath ,,,,,,if there is a sound while drying,,,maybe needs to clean the filter cup,
Apr 13, 2013 | LG WD-1070QDP 7 Kg Direct Drive Washer
I just had the LG WM3987HW washer/dryer combo installed on Saturday, and it will not dry our clothes. This machine is ventless and dries by dehumidification. The clothes are more dry at the end of the spin...
Nov 29, 2010 | LG WM3987HW Front Load Washer / Dryer
LG Intellowaster 2.08ft^3 (Fill with water while washing? yes/no)
no you wont see much water at all and make sure 2 to 3 tbsp of he detergent also
Jul 06, 2009 | LG Washing Machines
LG WD-324RHD stops at 6 minutes left in drying
Your timer has gone bad and you need to replace the time. Best bet is to get a Technician out there but you can do it yoursel. It is behind the face plate where it counts down the time
Feb 09, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Does not heat
"Steam drying will get how but the air that comes later to actually dry is cold so the clothes never dry"
I am assuming "how" means hot in this sentence, if so, I think I can help! There is no "steam drying" phase for your dryer so what is probably happening is; the wet clothes are being heated properly [as a result causing steam] however if this steam does not escape frum the dryer it will simply condense back onto the clothing [leaving them moist/wet].
Check your flexible tube from the dryer and the vent on the outside of your home to make sure they are unobstructed. Hope this helps!
Oct 13, 2008 | LG DLE2514 Electric Dryer
LG all in one washer dryer fills with water on the drying cycle
the unit is made to bring water in in the drying cycle ,,the water dont touch the clothes..the water is to take the lint away and to cool the drum,,you must remember that you can was 22 pounds but you can only dry 11 pound..so you must dry about half of what you wash..and drying the 11 pounds it will take 3 to 4 hours,,no exhaust...
Sep 21, 2008 | LG WD-3274RHD Front Load Washer / Dryer
Lg wd-3243rhd front load washer and dryer combo "le" error message
LE error code means the motor sensor has failed.  The motor sensor is located in the back of unit inside the motor.  You will need to order a replacement motor sensor from LG.  You will need a 17 mm and 10 mm socket tools to do this job.
Mar 17, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Lg wd-14123rd Dryer Problem!
The problem is in the heater assembly.  You will need to get a volt/ohm meter and find out where the problem is in the heater assembly.
Jan 22, 2007 | LG WD-14124RD Front Load Washer / Dryer
LG WD-14124RD Front Load Washer / Dryer Logo
47 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
