Question about Konica Office Equipment & Supplies
Konica 8020 color copier: image transfer roller unit needs to be replaced , Replaced but it is not able to recognise the change
  • Konica Master
  • 6,117 Answers
Because you have to go into service mode and clear the counter.
Utility then meter count then stop00 stop01. then touch counters then touch life clear the transfer roller.
Posted on Jan 17, 2015
  • 461 Answers
SOURCE: Buying and replacing just the transfer roller on a Dell 5110cn
Maybe if you call you can order just the transfer roller. You could try removing it and cleaning the ends (to provide better electrical contact). You could also try wiping the roller itself with a lint free dry cloth - but do so at you own risk and never touch the roller with your fingers!
Posted on Dec 09, 2008
  • 12 Answers
SOURCE: Reseting counter after installing new image transfer roller unit
You need to go into tech rep mode to reset.
press: stop 0 0 stop 0 1, then 0 0 0 0 0 0 0 0, press enter, then press counter on the left, select life, then highlight image trans roller and press the C button, repeat for paper dust remover and exit tech rep mode
Posted on Apr 06, 2009
  • 12 Answers
SOURCE: Imaging Unit Problem with bizhub C450
On the end of the image unit you will find a white bit of plastic with a small screw in the middle, make sure this screw is tight and then reinstall the units(give the units a bit of a shake too)
SOURCE: Can i reset my Konica Minolta C250 transfer unit
On your transfer unit there is a .80 amp fuse you can replace. this will reset your belt. make sure you use .80 amp or it will not work. on your fuser there is an inline 1/16 amp fuse next to the plug you can replace for that.
Posted on Oct 01, 2009
  • 15 Answers
SOURCE: Replacing Image Transfer Roller Unit & Paper Dust/Ozone Remover
hi this unit located in the RIGHT DOOR
Posted on Jan 15, 2010
Color printing is printed with a yellow background in bizhub c450
have you replace the Transfer belt.??? It also has a transfer roller for yellow. (Called First Transfer) since it is transferring yellow off the drum. You have replaced the yellow image unit???? 2nd transfer is to the paper!!!
May 18, 2016 | Konica Minolta bizhub C450P Laser Printer
How to clear notification transfer roller needs to be replaced soon.
1. Touch Menu.
2. Touch [Counter].
3. Touch [Display Keypad].
4. Press the following keys in this order.; Stop -> 0 -> 0 -> Stop -> 0 -> 1
5. Enter the CE password and touch [END]. (IF required)
6. Counter
7. Life
8. Transfer Roller Clear
Nov 19, 2015 | Genuine Konica Minolta Konica Minolta...
I have a Konica C250 machine which cannot print red color at all. I had changed the toner and image unit but still cannot print red color. How can I solve this problem?
Recommended that you have a tech come out and look at it might have a bad LED assy. for the Magenta Image unit. All other color print OK? Can you print gradation test pattern for each color in service mode? Meter count, details, stop 00 stop 01 Test Output Gradation pattern select magenta. If you open the side cover after printing a document with the color magenta try to catch a print of paper do you see the color magenta on the transfer belt if yes the drum is ok could be the transfer belt magenta 1st transfer roller on the belt replace the belt assy.
Oct 28, 2015 | Konica Minolta BizHub C252
After replaced transfer belt unit its error 2152
Open close front door. to reset. Ensure belt was install properly the code is for that device also check the transfer roller sponge one. ensure shipping parts remove before installation.
Jan 31, 2014 | Konica Minolta Konica Bizhub C353 Drum...
I have a Konica Minolta bizhub C351 that has an error message " transfer roller unit needs to be replaced soon" I purchased and replaced the "image transfer roller unit 4049-411 that also has the nu
Enter in the service mode:
Press Utility key - Meter count - Details - Counter mode - select present parts life and reset(clear) the transfer roller counter.
Mar 25, 2013 | Konica Minolta bizhub Office Equipment &...
I have a Konica Minolta Bizhub C350 which is now indicating that it needs to have the image transfer roller unite and paper dust/ozone filter replaced. Where are these located in the machine and is it...
I would advise having a copier technician replace those items it is not that hard to do but if you dont get the roller seated in the holder properly it can destroy the transfer belt and that could get expensive
Nov 29, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Jan 17, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
94 people viewed this question
Top Konica Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
isaac johny
isaac johny
Andrew Taylor
Andrew Taylor
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
