Question about GE Zoneline AZ55H07D Air Conditioner
Compressor wont start!
I have several ptac unit made by carrier and they will not start due them not being serviced properly i got many solutions i think. Ive tried to ohm them out i got a correct reading from herm to common terminal and run to start but when i tried to start them the compressor make a buzzing sound what should i do?
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Take the overloads (on top of the compressors ) out the system, and run it now. or just buy a compressor hard start-kit! $10.00!
Posted on Sep 08, 2008
What does error e8 mean on a carrier thermostat the outside unit want run what do I do?
call a service technician for a proper diagnostic check
could be a power board affect by vermin or a start run capacitor for the compressor
Sep 29, 2016 | Carrier Heating & Cooling
Desert master carrier ac compressor is leaking and due to leakage it is taking too much ampere due to it trips the breaker. what i have to do change only the compressor or the whole unit?
If only the compressor is faulty then you can repair it by just changing the compressor. This is a specialist job that requires specialist equipment and you wont be able to do it yourself unless you have this equipment. I suggest you contact a refrigeration repair service and get them to check it out.
May 25, 2016 | Carrier Heating & Cooling
Ptac unit wont cool
Check unit's ID#'s and add any hyphens, etc or separate letters, numbers, to be exactly what's on unit.
Inside sources might help. Popular Questions Answers Tips Manuals for Carrier 52CE215 Cool Electric...
Questions Answers for Carrier heating element
Feb 11, 2015 | Carrier 52CE215 Cool Electric Heat Air...
GE PTAC 5500 series cooling and then blowing hot
Cooling gas is missing. Call some AC service in near to fill it, ask more of them for price. Do not switch it on until you solve this to prevent higher damage.
Aug 28, 2014 | Heating & Cooling
Compressor will not get started. It clicks or just does not start
No that is not the solution, it the capacitor were bad, then it wouldn't start manually.
You need to be looking elsewhere. The problem may be in the refrigerant level. Those units are supposed to have pressure switches.
Check elsewhere such as pressure switches and make sure the thermostat is working properly.
Go to the thermostat and jump out R to Y. If the unit comes on, your thermostat is the problem.
Jan 23, 2010 | Carrier 38CKC036 Air Conditioner
I had a lightning storm tonight, power flickered several times. Now neither of my compressors kick on. There is a troubleshooting board inside, but not sure what the codes mean. It is a carrier 24ACA
The contactors on each unit were stuck closed. I shut off power to the units for about 2 hours. I went back out and checked and the contactors had released. I re-powered and they started up. Great solution, but didn't really do anything.
Oct 06, 2009 | Carrier 38CKC042 Air Conditioner
Amana ptac- blows same temperature air whether its set at 80 or 65...any ideas?
Check to see if your compressor is running. Thre are 5/16 screws on either side of the unit holding it to the case. Take those out and you can get to the cpmpressor. These are not complicated units but you may have to have a service tech look at it for you. I do sell a lot of these PTAC units so if your compressor is running you have leak or bad compressor. Russ
Jul 23, 2009 | Amana PTH123B25AM Air Conditioner
AMANA PTH153B35AE PTAC Temp drop??
PTAC temp drop should be 20 to 25 degrees across the coil. They never put a service tap on these units. I sell Amana PTACs. You may be alittle low on gas. Check your air TD and that will tell you. The compressor may be overheating due to lack of cool gas to cool the comp. May need a service tech but get a free estimate first. Rus
Jul 04, 2009 | GE Zoneline AZ55H07D Air Conditioner
Carrier PTAC Condenser ices over.
You are describing normal operation for a heat pump unit.
Feb 20, 2009 | Carrier 52CQ315 Air Conditioner
Charging a ptac unit?
Full service both coils first ,add your filter, then add a line temperature probe in the supply air flow or on the line going to the compressor add freon till you get the lowest temperature nad then it will start to climb, you've had the correct charge,!
Sep 08, 2008 | GE Zoneline AZ55H07D Air Conditioner
GE Zoneline AZ55H07D Air Conditioner Logo
277 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
