Question about Zoom X6 Adsl Wireless Gateway Rohs Router
Security Settings Can anyone please tell how to set up the security on my Zoom X6 router? I have tried the website that came with the instructions but it woudnt work. Can someone please tell me if there is an other way. Thanks
  • g3kiq Sep 10, 2008
    can not get the security wep to work typing 10.0.0.2 dosnt work
  • montyb20 Jan 10, 2009
    cannot connect to web site 10.0.0.2 to secure wireless
It turns out to be remarkably straightforward. Just connect to the router with an ethernet cable and you can set up the security -- it can't be done wirelessly.
Posted on Oct 24, 2008
Can someone help me, i want to set up security on this router, i type in the password on ithe screen , and it will lock, but then i cant connect
any advice
Posted on Oct 16, 2008
Type in http://10.0.0.2 right at the top of your brouser,not in google but right at the top where it says http://www.google etc. delete this and put you ip no (10.0.0.2) in its place
jack
Posted on Sep 10, 2008
I have ipod touch,3 GB. I am not able set up WiFi connetion to my Zoom ADSL X6 router. I enter the pass word but it keep rejecting the connection. I have three other PC that seems to connect remotely with...
You could try restoring your Ipod touch to factory settings and then retrying to connect it to your wifi. Or your wireless card receiver may be broken.
Mar 01, 2011 | Zoom Computers & Internet
My iPhone does not connect to the Zoom X6 DSL modem. I can connect my laptop and a couple other wireless devices but not my iPhone. Is there a setting I should change either on the router or on my iPhone?...
there is 2 possibility 2 change in router first WEP or wpa security code if in your router need password for connect it then you need to find that key code to enter in iPhone.
Second if in router MAC filter is enable then you need to add your iPhone MAC address in allow list of router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
First find the mac address of your iPhone in network setup menu then add that mac id in mac filter of router configuration menu.Then save settings and check.
Let me know if you need further assistance.
Thanks for using FixYa.
May 05, 2010 | Zoom X6 (5590) DSL Modem (55900003)
Can't connect ipod to Zoom adsl x6 modem.
I found if I removed the WEP security on an X6 the Ipod connected without any problem.
I tried WPA and WPA2, and these won't connect either.
The password it wants it the one you used to generate your WEP code when you first set up the router. If you don't know what that is, then you'll have to reconfigure it with anew one.
Also, an IPod Touch may connect if you choose Other connection in it's network settings, and then tell it to connect to WEP.
Jan 03, 2010 | Zoom Computers & Internet
Zoom X6 ADSL- Setting Security Settings
Yes .... problem now solved. Helpful guy from Zoom got back to me, but the real issue was ..... you must (with talktalk at least) use your IP password as the Passphrase. So the instruction to select a Passphrase is understated. It needs to be more specific. I used the WPA 2 setting in the Zoom Webpage Device Wireless Setup, and then the WPA2-personal, in Zoom Newtwok Properties Section on my PC.
Dec 11, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Security password
http://www.zoom.com/techsupport/adsl/adsl_x6.shtml
Go there and download the manual, its easy to setup a password, just follow the instructions on the manual.
Good luck
Dec 04, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Zoom X6 Adsl Router
You must assign a static IP address on the Xbox 360 that it is outside of the Zoom X6 router's DHCP pool. Also, the Xbox 360 must be in a DMZ. This will prevent the firewall of the router from blocking connections to the Xbox 360.
  1. Assign a Static IP address on the Xbox 360 console:
    • Power on your Xbox 360 and go to the System area.
    • Select Network Settings and then Edit Settings.
    • Select IP Settings. The Edit IP Settings screen opens.
    • Select Manual and then enter the following settings:
      • IP Address: 10.0.0.150 (or any 10.0.0.x IP address, where x is between 100 and 250)
      • Subnet Mask: 255.255.255.0
      • Gateway: 10.0.0.2
    • Select Done, to go back to the Edit Settings screen.
