Question about DCS RGS-305 Professional Gas Kitchen Range
Electric ignition electronic ignition wont shut off after burner lights
  • pietrov Jan 08, 2009
    i have a dcs range same problem after burner is lit igniter stays on ?
  • Steven DelFavero Feb 05, 2009
    ignitor stays on
I had the same problem. Putting together many of the posts here, I discovered that the ignitor shuts off when heated by the simmer flame. So, I took a manual lighter and held it to the ignitor and the ignitor stopped. Took it away and it started again.
I could see that the simmer flame wasn't working on that burner, so I dug into finding out why. Took apart the burner and found that there was no gas coming out of the separate tube feeding gas to the simmer flame. The jet was clean, so I removed the tube and found that it was completely clogged with something that was like sticky grease or rubber cement.
I cleaned out the tube with goof off and a rubber-coated wire, then put it all back together. Works perfectly now.
Hope this helps.
Posted on Mar 31, 2009
I want to know more about your business I repair restaurant commercial equiptment please respond maybe I can help
Posted on Sep 12, 2008
Why wont the left and right burners lite using the electric ignitor?
Are the igniters for those burners sparking?
Aug 29, 2014 | Grilling
Goodman furnace Model GDS80703AXBB -fan comes on then igniter light comes on, then burners turn on but shut off right away and wont stay lit. Now igniter light wont come on so burners not coming on at...
Sounds like either the flame sensor is not working.
The sequence for starting the furnace is:
1. extraction fan on
2. pressure sensor (for fan)
3. ignitor (spark or glow plug) comes on
4. gas valve opens up
5. ignition of flame
6. flame sensor (or temperature sensor)
7. plenum temp. sensor
8. main fan starts
It is most likely that the flame sensor is dirty or gone,
or (and I hope not), the module is gone and needs to
be replaced.
Sep 10, 2017 | Heating & Cooling
Thermador over two left burners will not provide gas when knobs are turned. Also the oven will not light and the igniters on all burners will not spark. The electric is good to the appliance oven fan
You have multiple problems! First the single igniter that fires in all of the burners is either broken or disconnected electrically. Second, your gas lines or nozels at some of the burners are clogged. Check for cloggs by using a match as you light ONE BURNER AT A TIME...If they all light you only have the electronic igniter to troubleshoot...Have a repairman check it out for you if you don't feel confident with gas!
Dec 21, 2012 | Kitchen Ranges
WHERE IS MY PILOT ON MY FRIGIDAIRE FGF368GM
Hello, There is no pilot..It uses ignitors to light. number 19 in this picture is the oven ignitor http://lookup.bellparts.com/diagramenlarge/frigidaire/47877/00000358
If when you turn on the oven it doesnt glow bright orange chances are it failed and needs to be replaced. The top is electronic ignition. If this helps please rate me..Thanks
Jun 08, 2011 | Frigidaire FGF368GM Kitchen Range
Thermador rdss30rs xlo burners don't light and right side burners don't light either. can light right side with lighter. while burners are on igniter spark continously.
IF THE BURNERS DO NOT IGNITE
• Are the burner caps properly aligned and seated in the burner bases?
• Are the burner ports clogged?
• Is a fuse blown or is the circuit breaker tripped?
• Is the manual shut-off valve closed, preventing the flow of gas?
Jun 29, 2009 | Thermador RDDS30 Dual Fuel (Electric and...
Electric igniters dont shut off
Remember to turn the control knob past the "LITE" setting once the burner fires.
If that is not the issue you have one or more defective spark switches.
Each valve has its own switch wired in series with the others.
Mar 12, 2009 | Wolf Manufacturing Gas Kitchen Range
Gas burners/electronic ignition
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jan 26, 2009 | Tappan TGF657 Gas Kitchen Range
Cooktop's electronic igniter started clicking all by itself
Check to make sure your burner caps are aligned. I had this problem, and it turned out one of my burner caps was slightly askew. Putting it level fixed the problem.
Jul 25, 2007 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Gas kitchen range
Most problems with gas ranges have to do with the flame--either it isn't quite right or it's nonexistent. Most new gas ranges have "electronic ignition," a spark igniter that starts the flame as gas flows through the burners. If, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repairperson. If your range has a pilot light, be sure the pilot light is lit.
Jan 18, 2006 | Crosley CE35100AA Electric Kitchen Range
DCS RGS-305 Professional Gas Kitchen Range Logo
480 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
Paul Carew
Sal DeAngelo
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
