I have an rca mod# F25652BL chassis# CTC187AB tv that keeps blowing the fuse. When I replace the fuse and plug in the tv the fuse blows at the same time just wondering what it might be
5 Suggested Answers
SOURCE: the tv keeps blowing fuses
Hi your problem is that a component(s) inside your TV has probably short circuited to Earth, this then causes a massive current to flow and this blows the fuse. Due to the types of Component failure from this, this TV should go to a reputable repair shop. Get a firm "Quote" and an explanation of what needs to be done.
Posted on Aug 15, 2007
SOURCE: proscan PS32610
yes
Posted on Sep 27, 2007
ctf1800
  • 4402 Answers
SOURCE: RCA MM52110 FUSE keeps blowing
should be covered under your insurance might give them a call.
other wise i would check the bridge rectifier,
Posted on Dec 05, 2007
ladywinn
  • 5138 Answers
SOURCE: rca projection tv serv#p56938yx mod#p56938 serial#c135c50tx chassis#ptk195s16p cant id
Here are some numbers to call for Flyback Replacement
Electronica 1-800-772-5578
Asti 1-800-221-1828
you will need RCA chassis# PTK195s16p - flyback number1541938b.
ThankYou for using FixYa. Have a Nice Day.
Posted on Feb 07, 2008
  • 3 Answers
SOURCE: blown fuse
Most likely there was a power event (surge, brownout, ect) that caused the power supply to fail in the TV causing the fuse to blow. you will need to have someone come and look at the unit and give you an estimate. If you keep putting fuses in and blowing them you could actually be causing more damage.
Posted on Mar 10, 2008
Tv keeps blowing fuses when its plugged in...
There should not be any reason for the new TV to blow a 15 amps fuse in the house.
The TV has an internal short circuit even if it is new, I would suggest to return it and get another one.
Good Luck.
Jan 06, 2009 | Televison & Video
RCA P60920BL 60 in. Rear Projection Television Fuse
I am assuming that you preplaced the flyback and horizontal out together. Even if you did, was it blowing fuses before? Usually with this chassis, the horizontal will not blow the fuse. It will just keep the swith mode power supply from operating. Double check and make sure you didn't have a soldered blob get away from the iron and "splash" somewhere on the board
Dec 23, 2008 | Televison & Video
Blows fuse
You may want to check the regulator IC. RCA had a lot of shorted regs
Nov 07, 2008 | Televison & Video
RCA R52WH74 (ITC222A Chassis)
no the board that has the FL231 on is the ITC222 deflection board. The other board is above the chassis in a seperate frame that runs across the set the convergence power supply is the board on the left above the board where the fL231 is. Yes the ITC222 and ITC222A are the same chassis. As for the service manual that site should have the service manual under the thomson category as the ITC 222 chassis is actually a thomson chassis made for RCA.
Sep 11, 2008 | RCA R52WH73 Projection Television
RCA D52W20 52 Fuse problem
Well you could always use a bigger fuse but I would not advise to do it, it could and most likely will blow tv not fuse. Fuses ussually blow from a short or power surge. If it is new or under warranty I would return it for replacement or repair.
Jul 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv model r52wm24
You most likely need a new convergence power supply board if fl231 keeps blowing thats the most likely cause, also check for shorthed capacitor cp231. If you need a link to get a replacement convergence power supply board, let me know I know where you can get them.
Jul 19, 2008 | RCA R52WM24 52" HDTV Projection Television
Tv model r52wm24
RCA tvs have to be diagnosed by the Chassis number. Please repost the chassis number and I may be able to help you out.
Feb 09, 2008 | RCA R52WM24 52" HDTV Projection Television
Dec 05, 2007 | Televison & Video
RCA CHASSIS CTC195K BLOWA SCR
make sure that the scr has adequate insulation. I have run into this problem before several times, and it always comes back to the scr and heatsink. check for shorts before you plug it in. unless you have an isolation transformer, do not hook up ac powered equipment to chassis ground, as this will blow your transistor again. use dc poweered volt-ohm meter.
Jul 31, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Electro Med Services...
