Please check the coils if it's icing and double check the vents to make sure that the air flow is not being blocked causing the temp in the refrigerator not to cool.
If you've cleaned the coils and the vents and the same is happening it could be a faulty defrost timer, defrost heater or the defrost thermostat. Have you checked if the fan is spinning because if the fan does not spin it could not be circulating the cold air causing the fridge to be warm.
Hope this helps!
Your Refrig/freezer should be set as follows:
Refrigerators: 36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
Then check the door seals around the edges to see if any splits, tears or cracks have messed up the seal. This will cause your compressor to constantly run as it's trying to cool off the warm house is being sucked into the freezer (or Refrig). A sure sign the door seals are damaged is lots of ice in the freezer door area or water pooling in the bottom area of the refrigerator.
Wait about 4 hrs after you readjusted the Refrigerator/Freezer settings so everything settles down. If you still have problems then the coolant may need to be serviced (topped off) or the motor serviced/checked.
Don't procrastinate because a water heater and Refrig/freezer are the 2 largest energy users in your home- they run 24 hrs a day.
Hope this helps...
