Question about SMC Barricade 7004
How do I open ports in the Special Application?
    Scholar:
  • 130 Answers
To access the application, you can open up the ports specific to the application in the special application, which is present in the router management screen as follows: 1. Open your web browser, type in the router's IP address (standard: 'http://192.168.2.1') and press enter. 2. Click on Login, Advanced Setup, NAT, Special Application. 3. Enter the port details and enable it as follows: Trigger Port Trigger Type Public Port Public Type Enabled 3724 TCP 3724 TCP Y 6112 TCP 6112 TCP Y 6881 TCP 6881-6999 TCP Y * The port numbers given are just an example. You need to open the ports depending on the application you are using and should get the information from the application provider.
Posted on Feb 19, 2006
Connect two tigerswitch 6724AL2 via fiber port
How do I open ports in the Virtual Server? pix.gif pix.gif pix.gif You need to forward the ports used by the application to the server running the application in the Virtual Server, which is present in the router's management screen, as follows.
  2. Click on Login, Advanced Setup, NAT, Virtual Server.
Private IP Private Port Type Public Port 192.168.2.x xxx TCP xxx 192.168.2.x xxx UDP xxx To access the application, you can open up the ports specific to the application in the special application, which is present in the router management screen as follows:
Jan 05, 2011 | SMC TigerSwitch SMC8612T
I cant open port for Zhone 6211-I3-200 Router
Some times you will need to open the Logical Ports on the router.
These are the logical ports.
For this you will need to open the set up interface of the router.
Once you open the set up interface of the router, you will be able to find the settings on the router where you can open the ports for the particular program.
If you are opening the ports for a special device in your network, then you must know the IP address of that device.
For example, wireless camera, DVR, X-box, Play station ...
You can choose the option PORT FORWARDING for a special device application.
If you just want to open the ports for all the network, then you can choose PORT TRIGGERING
Click Here
for more info
Dec 17, 2009 | Zhone 6211-I3-200 Router
I am trying to open the router ports to allow a ps3 to connect. when i try to play call of duty:modern warfare 2, i keep losing the connection. can you help me open the ports and configure the settings?
For example ,
You have a Linksys wireless router and you want to open the ports for the X-box.
You have opened the set up interface of the router. You will see Application and Gaming TAB at the top.
If you click on that tab you will find different Sub tabs.
Click on Port Triggering => Here you can open the port numbers for the network.
Click On Port forwarding if you want to open the ports for a special device in the network.
Click Save settings once you open the ports on the router.
Some of the recommended port numbers for different applications :
IMAP ==> 143 SMTP : 25
HTTPS ==> 443 HTTP : 80
DNS ==> 53 FTP : 21
SNMP ==> 161 TELNET : 23
XBOX ==> 53, 80-88, 3074
PS3 ==> 80, 443-447 ,5223, 3478-3479, 3658, 10070-10080.
WII ==> 28910, 29900, 29901, 29920, 80, 443
VPN ==> 1723, 500, 443-447, 10000-20000
World of Wars ==> 3724, 6112, 6881 - 6999
Click Here for more info
Dec 13, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
HOW TO DO THE PORTFORWARD
For example ,
DNS ==> 53 FTP : 21
Dec 06, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
Port Forwarding on NB7Plus4W router
For example ,
DNS ==> 53 FTP : 21
Nov 22, 2009 | NetComm NB5PLUS4W Wireless Router
Feb 19, 2006 | SMC Barricade 7004 Router
Special Applications
Some applications require multiple connections, such as Internet gaming, video conferencing, Internet telephony, VPNs, and others. These applications have difficulties working through NAT (Network Address Translation). If you need to run applications that require multiple connections, specify the port normally associated with an application in the Trigger Port field, select the protocol type as TCP (Transmission Control Protocol, UDP (User Datagram Protocol), or both, then enter the public ports associated with the trigger port to open them for inbound traffic. The Trigger port is an outgoing port (from LAN to WAN) that the application will send out. Step 1 Open your web browser and enter the IP address of your router (192.168.0.1). Step 2 Enter your username (admin) and password, if any. Step 3 Click on Advanced tab on the top and then Applications on the left side. Name - This is the name referencing the special application. Trigger Port - This is the port used to trigger the application. It can be either a single port or a range of ports. Trigger Type - This is the protocol used to trigger the special application. Public Port - This is the port number on the WAN side that will be used to access the application. You may define a single port or a range of ports. You can use a comma to add multiple ports or port ranges. Public Type - This is the protocol used for the special application. At the bottom of the screen, there are already defined well-known special applications. To use them, click on the edit icon and enable the service.
Feb 16, 2006 | D-Link Air Xpert DI-774 Wireless Router
Feb 16, 2006 | D-Link Air Xpert DI-774 (DWL-774) Wireless...
Feb 16, 2006 | D-Link AirPro DI-764 Wireless Router
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
SMC Barricade 7004 Logo
613 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
