Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
My Sony Trinitron won't turn on...has 4 blinks in Standby.
My Sony Trinitron was working one minute....I put my TVR on pause and now my TV screen won't turn on...has 4 blinks in Standby. I've tried the hard reset..leaving it turned off for 5 hours..nothing. I understand according to previous articles about this that I'm supposed to "Check IC1509, Q1505" but what does that mean? How do I do that? Thanks for any help you can give. My Sony Trinitron wasnot working . TV screen won't turn on...has 4 blinks in Standby. I've tried the hard reset..leaving it turned off for 5 hours..nothing. I understand according to previous articles about this that I'm supposed to "Check IC1509, Q1505" but what does that mean? How do I do that? Thanks for any help you can give.
Comment by , posted on Sep 09, 2008 Thanks, Dan. I actually realize now that may model is different. Will that matter? My TV is a Sony Trinitron KV BM14M40.
  • 8 more comments
  • shafqaiser Sep 09, 2008
    tube dose not power up only the sandby led blinks
  • jsburruso Oct 04, 2008
    Trinitron does not turn on. Red led blinking.
  • Anonymous Oct 13, 2008
  • jpbeotch Oct 18, 2008
    My son was turning the TV on and off. Now when I try to turn it on, the standby button blinks 5 times, followed by 2 times.
  • Sherry Shrimplin Oct 19, 2008
    Same problem of blinking in standby and won't turn on.
  • Anonymous Dec 01, 2008
    Same problem. Started after TV shut off by itself
    tV has a black screen, no picture
  • Anonymous Dec 02, 2008
    I have the same problem as the rest of the people on here. TV won't come on. Is less than 3 years old. This is my LAST Sony product. Customer service is in the TANK.
  • Anonymous Feb 08, 2009
    i have the exact same tv and i have the exact same problem... the standby button blinks and it makes the usuall clicking sound but the screen just wont turn on
  • brute8463 May 02, 2009
    my just turned off one evening and now the red led light just blinks as if when i first turn before the picture comes on. It will turn off and on but no picture. Can I fix this problem myself? Is it a relay? or something like that?
  • 61 Answers
There are 3 reasons for 4 blinls
1.unit went to stand by mode because of h-pulse
2.Vertical defflection pulse stopped
3. power line is shhorted or power supply is stoped.
Solution:
1. check 13vdc on A board of powersupply stage
2. Check IC561 on A-board.
Good Luck
Dals123
Posted on Oct 15, 2008
My tv whe I turn it on will only stay on for 4 seconds and then turns off, and the stand by light is on and blinking.
Have you when set turns off and standby or power light flash to count here the blinks if in a sequence like seven blinks, pause etc? This se should have the error buffer.
Dec 09, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony TV shuts down
check for D616 open or Q603 short.
sometime D501 leaky.
Apr 22, 2010 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Black screen model kv-27fs200 there is sound just no picture stand by light blinks 4 times the pauses and does it again
4 times standby light blink shows problem in vertical deflection section of TV.
Please check and replace vertical output IC in main board.
Thanks.
Dec 27, 2009 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Sstandby light blinks & doesn't turn on.
Unplug TV from the power outlet and let it sit for a few minutes, then plug it back. It sould work normally after that.
Apr 28, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony tv
Something is Wrong with the Video.Check Video out,Q705,732,761 and other components on the C board,c also check Q218,219,220 on the A board.In addition,unit could be in IK blanking,try turning up Screen Slightly
Nov 02, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony trinitron
The standby light should be blinking in a pattern. Count,pause,count... Please post the count and that will indicate the circuit in which a problem was detected. That will allow me to give you details and possible solutions.
Thanks,
Dan
Oct 02, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Stuck in standby
The 4 blinks indicate a vertical deflection problem. Either the connections on the legs of the vertical IC are bad or the IC is defective. If you can solder, you can fix this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
Oct 02, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
This may be a vertical circuit problem. IC1509 is usually the vertical IC. If you can solder, I would first try an resolder the pins on this IC. If that fails to resolve it, replace the IC. This IC is a small flat IC attached to a heat sink with about 11 pins. It will be marked LA7837 or something similar. Feel free to post the marking and I'll confirm you have the correct IC.
Keep me posted.
Dan
Sep 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
6,322 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