    • Select DNS Settings. The Edit DNS Settings screen opens.
    • Select Manual and then enter the following setting:
      • Primary DNS Server: 10.0.0.2
      • It is not necessary to enter a Secondary DNS Server.
    • Select Done.
    • Power down your Xbox 360.
  2. Access the Zoom Configuration Manager:
    • From a computer that is connected to the Zoom X6, open a web browser and type http://10.0.0.2 in the address line and then press Enter (or Return).
    • Enter the User Name and Password (in lowercvase letters):
      • User Name: admin
      • Pasword: zoomadsl (where "l" is a lowercase letter L)
  3. Create a Virtual Server rule to put the Xbox 360 on a DMZ:
    • In the Zoom Configuration Manager, click on the Advanced Setup icon at the top page.
    • Click on the Virtual Server/DMZ button.
    • On the Virtual Server/DMZ page, enter the following settings:
      • Internal IP Address: 10.0.0.150 (or whichever Static IP address you selected per Step 1)
      • Protcol: DMZ
      • Start Port: 0
      • End Port: 0
    • Click Save Changes
    • Click the Enable box, if you have this option.
    • Click Write Settings to Flash
  4. Plug the Xbox 360 Wireless Networking Adapter in to the Xbox 360 console. If you are not sure how to do this, please refer to the manual that came with the Adapter.
  5. Select the Zoom wireless network on the Xbox 360. (Note: The following steps assume you have a working wireless network with WEP or WPA security enabled and you know the Key and SSID of the network. If you have not done this, please refer to theFAQ on setting up a wireless network with the Zoom X6.)
    • Power on your Xbox 360 and go the System area.
    • Select Network Settings and then Wireless Network.
    • Enter the SSID of your network
    • Enter the Security Key for your wireless encryption. This must be either WPA or WEP. If you use WEP, you must enter the HEX digits for the Key you are using.
    • Power the Xbox 360 off, wait a few seconds, and then power the Xbox 360 back on.
    • Go to the System area.
    • Select Network Settings.
    • Select Test Xbox Live Connection. If everything is configured correctly, all the tests will show Pass.
  6. Congratulations! You can now enjoy your Xbox 360 with Xbox Live.
May 23, 2008 | Zoom X6 Adsl Modem/router Rohs...
Zoom x6 model 5590 wireless router
Make sure the Connection Type is set to Static IP on the setup page of the router
Mar 10, 2008 | Zoom X6 Adsl Wireless Gateway Rohs Router
I can't get my itouch to work with my Zoom X6
Okay... Its really simple. This worked for me. Click on "Forget this Network." Then go back to "Choose Network" and manually type in the network name (with caps if necessary) and type in your WEP Password. It should give you an new IP address, as well as the Subnet Mask, Router Name, and DNS Address...
Hope this helps!
Dec 10, 2007 | Zoom X6 (5590) DSL Modem (55900003)
X6 modem router
Your ISP probably has some setup requirements from the modem side of the router that will need to be identified.
Users guide is here which may help
for general wireless security see
http://www.fixya.com/support/t281214-wir...
Nov 13, 2007 | Zoom (5590-00-03) Wireless Router (G66115)
Problems with xbox 360 wireless adaptor, finding zoom x6 router
For this problem use http://zoom.custhelp.com/cgi-bin/zoom.cfg/php/enduser/std_adp.php?p_faqid=929&p_created=1193678463&p_sid=NcYTzXmj&p_accessibility=0&p_redirect=&p_lva=929&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MjEsMjEmcF9wcm9kcz0yNSwxMjcsMTY5JnBfY2F0cz0wJnBfcHY9My4xNjkmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PVdpcmVsZXNz&p_li=&p_topview=1
Oct 15, 2007 | Zoom X6 (5590) DSL Modem (55900003)
Zoom X6 Adsl Wireless Gateway Rohs Router Logo
124 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
