Question about SMC Barricade 7004
How do I Login to the Router? - SMC Barricade 7004
    Scholar:
  • 130 Answers
Open a new browser window and in the address bar type in 'http://192.168.2.1' or 'http://192.168.2.1:80' or 'http://192.168.2.1:88' and press enter.
Posted on Feb 19, 2006
SOURCE:
Password recovery for ZyXEL3480wfy
ZyXEL Router Passwords
Finding your ZyXEL router's user name and password is as easy as 1,2,3.
  1. Find Your ZyXEL Router Model Number
    Look in the left column of the ZyXEL router password list below to find your ZyXEL router model number.
  2. Find Your ZyXEL Router Username
    Look one column to the right of your router model number to see your ZyXEL router's user name.
  3. Find Your ZyXEL Router Password
    You know the drill. Look another column to the right to find your ZyXEL router's password.
Great! You've found the password and username for your ZyXEL router! What next?
Login to Your ZyXEL Router Using the Router Password
Try logging into your ZyXEL router using the username and password.
Don't Know How to Login to Your ZyXEL Router?
You can login to a ZyXEL router in three easy steps:
  1. Find Your ZyXEL Router IP Address
  2. Enter Your ZyXEL Router IP Address Into an Internet Browser's Address Bar
  3. Submit Your ZyXEL Router Username and Password When Prompted By Your Router
=============== OR: ===============
Forgot Router Password?
If you are having trouble logging in to your router, there is a good chance that your router's user name and password are still set to the default settings.
What should you do?
Login to Your Router Using the Default Router Password
Try logging into your router using the default username and password for your router.
Don't Know How to Login to Your Router?
You can login to a router in three easy steps:
  1. Find Your Router IP Address
  2. Enter Your Router IP Address Into an Internet Browser's Address Bar
  3. Submit Your Router Username and Password When Prompted By Your Router
For more information on how to login to your router please see our Free Guides.
Still can't login to your router even when using the default username and password for your router?
Reset Router Password To Default Settings
(Use this as a last Resort!)
Find Your Default Router Password
Simply select your router manufacturer from the list below to display the default router passwords and usernames.
Nov 02, 2014 | Zyxel Computers & Internet
Login failed
if ever you know how to configure WAN and lan again, i would recommend to reset the router.
to reset router: put router on power, press the reset button, most of router manufacturer hides this button to avoid accidental press. in this case, you can use a pin to press it. once pressed, the led will all blink together. you are now in factory default of your router and you can start a fresh configuration.
Oct 04, 2013 | D-Link Dir-600l Wireless N 150m Home Cloud...
Forget my router password
if you forgot your wireless password or your router password then you can login to your router from your browser by going to 192.168.0.1 the default router login is admin/password or 1234.
go to wireless and then you can change your security password.
if you are unable to login to the router from a browser then you will need to reset your router to factory settings by holding the reset button in with a paper clip for 30 seconds while powered on. then login and reconfigure your settings. you will need to reconfigure all your wireless devices to join your wireless network after this is done.
Feb 23, 2012 | D-Link Computers & Internet
I need connect a wirelees router a this modem,u help me plzzz
most wireless routers are setup for cable modems out of the box all you need to do is run an Ethernet cable from your modem to your wireless router. you can then access your wireless router by the ip address and a pc hooked you directly to the router.
Feb 28, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I forgot my user name and logon domain
If you've forgotten the Router password, then press the Router Reset button (a small point) located next to the Ethernet port on the Router to restore the Router to factory settings.
After resetting the Router to factory defaults, use the default name and password.
Router Login: http://192.168.1.1
Login Name: admin
Login Password: password
Jul 02, 2010 | NetGear WNR2000 Wireless Router
Change router settings
hi,
in the browser type 192.168.1.1 and insert your login and password. if you have not change the login name and password then visit to your manufacturer site for default login name and password.... Usualy default login name and password is "admin".....This page will lead you to the router settings....
Hope this has helped you..
Thanks...
May 15, 2010 | 3Com OfficeConnect Wireless Router
Lost my password for d-link dsl300t how do i fix
You just need to press RESET button on the back of the router. THis will reset router back to factory settings. then open internet explorer and type in address 192.168.1.1 - press enter key. THis will bring up the login screen for router
Default login and pw are
Login: admin (or maybe Admin)
Pw: admin (or maybe Admin, or blank)
Login and setup router
Oct 16, 2009 | D-Link DSL-300T Modem
Installation of the wirless key
You can install/secure/encrypt your wireless network by login to your Router.
First login to your wireless Router. Refer the User Guide to get the exact steps to login to the wireless Router.
In gereral, 192.168.1.1 or 192.168.0.1 is the default Router login address. The defult username will be 'admin' and pasword will 'password'.
Go to the Wireless settings option in the Wireless Router configuration and enter/add the wireless password/passkey.
Good Luck!!!!!!!!!!!!!!!!!!
Sep 09, 2009 | Zyxel Prestige 600WH Wireless Router...
Belkin wireless router f5d6230-3 login error.
Because default password is not working.... Please Re-set your router in order to re configure it. Press the re set button for 1 min (tiny hole at the bottom)
Hope this info hrlps
Mar 21, 2009 | Belkin (F5D6230-3) Wireless Router
SMC Barricade 7004 Logo
233 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
