Question about Hotpoint Dryers
Took my Hotpoint VTD60 apart - cleaned out enough fluff from inside machine to stuff a horse... the Drum is now turning again - HOWEVER ... Could you explain how the Drum is meant to be secured at the back?. It looks like a very short spindle is meant to sit in a hole in the back panel. I think a silver washer that fell out sits over this short spindle/ Problem is that the spindle keeps falling out and the drum ribs against the panels
  • 374 Answers
You need a rear drum bearing kit. Go to any online parts source such as partsselect.com and do a search using your model # to see exact part and a reasonable price you look to spend on the part. I hope this helps you.
Posted on Sep 09, 2008
Error code f-13
Do u want to resolve the f-13 fault code ON HOTPOINT WD860 Ultima and other models.
Fix the fault . It is a tricky job but the heater thermostat switch has tripped as it senses something burning. Probably a little bit of fluff on the heater element inside the heater unit.. There are 2 switches on top of this heater unit. One where the 2 blue wires go on the top left of the 3rd picture and the other which has a tall black wire connector on shown in the middle of the 3rd picture. Remove that connector and undo the holding screw . You can then reset the switch. The switch is a small circular switch hidden beneather the connector on the photos. This thermostat switch has a yellow. red dot ontop of it. If you use a small pin or needle and press into that dot you will hear it tick back into place. you have reset the switch now. You will probably need to clean the inside of the heater element unit to get rid of the fluff particles or it will keep switching off. To take this apart you will need a set of Star screwdrivers. Its a bit tricky but you will be able to undo the star screws and take them all out. I will add some photos to show you the unit apart. You can see the build up of fluff on the photos i have added from my hotpoint WD860 heater unit. This is a tricky job and takes about an hour due to the screw being awkward to take off and put on again but mine hasnt faulted for 2 years since sorting it out. You can buy a new Thermostat switch which is about 10 pounds sterling from Hotpoint or other spares stores. error-code-f-13-04t3bj0jgktmuqmnt3s3ejb0-2-0.jpg error-code-f-13-04t3bj0jgktmuqmnt3s3ejb0-2-2.jpg error-code-f-13-04t3bj0jgktmuqmnt3s3ejb0-2-5.jpg error-code-f-13-04t3bj0jgktmuqmnt3s3ejb0-2-9.jpg error-code-f-13-04t3bj0jgktmuqmnt3s3ejb0-2-14.jpg error-code-f-13-04t3bj0jgktmuqmnt3s3ejb0-2-20.jpg
Dec 07, 2014 | Hotpoint Ultima WF860 Front Load Washer
How do i find the fluff filter
usual places are:- the inside of the door or inside the drum at the back. The fluff will look formed and like it's some sort of filter. if it pulls apart easely then its the fluff.
Sep 30, 2014 | Washing Machines
Hotpoint WD860 for F-13 solutions
It is a tricky job but the heater thermostat switch has tripped as it senses something burning. Probably a little bit of fluff on the heater element inside the heater unit.. There are 2 switches on top of this heater unit. One where the 2 blue wires goon the top left of the 3rd picture and the other which has a tall black wire connector on shown in the middle of the 3rd picture. Remove that connector and undo the holding screw . You can then reset the switch.
be91b32f-a289-4249-a4d0-499e2094e901.jpg 95adeccb-a83d-4edc-99a4-f08bf4669b6c.jpg 8af03867-1caf-4748-adb6-379e0dca1507.jpg fd076e29-d1d9-414a-8a0d-c18654b08aab.jpg ab17c040-2aaf-46c0-b85b-42e5d4817547.jpg cdb28245-18ee-4848-a36d-4442ca167988.jpg 7519e7ee-6f39-4388-bec5-585c0a700bac.jpg f6a153c9-ad70-4e8b-a3b1-b7570b07311c.jpg
Mar 28, 2014 | Hotpoint Aquarius WD640 Front Load...
My hotpoint waher dryer edd960 keeps flashing f13 on cuts out drying half way through, what is the problem and can i fix it myself? if not how much it cost ish? thanks
Do u want to resolve the f-13 fault code ON HOTPOINT WD machines
Original pictures not showing. hotpoint-waher-dryer-edd960-brswrwcy453xu5qdcnkktuei-3-0.jpg hotpoint-waher-dryer-edd960-brswrwcy453xu5qdcnkktuei-3-2.jpg
Feb 09, 2011 | Dryers
F:13 COMES UP ON THE DISPLAY WHEN THE CYCLE FINISHES. YOU HAVE TO TURN OFF THE MACHINE WHEN IT F:13 IS DISPLAYED AND IT TAKES A WHILE FOR THE DISPLAY TO COME BACK IN THE MACHINE AGAIN.
f13 is a Dispenser circuit error
If the dispenser motor is not able to be driven to it's proper position.
Check mechanical linkage from dispenser motor to the top of the dispenser.
Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
Check Dispenser Motor
Thanks for using FixYa!!
Jan 09, 2011 | Washing Machines
We have F-13 flashing. Can you please advise what
Error code F13 indicaters dryer fan or dryer thermistor faulty.
These are to be be found in the top of the washer on top of the heater manifold.
To access them remove top cover.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Aquarius WD640 Front Load...
Got lots of fluff under the drum
You will find the filter at the rear of washer..
Remove rear lower panel, on right you will see a large black hose that goes to the bottom of drum,
Undo clip that secures hose, and remove hose, be careful as there will be some water run out.
Remove plastic filter and ball inside hose, and clean filter, replace and fit hose back onto tub, making sure it is on properly.
Test for leaks before you refit rear panel back on.
You may have to repeat the process more than once if there is a lot of fluff present.
Plz rate my solution.
Thanks
Jan 08, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint few 12 first edition
Its either behind the kick plate or in the pipe which runs from drum to pump at the drum end.
Dec 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint Aquarius WD22 Dryer functions, as in turns and blows, but NO hot air
The only thoughts that spring to mind, are either...
A: The dryer heater has packed up.
B: The tube/funnel that the air flows through to the drum is blocked with fluff.
In either case you'll need to take the lid and sides off, locate the dryer duct then find a way of opening it to clean the fluff out.
If you need any more help, message me.
Nov 16, 2008 | Hotpoint Washing Machines
Dryers Logo
296 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
