Question about Sharp Office Equipment & Supplies
What does the 'L' mean on the display window of the copier? It will not copy.
  • 2,120 Answers
USUALLY Bad Laser / Scanner Unit.
Posted on Sep 09, 2008
Display panel not powering
Is there any noise when you switching on the machine similar to its ready mode noise,
Check machine by pressing Copy button to make copies if it copying and working means your display only faulty or...
If it is not copying or not working means it has problem in Main board check RAM and Boot Flash Rom
Check Boot Rom correctly may be boot ROM faulty
Feb 08, 2013 | Canon imageRUNNER C3200 Color Printer
Hallow there. if you press copy key it should show 02 on the display meaning a problem with copy lamp. Please check the optical unit area for the following;
  • Check that the copy lamp board is well connected to the main board .
  • Check that copy lamp is lighting.
  • Check the document glass is well locked with the white part secured with screws.
If all the above is okay, then switch it on and work.
Jan 07, 2011 | Sharp AL 1631 Copier
On canon iR 1020, i cannot print and make a copy
Do you mean that you have blank copies/prints, or that there is some message on display, or just blinkig red led...?
If yyou have blank copies the problem is in laser shutter.
If you have error message send detailed description.
May 21, 2010 | Canon NP 6035 Copier
E-5 light is on. What does that mean? Can't use copier at this time.
When the copier detects the E507 condition, "E-5" is displayed in the copy counter. Hold down the "·" key, and "07" is displayed in the copy counter.
for reset thiscode.
It would be necessary to know as it is the code to be able to help it better
Mar 25, 2010 | Ricoh FT5832 Copier
What does ap mean
"AP" stands for Agitation in Process", it appears in the copy quantity display when toner is being replenished inside of the copier. Wait a few minutes..this happens after continuously copying for long periods, or copying dense things like photos. Sometimes it will occur after running the machine when it is out of toner. replace toner and turn on/off a few times to "agitate toner. Don't worry about the scan lamp being lit while this is happening, it will go out.
Hope this helps
Sep 08, 2009 | Copystar CS-1810 Copier
We have a Sharp AL-1641CS Copier and it does not want to copy. On the display window it shows L1. What does this mean?
this a problem with the scanning section the lense motor is not moving is stock or broken check for opstraction if not the lense motor is broken
Jul 07, 2009 | Sharp Office Equipment & Supplies
AR201 displays e7
Could you be more specific? e7-03 is trouble in your laser unit, e7-04 is dirt on your inside white strip which helps your copy lamp find the home position, and e7-05 is trouble with your copy lens.
Apr 28, 2008 | Sharp AR 201 Copier
How to re-set so that "Another Original? No-Yes" does not display after making one copy
You can look in the user's settings. But, I have not seen that display not show or had anyone ask about it.
Feb 06, 2008 | Panasonic Workio DP-2500E Copier
23 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
